Question about SGI Silicon Graphics Silicon Graphics O2 PC Desktop
Silicon Graphics O2 red and green light flash at turn on
Have swapped all modules except power supply
3 Suggested Answers
SOURCE: My silicon graphics 02 computer power switch is stuck.
POWER SWITCH WENT BAD ORDER A NEW ONE AND RELPCE OR HAVE A LOCAL SHOP DO IT.RICHARDM69
Posted on Mar 10, 2009
SOURCE: how to install os in Silicon Graphics Zx10
warrenvilara
Posted on Feb 02, 2010
I cannot stay connected to internet, my model 2701HG-B 2wire at&t dsl will start flashing red then disconnect me from the internet or my game site, how can i get this to stay fluently connected please!
You might want to try disconnecting everything EXCEPT the power cord. If you still get the red power light (it should stay there forever) then bring the gateway to Radio Shack or somewhere they have a 5 volt DC @ 2 amp power supply and plug it in for 5 to 10 minutes and see if the power light then stays green. If it stays green then all you need is a new power supply! If not, then the gateway is fried. Mine keeps going from a solid green power light to a flashing green power light and I can hear a relay click every 2 minutes at which time a pop-up say "ethernet line disconnected". I tried new power supply etc. to no avail! It is fried after 1.5 years! No more 2wire for me!
Sep 28, 2010 | 2wire 2700HG-B Router (2700HGB)
Computer will not turn on....how do I check to see if power supply is faulty? I have power supply removed and have a tester to check for dc voltage etc
I just went through a heap of troubleshooting with power supply issues before swapping psu's and finding this was the solution to my problem. Had a closer look at my psu that was faulty, the green light was flashing on the psu, unplugged all components and thought that I now had a non-flashing green light on my psu, on closer inspection the light was actually flashing very fast so appeared to be an almost solid light...the psu was stuffed so replaced it and no more issues. If your power supply has a green light check to see if it is flashing when plugged into voltage with nothing connected to it. If it is a solid light then it is probably ok.
Jun 16, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Why cant i get my tv to turn on ?
just worked on one of these, same problem, found a bad capacitor,1000uf 25volt, in power supply module.
Jan 06, 2010 | Proscan 19LA25Q 19 in. LCD Television
The red standby light flashes and when the power button is pushed the green light comes on with a clicking soung then it turns back off and the red standby light starts flashing again
One of the boards (module) has a short on it, and or the power supply itself is failing.
The service center will find the fault using the process if elimination. They will replace the bad boards or modules as required to get the set working again.
Jerry G.
Dec 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tvstopped working, green power light comes on, red light flashing
Most likely it has a power supply module problem. Have it looked at by a qualified service company.
Dec 08, 2009 | Sony Televison & Video
When I push button to turn on, the light flashes orange. Nothing happens, no fan, nothing. It worked fine yesterday.
This usually means a failed power supply and/or failed system board. No way to know further without swapping parts. Power supply is cheaper to replace .
Oct 05, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Power light flashing all 3 colors TV will not turn back on
Sounds like the Power supply module. I would take it in to service center ASAP!
May 21, 2009 | LG 32LC7D Television
Three red lights
Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE: The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION: If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 08, 2008 | Video Game Consoles & Games
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Protron 32
It looks like the power supply failed on your TV. The failure rate is about 95% in the power module.
There aren't service parts available to swap the entire assembly, the only option now will be to fix the power supply to the component level.
Let me know if you need more assistance. You can write to my email address jah2mil@hotmail.com
May 08, 2008 | Protron PLTV-32 Television
SGI Silicon Graphics Silicon Graphics O2 PC Desktop Logo
35 people viewed this question
Top SGI Silicon Graphics Computers & Internet Experts
David Payne
David Payne
Are you a SGI Silicon Graphics Computer and Internet Expert? Answer questions, earn points and help others
