Question about RTO Forward Reverse Drive Gears:Mgt
My 1990 chevy van will run okay sometimes and wont go over 15-20
I drove my van to an appointment and on the way there it wouldnt drive over15-20 miles an hour then on the drive back it drove fine . also sometimes when i change gears it makes a sound that can only be discribed as a clunky noise like clunk ,clunks.
  • whispers1246 Jan 22, 2009
    I already did that but it didnt help
  • 350 Answers
Check your transmission fluid with the car running and fully warmed up!
Posted on Jan 19, 2009
  • Jack Iaria
    Jack Iaria Jan 22, 2009
    I'd try FixYas' Premium Guaranteed Answer by re-asking the question! It's awesome, fast and guaranteed!
    Hope this is helpful.
    Good Luck!
1990 Chevy van fusebox location
Donald, You did not state the model, so I posted the link for the models I found for chevy van fuse box. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Interior Fuse Box Location 1990 1996 Chevrolet G20 1994 Chevrolet G20...
Blown Fuse Check 1990 1996 Chevrolet G20 1994 Chevrolet G20 Chevy Van 4 3L...
fuse box diagram 1990 chevy astro van pdf 1 Docs Engine com
1990 Chevy van fusebox location Google Search
Jul 27, 2016 | Cars & Trucks
1996 chevy exspress van wont start after i replaced damm near everything but the motor it started up i drove and it wouldnt start back up
Get a mechanic out to take a look. If everything has been replaced it should not be too costly to repair, probably a matter of adjusting what is there
GOOD LUCK WITH IT
Jun 04, 2015 | Cars & Trucks
Transmission for 1999 cara van
did you check the fluid in the transmissin it could be low or also it could need a new transmission filter i wouldnt try to drive it it anymore without checkin or changin it because it will burn it up
Feb 16, 2013 | 1999 Dodge Grand Caravan
1990 Chevy Van with a 350 small block that has a mind of it's own.
Try to get it running a bit to warm up the exhaust. Take a point and shoot thermometer and take the temp of the cat. If temps exceed 400 degrees I would start to suspect a plugged cat.
Mar 05, 2017 | Chevrolet Cargo Cars & Trucks
2002 express 1500 van, will not start
remove dog house locate test port and install guage should be 45-60 psi
Mar 03, 2010 | 2002 Chevrolet Express
I have a 1990bmw 325i. i turned the car off one day. ran in the store. ten minutes later came out and the car wouldnt start. left the car. came back thirty minutes later the car started. drove the car 25...
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Dec 14, 2009 | 1990 BMW 3 Series
Starting a 1990 Chevy Van
that is strange the oil pressure only builds up when the motor is running i would be wary if it was me buying it hope this helps Jim
Mar 19, 2009 | 1990 Chevrolet C1500
RTO Forward Reverse Drive Gears:Mgt Logo
80 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
