Question about Philips 170C4FS 17" LCD Monitor
Osd main controls locked philips 170C
Aparece cada 10 segundos ese mensage y no lo puedo quitar
VOTIT
  • 2071 Answers
SOURCE: helpme please
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Posted on Aug 25, 2008
SOURCE: philips monitor 190b6cb/175
Same problem OSD main controls locked the 5 seconds later OSD main controls unlocked then system closes down sayingproblem with atkdisp, what does all this mean? Can still operate my computer but thid damned flashing OSD message continues.
Posted on Oct 21, 2008
SOURCE: OSD Main Controls Locked
Hold the "OK" button for about 20 seconds
It will initialy come up with the message "OSD Locked" and then after the 20 seconds a ne message will appear "OSD Unlocked"
Posted on Jan 19, 2009
benwabnick
  • 2404 Answers
SOURCE: OSD main controls locked and moving cursors by itself
i think the main board is flaky in that monitor. Hook up another known good monitor to that computer and see if it behaves in the same way.
If it does behave in the same way then you know its either the video card or the motherboard if you have an integrated video connector to the motherboard.
If it goes away then you know the phillips monitor is bad.
If its the phillips monitor that is bad for sure. You can try taking off the front cover and try cleaning the contacts on the main board in the front of the monitor. Could be that a few of them have dust or dirt and is activating those buttons by accidents inadvertently.
Posted on Jun 27, 2009
SOURCE: i have a monitor philips 190S and the osd main
23 Oct 2008 ... There are a few things you can do to solve the problem, ... The menu should be reset and the flashing OSD control message should disappear. ... controls locked, then it comes up again saying OSD main controls unlocked. ... I have a Philips 190S monitor. I do have a button to enter the onscreen menu. ...
filetonic.com/blog/2008/10/23/osd-main-controls-blocked/
Posted on Dec 06, 2009
Mi receptor optimus cuando enciende aparece power off y se apaga en pocos segundos
tengo un problema con mi stav-3770 y cuando lo enciendo me dice power off que debo hacer en ese caso ??
Jan 08, 2013 | Optimus STAV-3770 Receiver
Tengo problemas con mi HHR la luz del T/C no se apaga y cada vez que pongo el cambio en Reverse o Drive hace un golpe en el motor, como puedo solucionar el problema?
Hola, Tengo Una HHR Y Cada Vez Que Me Aparece El T/C Me Empieza A Dar Golpeteos En La Caja Cada Vez Que Meto Drive Y Al Avanzar Da El Golpeteo De 1 A 2 Despues De Esto Tambien Me Aparece El Check y Al Aparecer Esto Ya no Enciende Desde El Control Remoto Yme Gasta Un Poco Mas De Gasolina Me Han Dicho Varias Personas Que Son Los celenoides Y Tengo Esa Duda
Apr 13, 2012 | Chevrolet HHR Cars & Trucks
Eclipce 2000 v6 24valvulas no puedo quitar la transmision para revisar el clutch. me podran ayudar?
hola
amigo no se si ya pudiste quitar tu transmision pero yo te dire lo q necesitas !
necesitas un dado de 10 puntas para unos tornillos que vas sujetos ala prensa por eso no baja
el dado tengo 1 semana buscandolo por todos lados y nadie lo tiene nisiquiera lo conocen espero averte ayudado!! =P
Oct 10, 2011 | 2003 Mitsubishi Eclipse Spyder
Cada ves que predo mi TOSHIBA e-studio202L me aparece error c440
tienes un problema en el area del fusor, lo puedes resetear siguiendo estos pasos:
1.- prende la maquina presionando 0 y 8. espera unos 5 segundos hasta que la copiadora haga un sonido y prenda en test mode
2.- escribe la numeracion 400 y presiona start.
3.- te debe de aparecer un numero de error, para resetearlo solo escribe 0 y dale set o start.
4.- apaga y prende el equipo normalmente y has pruebas funcionales.
si tu equipo sigue marcandote problemas vas a necesitar reemplazo ya sea de las resistencias termicas y el sensor de temperatura, algun fusible o alguna tarjeta controladora de alto voltaje.
Suerte...
Mar 15, 2011 | Toshiba e-Studio 232 Black and White...
Abri mi terminal Verifon vx510 para darle mantenimiento pero cuando la volvi a cerrar solo parpadea la pantalla, creo que se activo el tamper como lo desbloqueo o restauro, algun switch activa esto
buenas tardes lo que debes de checar son unas gomas que tiene adentro son las que activan el parpadeo o si necesitas ayuda mandame tu correo el mi es dawer_2010@hotmail.com
Jun 09, 2010 | VeriFone VX510
Disassemble the monitor till you see the controlls board. Most models are very easy for disassembling. Unplug the controlls board and check with multimeter if any of the buttons is faulty. It will have some values when you check 1st and 3rd leg. If that is the case spray all the buttons with contact spray and rewire them just in case. I've just done this on my 170c monitor and now it work like a charm.
Sep 19, 2009 | Philips Computers & Internet
Mi monitor se prende y luego se apaga
Mi monitor hp pavilion enciende pero luego sale monotor going to sleep y se apaga. Antes de apagarse se puede leer default en dvi cable. Que ocurre?
Mar 24, 2009 | Computers & Internet
Problem with OSD Main Contorls unlocked/locked
Philips say "To unlock the OSD Controls press the “MENU(OK)” button for more than 10 seconds while there is video input from PC."
Jan 29, 2009 | Philips 190B6CB/27 19" LCD
Error EOOO ir 2000
Hello ...
E000 The main thermistor reading does not reach 40oC 14 sec after the fixing heater goes ON (fixing low temperature error)
Jan 08, 2009 | Canon imageRUNNER 2000 Copier
Philips 170C4FS 17" LCD Monitor Logo
47 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
