Question about Tools & Hardware - Others
I have an ARROW # HT50P hammer stapler. I am using genuine arrow T50 staples.I bought it new a couple of years ago and have only used it a lightly a couple of times. The problem is the thing has alway
My stapler is an ARROW hammer stapler # HT50P. I know how to un jam it. The thing is it jams up very often. Is there a way to correct the problem, or should I just throw it away and get a different brand.
  • 9 Answers
SOURCE: My friend let me borrow
Most arrow staplers have slide levers along the sides toward the front. Pull back on these and it should pop open. Some however load from the rear of the stapler. You push in and down on a square metal piece and it will unlock and than you pull it out toward you. slide in a rack of staples, put it in, relock and ready to go. If you put in too many staples it wont go all the way in to re lock.
Posted on Dec 02, 2008
SOURCE: Arrow T-50 stapler
Take out the screw/nut combo @ the end of the gun where you load the staples. The whole rail that holds the staples will then come out and you can then get the little devils of the nested, jammed, rousted up staples out by sliding them out with a screwdriver. Don't jam the screwdriver into your fingers/hand when doing it.
Posted on Dec 08, 2008
rowdy45176
  • 2176 Answers
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Posted on Mar 15, 2009
SOURCE: there's a jammed staple but I can't figure out how to open it to fix the problem and refill it
This is how it works on the Arrow staple gun. On the back bottom, opposite end from where the staples come out, there is a little plate. Push it in and it unhooks and pops out. attached to a rod. When you refill with staples, just push them in, then put the rod back in and the spring applies the pressure.
Posted on May 31, 2009
  • 384 Answers
SOURCE: my jt 21m stapler is jammed and i cant get it to open
At the end of the stapler opposite where the staplers are driven out is a release. Push it in and turn it should come out with a long spring.
Posted on Jun 26, 2009
How to put the spring back in the handle of Arrow T50 Stapler?
Ref. recocking the spring handle in your Arrow T 50 Stapler
1. secure the stapler in a vise. You need three hands to recock the handle spring.
2. Using a notched tack lifter hand tool, with one hand holding the handle so as to expose the spring, place the notched tool against the spring arm and force it to the rear. it will now be under tension.
3. Wiggle the handle into position so that you can quickly insert the clevis pin. Once secured, let go your handle that is now under tension. Replace clevis ring.
4. Dry fire to test.
Sep 18, 2014 | Arrow Staple T50 3/8"" Monel stainless...
Craftsman 68514
The replacement pack for this gun say the staples are compatible with "Craftsman 68514 and 68517; Arrow Brand T50 Staplers T50 and T55; and Stanley/Bostitch TR110 and BT110 staple guns", so I assume they are also backwards compatible. That's just an assumption though.
Mar 22, 2013 | Arrow Tools & Hardware - Others
The info on the gun says it will shoot many different staples, but it will only take 3/8 staples and I need to use 1/2 staples to do the job.
The T50P stapler uses T50 staples of various lengths, including 3/8, 7/16, and 1/2. Is it possible that the 1/2 inch staples you are trying to use are not T50? All T50 staples are the same width and should fit your stapler. There are several other widths of staples that are not T50, although T50 is the most common.
Nov 29, 2010 | Arrow T50P ARROW STAPLE GUN
I need to put in new staples. How do I do it?
This stapler does not swing open like a paper stapler. It has a little square metal piece at its heel (about the size of a postage stamp). Press in lightly on this metal piece as you move it up or down just a bit, to unhook it. Then pull out the piston and spring assembly, insert staples in the hole and replace the piston. You must use T50 staples (of various lengths). T35 and others will not fit. Good luck, Al K
Sep 01, 2010 | Arrow T50P ARROW STAPLE GUN
Staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
May 26, 2010 | Arrow T50P ARROW STAPLE GUN
Can't load staples
Fire the stapler with the load chamber open and down, see if anything falls out. Point it in different positions and fire it, just make sure it cannot fire anything at you.
Apr 18, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
My friend let me borrow an Arrow HT50P Stapler and I would like to know how to open the stapler so I can load it
Dec 02, 2008 | Tools & Hardware - Others
Tools & Hardware - Others Logo
29 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
