Question about Invicta Russian Diver 2625 Wrist Watch
Invicta 2625 crown gasket - Invicta Russian Diver 2625 Wrist Watch
Does Invicta 6981 have a screw down crown?
The Invicta 6981 does have a screw down crown to unscrew the crown turn counter clockwise and pull/push into position to set time, date and other functions . To close crown PRESS it against the case and turn clock wise .You should be able to get a users guide if you enter into your browser "users guide for INVICTA 6981" , it might be a PDF format that you can use for further use . HOPE THIS HELPS YOU OUT .
Dec 25, 2015 | Invicta Watches
How do I set the time on an Invicta Pro Diver watch?
Depending upon the movement, most pro divers have a *****-down crown for water tightness. First unscrew the *****-down crown. You can then pull the stem out one or two clicks. The first click permits you to set the date by turning the crown one way or the other. The second click should permit you to adjust the time. Then push the crown back in, hold it down and ***** it down 4 water resistance. Be gentle when manipulating the crown and stem!
Nov 02, 2015 | Invicta Diver Watches
How to set the day of the week
here is your manual (I think)
http://cdn.invictawatch.com/invictawatch/website2014/webroot//uploads/manuals/2-8040n-pdf
If not, their site is pretty good.
http://invictawatch.com/service/view-the-instruction-manuals
nice video but as good as a chocolate teapot!
https://youtu.be/iv0aXQNH4yY
anyway, here is your info
Invicta Watch Setting Instructions By Ashley Brown eHow Contributor Found This Helpful A watch is only useful if it displays the correct time. Over time, your watch may display the incorrect time as the battery wears down. After installing a new battery, you will also need to reset the time. All Invicta watches have similar instructions for setting the time. Setting the time does not require any tools or equipment.
Other People Are Reading
Watches with Time Only
  1. Pull out the crown. The hour and minute hands will stop.
  2. Turn the crown until the hour and minute hands are positioned on the correct time.
  3. Push in the crown to start the watch.
Watches with Time and Date
  1. Pull out the crown to the first position. The crown can be pulled out to two different positions. Pull gently once to reach the first position.
  2. Turn the crown until it reaches the correct numerical date.
  3. Pull out the crown to the second position.
  4. Turn the crown until the hour and minute hands correspond to the correct time.
  5. Push in the crown twice. It should now be resting firmly against the watch, in its original position.
Watches with Time, Day and Date
  2. Turn the crown to reach the correct day.
  3. Turn the crown clockwise to reach the correct date.
  4. Pull out the crown again to the second position.
  5. Turn the crown until the hour and minute hands display the correct time.
  6. Push in the crown twice so it rests against the watch. The crown should be back in its original position.
Read more : http://www.ehow.com/how_7352591_invicta-watch-setting-instructions.html
Sep 13, 2015 | Invicta Watches
Hello! I bought the Invicta 8939 Ladies watch with 200m water resistance. The manual says that for most Invicta watches, you need to unscrew it first when adjusting the date or time. Mine doesn't...
Most good dive watches with a screw in crown need the crown to be pushed in and turned clockwise AT THE SAME TIME in order to screw in the crown fully and make the watch watertight.
When you want to adjust the date or time, you just rotate the crown counter-clockwise until it pops out a bit. If you gently pull the crown out to the first position you can turn it to adjust the date. If you pull the crown out farther, to the second position, then you can turn it to adjust the time.
Never take your watch into the water unless the crown is fully screwed in finger tight or water will get into the watch movement compartment and ruin it.
Good luck, hope this helps.
Mar 23, 2011 | Invicta Diver 8939 Watch for Women
How do you pull the crown out on and invicta watch
mcdevito75 here, Your invicta may have a screw down crown that adds water proof protection to your watch, try to un-=screw the crown when un- screwed then pull up to set time.
Jun 26, 2010 | Invicta Subaqua Noma Iii S
How do i set the day of the week on my Invicta subaqua noma 6125?
For Invicta chronographs to set the day you need to pull the crown out to position 3 (2nd click after releasing the crown/ furthest crown position/ same position to adjust time). You can only set the day by rotating the crown clockwise. Every 24 hours of clockwise rotation will move the day indicator forward 1 position (Mon>Tue, Tue>Wed, etc). If your watch is set one day ahead of the correct day (Its Tuesday but the watch displays Wednesday for example) you will need to rotate the crown clockwise through the entire remainder of the week in order to get to the correct day, you CANNOT rotate the crown counter-clockwise in order to move the indicator back a day.
May 21, 2010 | Invicta Subaqua Noma Iii Chronograph men...
Just bought an Invicta 8926 can't get the crown to pull position 2 or 3. It is screwed down tight. Is it supposed to be turned counter clockwise to release the crown or is it just supposed to pull out...
Watches vary in design but those that have a high degree of water resistance often screw the crown in.
Try turning the crown anticlockwise before pulling it out.
Apr 21, 2010 | Invicta Automatic Watch
What kind of battery does the Invicta Men's Russian Diver Watch take?
The correct answer is to examine the battery that is in it and identifying the markings on the old battery. To do this you will need of course to remove the case back. Now if the watch does not have a battery in it then that is another story. Sometimes you will see the battery type marked on the inside cover of the case back. Hope that helps, Best of Luck
Nov 17, 2009 | Invicta Russian Diver 2625 Wrist Watch
How to set a invicta 3443 watch up
To set the time pull the crown out to the first position and set the time by turning the crown. Pull the crown out to the second position to set the date. Since this is a diver model you will need to unscrew the crown before it will pull out. Make sure you replace the crown and screw it back down for a good protective seal.
The alarm sets the same way. Unscrew the button to set.
Nov 24, 2008 | Invicta Pro Diver Collection Grand Diver...
Invicta Russian Diver 2625 Wrist Watch Logo
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
