Question about Philips Magnavox MT1905B 19" TV
Phillips Magnavox... Large black box on screen... can see image behind screen and hear the audio. black box is in center of screen and covers 2/3 of screen. dont know how to get it off? Same problem - big black box covering half the screen. Happens on random channels, but on some more than others. Can't remove it no matter what I try. How do we fix?
  • 1 more comment
  • lil help Jan 19, 2009
    *There is no closed caption option on any menu to turn on or off, so what now?
  • Anonymous Feb 07, 2009
    i have a philips mag tv with a black box over screen
    i think it closed captions but i cant find how to turn them off
  • bj14090
    bj14090 May 28, 2012
    This worked perfectly...thanks so much
    Sergeant:
  • 280 Answers
You have to use the remote to turn off the closed caption. But I am sure that is the problem
Posted on Apr 10, 2009
Need diagram for replacing heater core
    Detach the heater core hoses at the firewall. The two black hoses attach near the firewall on the passenger's side of the engine compartment. Squeeze the hose clamps on the end of the hoses with pliers and slide the hoses from the heater core tubes.
    • 4Remove the lower passenger's-side and driver's-side dashboard panels. The two panels are held in with push-pins. Raise the center of the push-pins with a small, standard screwdriver and pull the pins from the panels. Pull the panels away from the dashboard to separate them from the dashboard.
    • 5Remove the center console. Separate the gear select trim piece from the center console, using a small standard screwdriver to pry the trim piece from the center console. Lift it over the shift knob and rotate it to clear the knob. Remove the retaining screws holding the center console in place with a Phillips screwdriver. Lift the console up over the shift knob and remove it from the interior.
    • 6Remove the glove box. Open the door to the glove box. Squeeze the two retaining tabs on the ends of the glove box and pull the glove box away from the dashboard. Remove it from the interior.
    • 7Detach the drain tube from the heater core cover, which is located behind the glove box. The tube can be pulled from the heater core cover by hand. Detach the air intake duct from the bottom of the heater core cover. The air intake duct runs from the bottom of the cover to the center of the dashboard. Remove the duct by hand.
    • 8Remove the retaining screws on the black heater core cover with a Phillips screwdriver. Pull the cover from the heater core and remove it from the interior. Remove the heater core clamp screw with a Phillips screwdriver, pull the clamp away from the heater core, then pull the heater core from the housing.
    • 9Place the replacement heater core against the housing. Place the clamp over the heater core and install the clamp retaining screw with a Phillips screwdriver. Position the heater core cover over the heater core and install the retaining screws with a Phillips screwdriver.
    • 10Attach the drain tube and the air intake duct to the heater core cover.
    • 11Install the glove box. Squeeze the retaining tabs on the sides of the glove box and push it into position against the dashboard. Release the tabs when the glove box is in position.
    • 12Install the center console. Guide the console over the shift knob and install the retaining screws with a Phillips screwdriver. Slip the shift selector trim piece over the shift knob and push it into the center console.
    • 13Place the lower passenger's-side and driver's-side dashboard panel in position. Install the push-pins into the retaining holes, pushing the in center of the pin to engage the pins.
    • 14Fill the radiator with coolant. Most climates require a 50/50 mix of DEXCOOL coolant and water. 2.2L engines require 8.6 qts., 2.4L
Nov 22, 2012 | 2000 Oldsmobile Alero
My 2000 e46 bmw heater blower not working, i've checked the fuse
The E46 blower resistor is harder to remove than the E39 .
Open the Glove box.
Remove the three phillips screws across the top of the open box. Remove the two phillip screws that are deeper in on the sides of the open box(nine and three o'clock). Hard to see, use your flashlight. With these five screw removed remove the glove box. Disconnect the flashlight charger plug, and the glove box light connector. Pay attention to the wire routing. Remove plastic cover behind glove box. Locate motor and metal link to one of the a/c doors. Remove the metal arm from the plastic clip. Slide motor out and disconnect. There is an odd shaped black plastic piece with two T-20 or 25 Torx screws that need to be removed.Remove plastic piece. The Final stage is located behind the metal arm for the a/c door.R emove the floor heater duct for more room. You may or may not feel the need. If you wish pull on the leather extension to the center console outward until you hear a loud plastic cracking. Stop. Take a deep breath and know that you have broken nothing important Remove heater duct careful not to break the blend air door cam (white) and the lever connected to it (black).
