Question about Husqvarna GAS CHAIN SAW 435 16"
What kind of tool do i need to adjust jets on my 435 husky saw
  • Husqvarna Master
  • 2,239 Answers
You need a special tool with an internall star pattern, part no. 530035560, check the web if the dealer will not supply you.
Posted on Jan 02, 2013
dontbother10
  • 2220 Answers
SOURCE: I have a new Husky saw that does not maintain
All modern saws are set to operate very lean at sea level (thank the EPA). If you bought it locally take it back to your Husqvarna dealer, he should adjust it without charge. If purchased at a big box store or on line I'd take it to a dealer at the altitude where you use it and ask them to adjust it. there will be a fee but running it to lean will cause it to fail. A few dollars spent for an adjustment will certainly be less expensive than a new saw.
Lou
There are tabbed plastic caps on over your fuel adjustments. Thank the EPA once more.
Posted on Sep 04, 2009
SOURCE: Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
Posted on Sep 11, 2009
  • 15 Answers
SOURCE: cannot adjust carburator on husqvarna chainsaw 435
the screws are on the side of the carb very small heads flat screw driver is needed as they have a cover on them it has to fit inside the cover H (high) and L (low) tighten them all the way in tight but not forcing them turn anti clockwize 1 1/4 turns try to start the saw pull the trigger and adjust the H (high) till it runs smooth then  let it idle then pull the trigger again saw should rev without loss of revs if it does turn the L (low) small amount either way till it does  hope this helps
Posted on Oct 19, 2009
  • 4088 Answers
SOURCE: carburetor tool
Unless you are skilled enough to make your own, you are stuck taking the saw to a servicing dealer as they are the only ones allowed to possess the necessary 'D' head screwdriver. Give thanks to the EPA for mandating the prevention of mal-adjustment pollution.
Posted on Jul 07, 2010
  • 2239 Answers
SOURCE: I have a husqvarna 435 chain saw and need to
There is a special tool required, the part no is 530035560 available from Husqvarna/Jonsered dealers, as posted earlier this should be a dealer adjustment as the machine is new.
Posted on Jan 05, 2011
Chainsaw chain keeps running
This is a carb adjustment issue and needs to be rectified before using it again, the L jet on the carb is set too lean, if you cannot correct yourself i would suggest taking it to the local chainsaw shop.
Jan 19, 2014 | Husky Garden
How do i set air on husky 435 saw to fix boggy runnin
Mitch:
Adjust the fuel and air mixture screws while the saw is running... you'll find that "sweet spot"... it just takes a little patience! Small adjustments... If you over adjust and the saw quits running or starting, GENTLY turn both screws in all the way (don't damage the needle valves or seats) and turn both out one and a quarter (1 1/4) turns out. The saw should start, then adjust from there.
Jan 01, 2013 | Husqvarna GAS CHAIN SAW 435 16"
I have husky 435 and want to put a 14" bar on the
Most all brands of chain saws will except one size smaller and one size bigger than what came with the saw. You just have to make sure the bolt holes and the hole for the adjustment pin match the origional bar.
Aug 26, 2012 | Garden
I have a husqvarna 435 chain saw and need to adjust carboorator but the adjustment screws have no way turning them. They are just round heads. New saw
Jan 03, 2011 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna 345e
I have a model 435 Husky that had the same hard-to-start problem--warranty service replaced the carburetor and it seems to work ok now. The chain that continues to turn can be fixed by turning the idle-speed screw (not the H or L jet screws) CCW a small amount until it can be accelerated then dropped back to idle to quit driving the chain. Hope this helps!
Apr 05, 2010 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna chain saw oiler problem
I fear you are correct about the oiler problem. I see a lot of oiler problems on these saws. Sooner or later Husky will have to address it. Ask the dealer about modifying your oiler; the 350 has an adjustable and might fit 1 or both of these saws. I think Husky needs to admit the nonadjustable is a mistake, and come up with a fix.
If you want to do some research start with the IPLs here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Please post back (below) with what happens at the dealer. Take your buddy and his saw with you! Good Luck. HTH
Lou
If Husky starts modifying all these with 350 oilers I want compensation...LOL
Feb 17, 2010 | Husqvarna 450 e-series 18" Chain Saw
Hard to start Husqvarna 435
reportedly you need to open up the low idle jet screw about 1/4 turn, takes an odd shaped tool to get at it, Husky sells this tool, or you can probably makeshift one from hard plastic tube... anyway, this is due to EPA issues, but once you increase the L adjustment 1/4 turn (counter clockwise, I believe), problem is said to go away.
Aug 30, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husky wet tile saw repair service
I need to order a part for my Husky wet tile saw. can someone give me an email address. web serches are a bust.
Aug 24, 2009 | Husky Wet Tile/Stone Saw with with Laser...
Jul 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Need to adjust carburetor jets of homelite chain saw
what is the adjustment for high and low settings on a homlite 330 ?
Jan 11, 2009 | Garden
Husqvarna GAS CHAIN SAW 435 16" Logo
175 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
