My left tail light is out. I need to know how to replace it. Thanks.
They are indeed accessible from the back of the trunk. In your model year there are two or three plastic pins holding the carpet to the metal so you will not see the bulb and wires. Pull the pins out with pliers (might use a bit of force) and you shall uncover the secrete wires leading to the bulbs. Screw the bad one out and you can get a replacement from a parts store.
Tail lights on most newer cars are accessible by opening the trunk and locating the rear of the tail light then just grabbing and twisting the plastic bulge (bulb assembly) where the wire goes, allowing you to remove the bulb assembly and replace the bulb!
Good Luck!
TAIL LIGHT NOT WORKING
It
can be faulty tail light bulb or its issue with tail light control
switch or its wiring's are short.
Check the voltage at fuse slot of tail light.Do you receive 12 volt
there.If not,then it says tail light switch is not receiving power supply.
There
are few help links related to your problem.I suggest you refer the list and
check the help links.Click the link below:-----
http://schematicsdiagram.blogspot.com/2011/12/right-turn-signal-not-working-on.html
http://schematicsdiagram.blogspot.com/2011/12/only-one-side-indicator-light-working.html
http://schematicsdiagram.blogspot.com/2011/12/turn-signals-not-working-on-1987-jeep.html
SOLVE YOUR 4 WAY FLASHER RELATED PROBLEMS HERE
http://repairhelpcenter.blogspot.com/2012/11/4-way-flasherturn-signal-flashersignal.html
http://whatisbyme.blogspot.in/2012/04/1994-toyota-camry-bypass-tail-light.html
http://schematicsdiagram.blogspot.com/2011/12/car-tail-lights-not-working.html
These details will help.
Thanks.
http://technoanswers.blogspot.in/2012/04/2008-toyota-rav4-replace-tail-light.html
2003 Chevrolet S10 Tail light Fuse
http://schematicsdiagram.blogspot.com/2012/11/2003-chevrolet-s10-tail-light-fuse.html
Chevrolet Parking light and Tail lamp light
Wiring diagram
http://schematicsdiagram.blogspot.com/2012/11/chevrolet-parking-light-and-tail-lamp.html
Car Tail Lights Not Working?
Turn Signal Not working
http://technoanswers.blogspot.com/2012/11/turn-signal-not-working.html
Right turn signal not working on Pontiac Car?
Only one side indicator light working on car?
Turn signals not working on 1987 Jeep
Wagoneer?
SOLVE YOUR
Thesedetails will help.
Thanks.
