Question about Kenwood 1080VR Receiver
Denon Dvr-1400 shuts off after 5 seconds
I am just trying it out. I have 2 speakers attached and a cd player.
cd player works but receiver shuts off or goes to standby.
Can you help?
Kris ;-}
  • Kris Mohler
    Kris Mohler Jan 21, 2009
    power suply to my denon recriver is fine,it acts like maybe a short of some kind.
  • Kenwood Master
  • 19,396 Answers
I the receiver shuts off or goes to standby, then there is a short, probably on speakers cable, or on connector cable.
See if you get some problem with different speakers.
Posted on Jan 23, 2009
    Sergeant:
  • 221 Answers
It shuts off due to the ic on the board getting overheated and shorting the board and due to that it shuts off.as it starts properly for couple of minutes or seconds you say but as its ic gets heated it shuts off.
u can get the required ic at
www.radioshack.com
Posted on Jan 21, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Either the speakers are defective / the ohmage is below ratings of the Denon Dvr-1400 or internal fault on the receiver.
Check the specs of the speaker. There would be label at the back nd compare to minimum requirement of the Denon. Additionally, use a VOM/DVM and check resistance/continuity of the speaker/speaker wire.
Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 19, 2009
    Genius:
  • 1,665 Answers
It seems like its power supply is faulty.
    President:
  • 1,990 Answers
Welcome to Fixya! It sounds like the Reciever is getting too hot and shuuting down. Have you checked the Cooling fan inside to see if it is working?
  • Travis Humphries
    Travis Humphries Jan 19, 2009
    Could also be the Power Supply. You need to locate an Authorized Service Center for a Repair of these Problems.
Denon AVR-988 receiver not working surround output when playing movie in my samsung blu ray BD-1400 player
Be sure in the menu setting that the audio analog/digital setting is correct for the blu ray setting. All try the factory reset as stated in owners manual
Feb 18, 2015 | Denon Audio Players & Recorders
Wiring speakers
your main 2 speakers (front left & right)..hopefully the 5th speaker is a subwoofer right if not it will be...the last 2 speakers will be use as the rear (left & right)...in order for this to sound correct the receiver should have a button (5:1) depressed ...otherwise you just have 5 regular speakers...
Jun 24, 2010 | Denon AVR-1400 Receiver
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
I bought a used Denon AVR-1400 without the remote. I am able to control everything from the face except switching to front b speakers. How do I switch to b? I have tried every button on the face and have...
There is no capability to switch to front "B" speakers, the second "front" speaker output allows for bi-wiring a single pair, or running two speakers with identical outputs.
Sep 04, 2009 | Denon AVR-1400 Receiver
Problem getting the best surround sound when watching a dvd
THE BEST SOUND IS WHAT SOUNDS BEST TO YOU, HOWEVER DO THIS:
1, USING THE SETUP MIC CONFIGURE YOUR DENON, PAGE 8 OF THE MANUAL. NEXT
2. RAISE THE REAR SPKR LEVELS, PAGE 46,47. NEXT
3. WHEN LISTENING TO AUDIO CD OR RADIO TRY THE 5 CH STEREO DSP MODE.
4. WHEN WATCHING A DVD USE DSP DOLBY PROLOGIC OR TRY 5CH STEREO IF THE MOVIE IS MOSTLY TALKING.
5, TRY 5CH STEREO WHEN WATCHING PROGRAMS WITH MOSTLY TALKING
Mar 01, 2009 | Denon AVR-2106 Receiver
No dish network sound through denon 1609 receiver
check the setting for the HDMI connection at the Denon you may have to assign the HDMI audio setting also on the front of the Denon while in the DVR mode press the input mode button on the front of the Denon to select auto and if that doesn;t give you sound you will have to connect a cable from the DVR optical.coaxial or analog audio output to the Denon and setup for that type of audio connection
Jan 19, 2009 | Denon AVR588 Receiver
Connecting Denon receiver to DVD player
Normally the optical inputs are disabled unless specifically turned on. I dono't know your specific model. I'll research the model and update this with more specifics.
Dan
Jun 17, 2008 | Denon AVR588 Receiver
Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
May 24, 2008 | Denon AVR-1803 Receiver
"Err" message
i had err 2 screen. removed case (about 10 screws, took just a few minutes) and found 1 disc was had been knocked out of the tray. removed all discs. replaced case. works fine again
Dec 29, 2007 | Denon DCM-280 5-Disc CD Changer
Denon avr-886 VERY FRUSTRATED
Read the manual. You've either got crossed speaker wires, it's overheating, or it's a more serious problem. The same just started happening to mine, so I'm taking it in.
Oct 03, 2007 | Denon AVR-886 Receiver
Kenwood 1080VR Receiver Logo
61 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