You can pull that black lever out if you are patient. Back to the final stage now that you have more room. It is the component with the 5 0r 6 large gauge wires on the connector. Push back the black plastic clamp while pulling/wiggling on the connector.
The final stage should come out, then disconnect the connector. Reinstall all. Make sure the heater duct is installed properly if you removed it.
Sep 08, 2009 | 2001 BMW 325
2008 honda pilot cabin air filter
This solution pertains to a 2008 Honda Pilot...To replace the cabin air filter which is located on the passenger side of the vehicle behind the glove box: Open glove box and remove stored items...while sitting in the passenger seat, pull towards you on each of the two clips on the left and right side of the glove box...this will cause them to become loose and the glove box will tip out completely exposing the inside of the dashboard. (Alternately...carefully pull towards you on the top center of the glove box which will cause the left and right side stops to pull away from the edges and allow the glove box to tip out) Here it gets tricky...the box holding the cartridge for the cabin air filter is the large black box on the left side behind the glove box The filter fits in a removable tray vertically inside that box. A pressure clip at the top of the box allows the vertical cover to be removed exposing the tray with the Cabin air filter... BUT!!! There is a plastic bar an inch or so high which has been placed there by the manufacturer to prevent most from changing the filter without the service department being involved. This bar must be cut with a sharp sheetrock knife or hacksaw and discarded, (it will not be reinstalled). Then there is a flat metal bar behind the plastic bar that can be removed using an 8mm socket and a phillips screwdriver. There are 2 8mm screws and one phillips head screw on each side that must be removed in order to remove the metal bar. THEN you can remove the cover to the cabin air filter box, pull out the tray with the filter (note how the filter is in the box so the new one can be placed the same way) reinsert the tray with the new filter and replace the tray cover. All other steps to finish the job are obvious as everything is the reverse. Actually the whole process is a lot of trouble and unless you are determined to change the filter I would recommend not doing it.
Aug 24, 2009 | 2008 Honda Pilot
Bmw e46 heater blower not working
Time to get the blower resistor replaced. Simply carry out the following steps. Open the Glove box. Remove the three phillips screws across the top of the open box. Remove the two phillip screws that are deeper in on the sides of the open box(nine and three o'clock). Hard to see, use your flashlight. With these five screw removed remove the glove box. Disconnect the flashlight charger plug, and the glove box light connector. Pay attention to the wire routing. Remove plastic cover behind glove box. Locate motor and metal link to one of the a/c doors. Remove the metal arm from the plastic clip. Slide motor out and disconnect. There is an odd shaped black plastic piece with two T-20 or 25 Torx screws that need to be removed. Remove plastic piece. The Final stage is located behind the metal arm for the a/c door. I remove the floor heater duct for more room. You may or may not feel the need. If you wish pull on the leather extension to the center console outward until you hear a loud plastic cracking. Stop. Take a deep breath and know that you have broken nothing important Remove heater duct careful not to break the blend air door cam (white) and the lever connected to it (black). You can pull that black lever out if you are patient. Back to the final stage now that you have more room. It is the component with the 5 0r 6 large gauge wires on the connector. Push back the black plastic clamp while pulling/wiggling on the connector. The final stage should come out, then disconnect the connector. Reinstall all. Make sure the heater duct is installed properly if you removed it.
Jul 27, 2009 | Heating & Cooling
Black box taking up over 1/2 the screen.
caption box selection is on. disable caption
Jun 29, 2009 | JVC AV-27530 27" TV
Black screen on EVERY input/channel
Turn off the closed capition
Jun 19, 2009 | JVC AV-27530 27" TV
Magnavox t.v. Model # TS2760 C101 with black box on screen
To fix this problem you need to go to the text probably in
the closed caption or thereabouts. Go to the text highlight it and cut the text OFF
It is very simple to cut the text off...a little practice and persistance and you
will find it.
Mar 09, 2009 | Televison & Video
Magnavox tr3272C103
Maybe the close caption has turn on.,by using your remote press the menu and find the close caption and turn it off .
Oct 03, 2008 | Philips Magnavox 27MS343S 27" TV
A solid black block covers majority of screen - all else works
Try turning off the text box function of the closed caption decoder.
Sep 25, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Philips Magnavox MT1905B 19" TV Logo
507 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
