Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Printer not printing
Canon Multipass MP730 , the ink is not flowing through the head. I tried all the programs to clean it . Did not work. Can I open up the head some how and clean it?
I'm here in the office & the printing is blurred on certain lines. when i xerox, it does the same. do i need 2 clean something? pls help. i just changed the ink cartridge.
Posted on Jan 19, 2009
My Canon MP730 printer will not print in black and white...we have put in a new ink cartridge and tried turning the machine on/off. The printer is set to print on black and white. What do we do?
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Dec 31, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MultiPass MP730 purchased 2004 NOT Printing Black INK- did: new canon ink tank inserted (never used refills) ran: printhead maintenance mannually cleaned print head w/ rubbing...
Dec 02, 2010 | Canon Office Equipment & Supplies
Canon MP730 won't print black ink.
Hi you can try this.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you will need to clean out the waste ink it inside the printer all got to be open up to do this.
Ok I have put a MP-Tools in my website for you to try out this tools are for reseting your inks plus it can do much more.
Click on the link to download it.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 15, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
How do I change the waste ink absorber in a canon ink jet printer
2. Hit "Copy" Key
3. Hit "#" Key
6. Hit "0" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Dec 28, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
My MP730 will not print from the computer. It
The print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 min then turn the print head around with the nozzles down.Hold that for every color of 5 min.Then put the print head in hot water with the nozzles down.Left it water about 15 min and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Nov 27, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
How do I remove a Canon 730 Multipass print head to clean it? The Black ink isn't printing - I've cleaned the print heads using the software, but now need to remove the print head and clean it manually...
Press the button on the right hand side of the printer. Lift the lid, pull up the little gray handle. Rock the print head container a bit and you'll see a little metal bar. Grab that and pull straight up.
Jun 12, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MP730 not printing. Printhead cleaning doesn't help.
You may need new print heads. They are around $50. Or, you could do this: Take the print head out of the printer, and run warm water from the tap (not high pressure), over the ports for about 5 minutes. Ink will drop out of the jets. Dont touch the electrical contact end of this head. This may clean the head enough so it works again. If not you need a new print head.
Apr 25, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
My multipass 370 printer won't print
Hi
MP730.
2. Hit "Copy" Key
3. Hit "#" Key
6. Hit "0" button
Mar 14, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MP730 won't print at all (blank pages).
try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
Feb 03, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
115 people viewed this question
old marine
old marine
