Question about Gateway 2520915 Keyboard
Keyboard beeps when any key is pressed
My keyboard beeps when you press ANY key. If you hold it down it beeps, then it beeps again and types the key, this takes over a second to type each key. This isnt because of a slow repeating rate either, and I've unplugged it multliple times or tried restarting the computer. I currently am having the problem on my gateway computer which uses Microsoft Windows XP SP2. Please help and thank you.
  • 1 more comment
  • we2chaps Aug 12, 2008
    was wooking unpluged when moving now it just beeps on any key
  • gregr906 Dec 14, 2008
    i have the same problem on screen keyboard works, but ps2 and usb keyboards wont work. the only way it will work is in bios and if you hold the key down for a few secs then it will type it
  • brigittevg Feb 20, 2009
    The keyboard doesn't work, the PC beeps when pressing a key. Only the on screen keyboard works. I have created several user accounts on this PC, and the problems only occur with ONE of the user accounts.
    So this is definitely no hardware problem.
I found out what was wrong in my case. Someone had tampered with the accessibility options
So for anyone with keyboard problem check :
In Windows XP : control panel-> accessibility options -> keyboard : StickyKeys and Filterkeys checkboxes should be unchecked.
In Windows Vista : Ease of access -> Ease of access center -> keyboard : StickyKeys and Filterkeys checkboxes should be unchecked.
Posted on Feb 23, 2009
Sooooooolvvvvvved
BEST REGARDES
ANY QUESTION ABOUT ANY PROBLEM CONTUCT ME ON
MAGIC-2005@HOTMAIL.COM
Posted on Jan 04, 2010
Hold your shift key down for 10 seconds and it will reset your keyboard. It might happen again and just repeat the process and it will reset again. This definately works.
Posted on Oct 01, 2011
    Novelist:
  • 114 Answers
HAVE YOU TRIED ANOTHER KEYBOARD? TRY YOUR ON SCREEN KEYBOARD UNDER "ALL PROGRAMS" "ACESSORIES" THEN "ACCESABILITY" CLICK ON "ON-SCREEN KEYBOARD. IF THE ON-SCREEN KEY BOARD WORKS YOUR KEYBOARD IS BAD.
Posted on Jun 25, 2007
I have the same problem as the one above, and can say at once that plugging in another keyboard will not work. My on-screen keyboard does indeed work, but it's not related to a bad keyboard. My keyboard works during BIOS and boot-up, so something tells me there's something wrong with windows.
Try a Windows -> Run -> sfc /scannow
See if it detects any errors there.
Posted on Oct 15, 2007
2 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: Keyboard beeps when any key is pressed
The reason these beeps are happening is because there might be a key that is slightly depressed enough to where its registering keystrokes. Move your fingers all over the keyboard and see if you the beeps stop after you do that. If it still is going on then that means your keyboard is bad and will need to be replaced.
Posted on Jun 12, 2009
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Turning off my green keys on HP pavilion desktop keyboard?
    How to turn off Sticky Keys: disable the Ease of Access feature
    Tip: use the Windows Ease of Access Center
    How to turn off Sticky Keys: what are Sticky Keys and why turn them off?
    Sticky Keys is a Windows Ease of Access feature that makes it possible to use keyboard shortcuts or type capital letters without needing to press more than one key at once. Normally, you'd hold down the Shift key while pressing a letter to type a capital, or hold down the Ctrl key while pressing 'S' to save a document. It's even trickier if you want to use a shortcut such as Ctrl-Alt-Del or Ctrl-Shift-Esc.
    With Sticky Keys, you can press Ctrl, Shift or Alt, let go and then press another key - Windows will interpret this as pressing two keys together. You should also hear a beep if you have speakers connected.
    That's great if you're disabled and can't press two keys at once, but what if you want to disable Sticky Keys?
    How to turn off Sticky Keys in Windows 8
    You can't press Shift another five times. Instead, you need to bring up the Start menu (or Start screen in Windows 8) by pressing the Windows key. Now type "ease of access" and click on Ease of Access in the list of results.
    If you're using Windows 8, you need to click on the Ease of Access Keyboard settings result, and then it's a simple case of sliding the Sticky Keys toggle to 'off'.
    If this does not help you. Let us know the below details to understand the issue bettery.
    What is the OS?
    What do you mean by hot keys? ex.......
    Rgds,
    Divya
    Sep 02, 2012 | HP (395366-001) Keyboard
    I got windows loaded but keyboard is locked. i can't type anything.
    perform the following on the keyboard
    1. On the keyboard press the windows logo (image below)
    2. keep holding the windows key whiles you press the key U key in addition
    3. You should have a list of options.............choose on screen keyboard and with your mouse you can login and keep using your pc without a physical mouse.
    Aug 04, 2011 | Compaq Computers & Internet
    How do I type a capital O with a line through it?
    On Microsoft Windows, using the "United States-International" keyboard setting, it can be typed by holding down the Alt-Gr key and pressing "L". It can also be typed under any keyboard setting by holding down the [Alt] key while typing 0216 or 0248 on the numeric keypad
    Apr 04, 2011 | HP P2360AA Keyboard/Mouse
    Unlock numeric key pad on lap top
    your laptop should have a blue FN key (Function) that will work in conjunction with other blue keys on teh keyboard. most laptops this is located in the lower left, next to the ctrl key. Look to the right top on your keyboard for a one labeled numlk. hold down teh left FN key and tap the right num lk key and you just turned off the numbers lock.
    There is another option that is a little more intense - if interested let me know that laptop type you have.
    Feb 04, 2010 | Microsoft Windows XP Professional
    Key board problem
    Try to press Fn key, hold it down and press the Numlock key.
    Jan 16, 2010 | Velocity Micro NoteMagix x30 Laptop
    May 28, 2009 | Gateway 2520915 Keyboard
    Keyboard stuck in upper case
    press caps lock and F9 together see if that fixes it
    May 06, 2008 | Microsoft Windows XP Home Edition
    ASUS keyboard
    u have problem with ur key board remove the dust in the key board its not problem with ur computer its a just ur keyboard
    Oct 18, 2007 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
    Gateway 2520915 Keyboard Logo
    22,394 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
