Question about Sewing Machines
How to adjust tension on memory craft 7000 - Sewing Machines
SOURCE: Janome Memory Craft 7000 Sewing
My Memory Craft 7000 sometimes does the same thing, if it's very cold. Try warming it up by placing it near a heat source, a vent or a floor heater, for a few minutes. Then it works perfectly.
I've used these machines for over 20 years now, and they're my favorite!
If this doesn't solve your problem, you need to take it in for servicing.
They are work horses, but they do need their maintenance from time to time.
I hope this helps you.
Posted on Jan 18, 2009
bargainbox
  • 1388 Answers
SOURCE: Janome Memory Craft 5700 LCD Screen
The LCD Backlight is prone to going dark eventually and fails progressively, but you can buy a replacement and even instal it yourself.....
We can now supply the LCD Backlight Screen for the Janome Memory Craft MC 8000 and Memory Craft MC 5700.
Keep your old Janome, save money and reduce unnecessary landfill.
It also comes with comprehensive installation instructions from the Original Janome Service Manual which are sent in advance so you can look at the "How to do it" before you decide whether you wish to DIY or enlist the services of a trusted friend or take the LCD Screen and installation instructions to your friendly local technician and have them do it for you.
Here is the LCD Backlight Link
Posted on May 31, 2009
bargainbox
  • 1388 Answers
SOURCE: I have a memory craft 7000. It is about 20 years
Janome Dealers will be able to help you with this.
You can find you local Janome Dealer in the Phone book, or online on the Janome Store Locator Page of your country.
Posted on Aug 02, 2009
  • 1116 Answers
SOURCE: How do I adjust the tension on a Memory Craft 3500
Page 15 of the manual. You can download one here - http://www.janome.com/index.cfm/Machines/Retired/MC3000
Posted on Apr 20, 2010
Zenqi
  • 208 Answers
Most likely it is a step motor failure. It is possible that the A board or the F board has failed. There is a diagnosis chart and service program to run to isolate the problem, but it is complicated and requires explicit knowledge. You could try this: Turn the power off and manually move the needle bar from side to side a dozen times or so then turn the power on. Turn the power on and off several times if necessary, always waiting five seconds between on and off. If this does not work, take it to a Janome dealer (Janome is New Home).
Posted on Nov 15, 2010
How to tighten top thread when it bubbles on bottom of fabric for a Janome Memory Craft 3500 .Book instructions do not help.
there is a manual pdf down load from manualslib.com that explains where the thread tensioner is and how to adjust page 17 of 46 pages
it shows how to thread the machine correctly
the tensioner is a wheel at the top of the machine that turns 0- 6 notches to the left or 0- 6 notches to the right ( 12 possible tensions)
download the manual( free) as it explains probably better than the user manual
it is for your machine
I found it by going google and typing in--how to adjust thread tension on a janome memory craft 3500 and found that manualslib site
May 06, 2016 | Janome Sewing Machines
How do I set bobbin tension?
Generally bobbin tension is the last thing to try to adjust on your machine. Most sewists adjust the bobbin tension ONLY if they are using very lightweight or very heavyweight thread in the bobbin. Most sewists will advise to make all possible adjustments to the top tension before tackling the bobbin tension to resolve issues.
Try searching YouTube videos or this may be helpful:
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Setting the Bobbin Tension on your sewing machine
Liz Kettle adjusting your bobbin case tension 1 wmv
How to fix Tension Don Panic
Sep 27, 2015 | Janome Memory Craft 3000
My memory craft 350e won't keep the tension tight. What can I do to fix this? Please help.
Balancing Thread Tension - Janome MEMORY CRAFT ...
www.manualslib.com > ... > MEMORY CRAFT 4900 QC > User manual
Janome MEMORY CRAFT 4900 QC Manual Online: Balancing Thread ... Auto-threadtension When the thread tension dial is set at AUTO for ... to increase the threadtension. ... Sewing Machine Janome Memory Craft 350e Instruction Book.
Sep 19, 2015 | Sewing Machines
How do I adjust bobbin tension?
Normally the bobbin is not the part that is tensioned. there is a tension device on the top of your machine for tensioning the needle thread.
Dec 17, 2014 | Janome Memory Craft 4000 Sewing Machine
How to time memory craft 7000
your manual should have directions if you don't have please us your search engine on your computer put in model + name+ number + manual + free
Jul 03, 2014 | Janome Memorycraft 6500P Computerized...
Memory Craft 7000 making terriable noise
the machine is showing it doesn't need oiling or the manual says
it's a self oiling machine?
if the machine is self oiling the DON"T oil the machine.
if you think the noise is from the tension dial,, the try using a can of
air or unwaxed dental floss on the tension dial if you have access
to the tension dial.
or the machine may need to be checked to find why it's making the
noise. the machine may just need some adjustments or a tune-up
depending on when the machine has been serviced last.
Dec 12, 2012 | Janome Memory Craft 5700
Janome Memory Craft 7000 Sewing Machine- When I turn the machine on it moves the needle position slightly and message comes up Err 4, then it freezes. Any clues ????
Aug 17, 2008 | Janome Memory Craft 5700
Janome Memor Craft 10001 bobbin tension
There is an adjustment on the side of the black bobbin case.
Remove the needle plate, to gain access to the case. Lift it out, noting how it is positioned! On the side of it , there are two screws, one is the adjustment screw - its the one that sits out more. To increase tension, turn it clockwise 1/8th of a turn, reassemble and test sew. (make sure the top thread tension is back to where it should be). Repeat if required. DO NOT adjust too much at a time!
Good luck
Aug 17, 2007 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
56 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
