Question about JVC RX-9010V Receiver
JVC rx 9010 Sub room woks fine but main room shuts of receiver after a few seconds this just happened all of a sudden. What can i do Thanks
5 Suggested Answers
SOURCE: jvc rx-5032v audio/vido control receiver
HI MATE YOU NEED THE REMOTE
Posted on Aug 19, 2008
lynchms
  • 93 Answers
SOURCE: JVC MANUAL
http://resources.jvc.com/Resources/00/00/96/LVT0018-001A.pdf
Posted on Mar 04, 2009
  • 1348 Answers
SOURCE: JVC Receiver RX-6040B turns it self off after 10 seconds
the amplifier is seeing a short,or the internal components like one of the output ic are causing dc to show at the speaker terminals.the speaker protect is causing it to shut down.
Posted on May 14, 2009
SOURCE: Reciever Shutting Down
I replaced R916 with a 10 ohm wire wound resister and that fixed the problem on the unit I have. That resister is in serise with R 915 so they should be close in value. Both were marked 8 ohms but tested about 11 ohms on R915 and the bad one tested very high (over 1 meg) so I replaced it. When I first put it back together it didn't work but I noticed that the ground screw at EP901 was not retighted so be sure that all ground screws are tight and all conections are redone before testing with the power cord.
Good Luck,
Thomas
Posted on Aug 06, 2009
I have a JVC RX-9010V I am not getting any sound but i am using smaller speakers rated at 8 omns but the one is rated 150 watt..no sound no hiss..The amp does click as it where turning on, have seen n
Have you tried re-initiating it ? Strange the unit initiates but no sound.
Sorry, I forgot exactly how, but you can Google " factory reset
JVC RX-9010V". hope that helps.
Oct 27, 2014 | JVC RX-9010V Receiver
Around 4 second after power up the unit shuts down..
my jvc rx-8010v turns on and after 4 seconds it shuts down.
Jan 05, 2011 | JVC RX-8010V Receiver
Jvc subwoofer sx pw22 working fine then just stopped working. power light is on and fuse is not blown. any suggestions?
First check all the connections. Something as simple as a loose wire will cause your sub to shut down. If all connections are secure, then your coils on the sub itself may have come apart. To test, try pushing in the center of the sub as it is playing. If sound comes out, it's your coils.
Hope this helps.
Dec 23, 2010 | JVC RX-778V
JVC RX-7030V - Overload - Protection
the transtistors are mounted to a large heat sink. and yes all 4 main trany's need replaced. you can go to the library and look in sams photofact for the service manual. the part #ers are on the transistors. have fun and good luck again.
Mar 09, 2010 | JVC RX-7030V Receiver
May 14, 2009 | JVC RX-6040 Receiver
No subwoofer output-JVC RX-8020V
this is a self-powered sub, correct?
May 18, 2008 | JVC RX-8020V Receiver
No subwoofer output
yes, you do have to set up the sub output in the reciever.
May 17, 2008 | JVC RX-8020V Receiver
JVC receiver shows power, but won't turn on
Your receiver have a bad channel, maybe is a couple of damage
transistor.
Your need indentificate and change the transistors.
Dec 28, 2006 | JVC RX-9010V Receiver
JVC RX-9010V Receiver Logo
46 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
