Question about John Deere Replacement Hydrostatic Transmission Lt150, Lt160, Lt170, Lt180
Where do i find the fuse box on a john deere LT16 lawn tractor
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
farmerbear
  • 490 Answers
SOURCE: need mower deck belt diagram for L-130 John Deere
I have found the manual at JD's website. Click the link and scroll down in the left column until you find the heading for replacing the belt. I contains big, clear photos. Here is the link:
http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO
You can copy it into your browser window or type it in. I sure hope this helps you out. If I can be of any further assistance, please let me know:)
Posted on Aug 21, 2010
daneinwv
  • 124 Answers
SOURCE: How do I adjust valve rods and what's the
Hi I'm Dane, and I'm going to help you solve you problem. Glad to finally get this answered for you. The piston should be set to top dead center on the compression stroke. Adjust the valves when cold to .004 Intake and .006 Exhaust. Torque spec is 61" lb .If you found this reply helpful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Posted on Dec 06, 2010
  • 10865 Answers
SOURCE: My John Deere 318 lawn
hello hird... you may have a gummed up carburator. get a can of starter fluid. get a helper. remove the air cleaner. start it up and leave it in neutral while your helper squirts starter fluid into the air intake for a minute. repeat if necessary until it no longer dies in gear.
if after 3 attempts check your mower deck as a frozen pulley wheel can cause this problem also. joe
Posted on May 15, 2011
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
Where is the fuse located in the John Deere GT275?
Replacing Fuse
1. Lift hood.
M88565
2. Pull defective fuse (A) out of socket.
3. Check metal clip in fuse window and discard fuse if clip
is broken.
4. Push new fuse into socket.
5. Lower hood.
May 20, 2012 | John Deere Garden
Manual for a 1988 s82 john deere lawn tractor
Where the fuse box on a john deere s82
Feb 28, 2012 | Garden
Sabre lawn tractor 1438 gear manual
John Deere Sabre 1438, 1542, 1642, 1646 Lawn Tractor Service Technical Manual TM-GX10238 * - Download Documents / eBooks
hello arthur, john deere does not post manuals on line,this is all i could find or see your local dealer,hope this helps..
Feb 18, 2012 | John Deere Garden
ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
Oct 02, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Aug 10, 2009 | John Deere Mower Blade 5 each
Apr 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Replacement Hydrostatic Transmission Lt150, Lt160, Lt170, Lt180 Logo
168 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
