Question about Sanyo SCP-3100 Cellular Phone
Multiple beeps from phone & battery LED flashes
Have replaced the battery with a new one but the phone still occationally beeps multiple times when the battery is noweher near flat. Has anyone else has this problem & found a fix? Thanks in advance
You can try doing a Master reset on ur fone. your symptoms are that of a battery having a memory effect from charging with a charge for a period of time. But you said you changed batteries..new i hope... with the same result. maybe the fone has developed the battery memory problem. so try reseting it to factory settings and see. If that dont work.. carry it to ur provider and let them reload the software for you.
Posted on Jun 25, 2007
SOURCE:
Battery lights flash occationally
Its possible the belt is getting wet and slipping.
Jan 17, 2014 | Toyota Highlander Cars & Trucks
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
Forgot the combination to the lock. Is there a way to retrieve the combination or return it to its factory default combination 1, 2, 3, 4, 5
The instructions below are copied from the programming instructions (page 11):
ERASE ALL PROGRAMMING
(The "out of box" factory default will be restored)
1. At the back of the lock, remove the screw at the bottom of
the lock housing and remove the cover.
2. Take out the battery pack and remove battery power by disconnecting
the battery pack.
3. Plug in the (provided) male shunt connector into the yellow
wire female connector.
4. With shunt connector connected, re-connect the battery
pack. The lock will immediately sound 3 short beeps (if
these 3 beeps are not heard, then restart at step 2).
5. The lock will then sound more slow beeps, 1 beep for every
second it takes to clear the memory.
6. After a few more seconds, the LED will slowly alternate between
flashing red and green--disconnect the yellow wire
shunt connector.
7. The LED will continue to slowly flash green and red for 25
seconds. To enroll Function Cards, proceed immediately
as follows:
• With the lock LED slowly alternating between flashing
red and green, present the Function Card #1
to the lock. The lock will sound 5 slow beeps.
• The lock LED will flash green rapidly. The lock is
ready to enroll the Function Cards.
• Re-present Function Card #1 to the lock. The
lock LED will flash green then red, with two beeps
(indicating the card was enrolled successfully).
• Present Function Card #2 to the lock. Again, the
lock LED will flash green then red, with two beeps.
• Continue to present, in order, Function Cards 3-
9. Each time a new Function Card is presented, the
After the 9th Function card is presented, the lock LED will flash
green twice, sound two beeps, and will then remain silent,
ready for use. Note: If the lock continues to beep after presenting
the 9th Function Card, check to verify that the yellow
wire shunt is disconnected.
Note: If you only wish to use the first 3 Function Cards, simply
allow the lock to "time out" after 30 seconds.
Here is the link to the complete instructions, in PDF form. You will need Adobe Acrobat or equivalent to view them:
http://napcosecurity.com/download/PL3000_WI1280A.04_PROG.pdf
Good luck-and please provide feedback if this helps!
Nov 04, 2011 | Trilogy ALARM LOCK PL3000 Series T3 Prox...
The battrey leds stay flashing i changed battries also the led still flashing
Automatic: The UPS performs a self-test automatically when turned on, and every
two weeks thereafter (by default). During the self-test, the UPS briefly operates the
connected equipment on battery.
Manual: Press and hold the button for a few seconds to initiate the self-test
REPLACE BATTERY LED ILLUMINATES
Replace Battery LED flashes and
short beep is emitted every two
seconds to indicate the battery is
disconnected.
Check that the battery connectors are fully engaged.
Weak battery. Allow the battery to recharge for 24 hours. Then, perform a self-test. If the
problem persists after recharging, replace the battery.
Failure of a battery self-test. The UPS emits short beeps for one minute and the Replace Battery LED
illuminates. The UPS repeats the alarm every five hours. Perform the self-test
procedure after the battery has charged for 24 hours to confirm the Replace
Battery condition. The alarm stops and the LED clears if the battery passes the
self-test.
Sep 09, 2011 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
Have had to replace the backup battery in the opener 3 times in the last year. What could be draining the battery?
Here is some general information that you probably already have. The opener should keep that battery charged. I would recommend getting a service technician out. Just when you really need that battery backup it will be out.
On top of your unit is a battery pack with three colored led lights. You can tell what is going on by looking at these. This information is in your manual or here it is. GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing GREEN LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Jun 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain Whisper Drive and it started beeping. Reading the manual, it seemed that I needed to replace the battery. It is about 5 years old. Replaced the battery and the LED is no longer red but...
On the back of the garage door opener there is a red button. Depress this button and sync your keypad to the opener. This will re-establish the code and reset the remote.
May 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have the rona keyless entry lock (with single numbers on the front to enter our code.) For some reason, I cannot get it to change the code and have since lost my instructions. Can you please tell me...
remove all batteries then press any button on the keypad 3 times.Wait 10 seconds then replace batteries.You should hear a long beep followed by a short beep then press and hold the 0 button for 3 seconds. Red LED should flash 3 times and you should hear 3 long beeps. Now release the 0 button. Now enter new Master code (4-12 digits) followed by the LOCK button.You only have 15 secs to do this. LED should flash green once followed by a melody tone. Good luck
Bob...
Sep 07, 2010 | Directed Dei Valet 561r Remote...
My Dell 100L will not switch on and battery will not charge.
since the LED is orange it might be a ram issue. try to locate the memory modules in your computer then try to reseat them. or if you have 2 ram modules try to remove 1 first then try to turn on the laptop check if it will do the same thing. then try removing 2 ram modules check if it will beep. if no beeps ask for mobo replacement. if it has beeps take note of the beep codes.
Oct 03, 2009 | Dell Latitude 100L Notebook
Power LED flashes three times-no boot
Try this. Power down. Remove the battery. Remove the memory. Replace the memory. Replace the battery.
Try to power back up.
Best of luck...
R-
Nov 05, 2007 | HP Pavilion dv1000 Notebook
Sanyo SCP-3100 Cellular Phone Logo
112 people viewed this question
Top Sanyo Cell Phones Experts
Wess Rohadfox
Wess Rohadfox
Level 1 Expert
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
