Question about Bosch Ovens
Removing control panel on bosch HBN 13M5.1B Oven
Need to repair oven knob.
murdozzz2
  • 75 Answers
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Posted on Dec 09, 2007
  • 142 Answers
SOURCE: I have Bosch double oven HBL HBN and does not
sensors would not make it heat up any quicker element might be getting weak,but 10 mins to heat up is about normal.
Posted on Sep 28, 2009
  • 9 Answers
SOURCE: oven won't turn off
I SOUNDS LIKE THE SELECTOR SWITCH INSIDE HAS STUCK ONE OF THE TABS TOGETHER. THEY ARE A SMALL ROW OF BRASS FINGERS THAT CONNECT WHEN THE KNOB IS TURNED..
Posted on Mar 09, 2010
espressonist
  • 1711 Answers
SOURCE: I need to replace the
We have here below two videos that can help you to replace the oven fan. Maybe there will be some diferences in your model but these videos is the best solution to your case
http://www.youtube.com/watch?v=6QGurNvbI0Q&feature=channel
http://www.youtube.com/watch?v=pEhRqdvpiJM&feature=channel
Posted on Nov 07, 2010
SOURCE: bosch hbn 13n5.1b bottom oven temperature control knob not working
Yes they can be and if your savey they have universal oven switches that do the same thing only much cheaper than OEM parts.
Posted on Apr 07, 2012
Bosch HBN 91 Sticky Fan
Yes you can oil the shaft...but the problem is within the bearing itself. You might be lucky and only have to oil it once...but chances are your bearing will sieze again...I suggest you remove and replace the fan.
Dec 02, 2013 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Tip
Common heating faults with Bosch HBN 430560B / 430520B single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBN 430560B / 430520B Single Oven
Function selector knob loose
contact the bosch service agent for spares
Sep 03, 2017 | Bosch Ovens
Bosch hbn 13n5.1b bottom oven temperature control knob not working
Apr 07, 2012 | Bosch Ovens
I HAVE A HBN 43M5.OB DOUBLE OVEN AND THE MAIN OVEN WILL NOT HEAT UP AND THE RED LIGHT STAYS ON .THE GRILL WORKS ON THE MAIN OVEN AND SO DOES THE SMALL OVEN WORK.
Most likely the heater element has burnt out. This is accessible by removing the panel in the back of the oven.
*** ENSURE POWER TO OVEN IS OFF BEFORE ATTEMPTING REPAIR ***
Nov 14, 2010 | Bosch Ovens
Oven won't turn off
Mar 08, 2010 | Ovens
Bosh double oven. Temp is 100 degrees cooler on top oven, any ideas? both on bake mode
The fact that top oven is 100degrees less than bottom is no relation between the two; they are controlled by independent stat controls and if the only way you know if the temp is correct, is to set a temp (such as 350 degrees) and put a thermometer in that oven to see if the thermometer is with in 25degrees of the control settting. You need to do this for the bottom oven as well to see if it is aslo within 25degrees of the setting. then you make adjustments for each unit independently. If the controls are mechanical (knob), then the adjustment is within the control (usually by removing knob and serching for a small screw). If the controls are electroonic, then you need to search the circuit board to see if there is adjstments mounted on the board. Goodluck,Macgivor
Jan 31, 2010 | Bosch HBN 455 Stainless Steel Electric...
INSTRUCTION MANUAL
you can obtain the instruction manual for this directly from the bosch web site free of charge if it is not listed there try the BSH Home appliances ltd site they are the manufacturers repair service in the UK
Feb 23, 2009 | Bosch HBN 131560B / 131520 hot-air...
Bosch hbn s gb
oven element would need model and ENR No. to supply
Sep 16, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Retractable function selector knob stuck
facia panel most probably need removed, not to bad a job, but oven need to come out... go to bosch, web site...search parts finder with your model , and you will see an exploded diagram, this may help yet you get an idea on how it comes apart.. failing that call an engineer...
Jul 02, 2007 | Bosch HBN 560570B / 560550B Electric...
Ovens Logo
158 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
