Question about Oregon Scientific Time Machine Digital Radio Controlled Alarm Clock Excellent
"The Oregon Scientific Time Machine No Longer Works. It Does Not Run Off Batteries. There Is No Model Number On The Machine, but It Looks Like The One Pictured On The Left. What's The Problem?"
SOURCE: Not picking up signal
Have a outdoor atomic garden clock that is not receiving signal. Have changed batteries, thats not the problem. Appreciate any suggestion.
Posted on May 29, 2008
SOURCE: Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Posted on Apr 13, 2009
SOURCE: oregon scientific thermometer model tht312
Actually I just kept working with it, but I did put a new battery in and that may have helped. It is working fine now, thanks for your response.
Posted on Jun 04, 2009
SOURCE: I have an OREGON SCIENTIFIC MODEL 323A travel
The following is from a manual I found online. Step 1. and 2. worked to solve the same problem you're having for my sister-in-law. Hope it works for you too--good luck! JLC
SETTING THE CLOCK AND CALENDAR
CLOCK MANUALLY
1. Press and hold [MODE] button for 2 seconds.
2. Using the [UP]/[DOWN] button to scroll through the 4 U.S.
time-zones (Pacific, Mountain, Central or Eastern) or non-U.S.
cities. Press [MODE] to confirm.
3. If non-U.S. city is selected, the world time city will be flashing.
Use [UP]/[DOWN] to select the city (for city names abbreviation,
please refer to the section “Selecting the World Time”). Press
[MODE] to confirm.
4. Repeat the same procedures to set the hours, minutes, year, month,
day, language of day-of-week and hourly-chime on/off by using
[UP]/[DOWN] button.
Posted on Oct 28, 2009
SOURCE: Manual for oregon scientific rm313PNA
http://pdf.smithgear.com/RM313PNA.pdf
Posted on Dec 20, 2009
I have a Oregon Scientific weather radio. I have lost instructions and am try to figure out how to set alert status by counties.
From the Oregon Scientific site top ten questions: click the link below to download the manual for the model number of your radio:
Manuals XF
Apr 08, 2015 | Oregon Scientific Audio Players &...
Cl-935
This model number does not appear to relate to Oregon Scientific. Look at these two manuals: they may answer your question: http://www.manualslib.com/products/Oregon-Scientific-Eb313hg-294871.html
Aug 03, 2014 | Oregon Scientific Handheld Weather...
Oregon scientific instructions
Which model Oregon Scientific do you have? There are a couple that you need to set the time zone with a switch on the back of the unit. For the BAR388HGA-BK, you press and hold Mode for 2 seconds until it goes into the setting mode. Then you can use the up/down arrows to cycle through the Time Zone options. (1 is Pacific, 4 is Mountain). Press Mode again to confirm the setting and advance to the next item to change. You will leave the Set mode if you do not press a button for several seconds. If you just press and release the Mode button, then you can set the time display option.
A number of Oregon Scientific product manuals are available here:
Technical Support , http://www.oregonscientific.com/us/en/service/support . Scroll down and see the drop-down menu on the right.
I hope this helps.
Jan 25, 2014 | Garden
Oregon scientific model no rar186 how to set up outdoors sensor
I have had this Oregon Scientific model RAR186 unit for years and it works great. The only issue I ever have is when the batteries need to be changed in the remote sensor unit (Oregon scientific model #THN122). It never fails that once I change the batteries that the unit does not send a signal to the base unit. I will often hit the reset button and change the channels on the remote sensor before I finally remember that you need to do the following to get the sensor to talk to the RAR186 base unit:
On the base unit (RAR186), hold down the CHANNEL and MEM buttons for at least two seconds.
You will then see a graphic appear above the channel number that shows that it is searching for the sensor.
Within a minute, you will then see the temperature displayed for the sensor showing that they are communicating.
This is buried in the manual that you probably discarded as did I.
Apparently, if your sensor is broken, you can either search to find a new sensor of the same model or also use the following sensors: THC138, THGR122NX, or THN132N
I have not needed to replace the sensor as once I found the instructions to reset the communication between the sensor and base unit, all was fine. Hope this helps someone. I wrote this instruction using a Sharpie on the inside cover of the sensor since you have to remove 3 screws to replace the AAA batteries (2) in hopes I will remember next time and not waste my time searching the internet and not find the answer. Good luck!
Apr 02, 2013 | Oregon Scientific Measuring Tools &...
Remote sensor (thn122) not working, batteries changed, terminals cleaned
Mar 05, 2013 | Oregon Scientific Measuring Tools &...
Has the Oregon Scientific WRS101 been recalled?
It looks like some models were recalled. Go to this site and see if your radio still qualifies for the recall, it looks like your model number probably does.
http://www2.oregonscientific.com/recall_form.asp
Apr 02, 2010 | Oregon Scientific WRS101 Weather Radio
Oregon Scientific Model 323a--Atomic clock...the atomic clock keeps setting itself to one hour behind what time it actually is in my time zone...I mannually re-set the clock to the correct time...but when...
Make sure that the clock is set for the correct time zone and that the DST (Daylight Saving Time) function is ON. Also, although not mentioned in the manuals, these clocks will typically jump and hour ahead or behind when the batteries get weak. Replace your batteries if they are more than a year old.
Bill B
Mar 21, 2010 | Oregon Scientific RM323A Travel Alarm...
Mar 26, 2007 | Oregon Scientific RM983A Radio Controlled...
Oregon Scientific Time Machine Digital Radio Controlled Alarm Clock Excellent Logo
208 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Gyula Lacz
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
