Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Black Smoke in exhaust and not idling properly
Changed idling air sensor
    Scholar:
  • 117 Answers
GM has a problem with their fuel pressure regulators leaking . Since it is under the intake manifold, it adds extra fuel to the cyls. Also make sure the fuel pressure is within specs.
Posted on Nov 02, 2013
I changed the idle control valve still don't idel could i have a bad tps sensor
Black smoke usually means burning too much gas. The problem is the IAC idle air control. I would also replace the TPS
Jun 07, 2017 | 2002 Kia Optima
Black smoke from exhaust
Hi Paul,
I think you're right - it sounds like you're running to RICH (too much fuel / not enough air), but I would think that you'd see the check engine light on.
If you are too rich, there's probably an O2 sensor or other computer issue going on - and if allowed to persist, you'll probably end up with a clogged catalytic converter. As long as the sensor / computer is adjusting your air : fuel ratio, there little you can do to override it. I believe the computer will continue to adjust the mixture to get what it wants to see by the O2 sensor in the exhaust.
Bring it to a mechanic / dealer to get this fixed correctly - before you waste any more fuel or cause additional problems with the cat converter or other parts.
Jul 01, 2013 | Cars & Trucks
Mazda 3 won't idle.
code p0 refers to intake air temp sensor --circuit malfunstion causes are wiring open circuit(broken)wiring short to ground bad earth and ECM.
code po113 refers to mass air flow( MAF) sensor/ volume air flow (VAF) sensor --low input. Causes may bewiring short to ground MAF?VAF sensor faulty ECM
code po327 refers to Knock sensor (KS) bank 1--low input. Cause may be insecure (loose) KS poor connection- wiring ---short to ground incorrectkly tensioned KS and ECM
Mar 10, 2013 | Cars & Trucks
Lack of power and lots of smoke from exhaust
You've done a lot of work. How does your EGR valve look Its the 'space ship' gizmo under the air cleaner. Remove and decoke is a quick job and it may just cure the lot
May 07, 2010 | 1999 Chevrolet Silverado 1500
Black smoke coming from exhaust and idleing up
check
ingectors maybe one not working
spark plug
air flow mass
feul sensor
Nov 07, 2009 | 1995 Nissan Maxima
1986 C Lebaron turbo 4 cyl. black smoke when
Black smoke is excessive burnt fuel. White is excessive unburnt fuel. Have your turbo checked and the air filter. Good Luck
Aug 22, 2009 | 1986 Chrysler LeBaron
Black smoke from exhaust,no idle in warm temps-97 Nissan 2WD 2.4L
I had a 1995 nissan pick up with a similar problem, may want to try cleaning out or replacing the EGR valve.
Jul 23, 2009 | 1997 Nissan Pickup
Running rich and blowing black smoke
Could be a number of different things.Fuel pressure relief valve not working,injector pulse too long,Is the air box lid securely fastened and air cleaner clean.Are there no leaks between the air box and throttle body(intake tube).Have you checked oxy sensor.air flow meter may be also possible.Try squeezing the flexible fuel hose enough to allow the engine to run and see if the engine reacts better if it does you have excessive fuel pressure.
Nov 20, 2008 | 1990 Toyota Celica
1991 V.W. jetta 2.0 16v
If you facing a little black smoke along with it your engine is running a little rich. Black smoke indicates unburned fuel and this could cause a black stain and leading to test failure
Jul 06, 2008 | 1991 Volkswagen Jetta
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
53 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
