Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster 1/2 HP opens on its own
I have a 6 month old unit that seems to have a ghost. I have come back from some trips to the store to find my garage door open to the world. At first i just assumed it didnt close fully and reversed when I left so I have become diligent now about watching the door close completely. Today I came back after a 2 hour trip and it was open again and I definitely saw it close, as did my passenger. Any ideas how this can be happening. I thought these new remotes have zillions of codes that reprogram themselves so theres no possibibility of a neighbor with the same code?
  • 2 more comments
  • srdiamond Jan 19, 2009
    My remote is the 373LM which is listed as a 315mhz. Is that good or bad? I only have 1 remote and it stays on my visor so no way it gets pushed accidentally. Plus if it was stuck i would see it opening when I pull away - I literally sit and watch the door shut every time as I have for the last few months so I would see if it opened right away.
    I would say once every month or two I notice it. What are the red wires at the motor and should I permanently disconnect them or just temp?
  • petey007 Feb 01, 2009
    when I press my keypad the motor run but the chain does not travel the product is liftmaster profesional line
  • Vince Heuser May 11, 2010
    Do the remotes run on 390mhz or 315 mhz? It should be in the owners manual
    Champion:
  • 244 Answers
5 nonth ols ia 315. wjere are remotes. on car seat? are pushbutton stuck. try disconnecting wire to each pushbutton or console. see if problem goes away. you have 100 billion codes
Posted on Jan 19, 2009
  • marty metzger Jan 19, 2009
    try disconnecting red wires at motor. how often this happening.
    they goes to pushbuttons and wall control. if you have push-on terminals, just remove and leave out. wouldn;t hurt. see if problem stops (That is why i asked for frequency).
Compatible garage door opener
Change out all the track. It is not a difficult job, and the tracks will line up. If you are talking about the rail that the chun runs just throw the old opener away and use the parts thet are it the box, You may damage new unit trying to install old rail, aqnd there is no warranty or exchanges for owner cause damage.
May 14, 2017 | Building Materials
1/3 hp liftmaster pro goes up 1 ft and then closes, need to press a couple of times to work.
After checking all the door parts; alignment, missing nuts and finally adjusting the spring we found a defect in the door opener (new replacement). There's a speed sensor that was hitting the cover and this was causing the door to go up or down only to a certain point. Sometimes it would stop and other times it would totally reverse. I made a small adjustment to the speed sensor and voila it's been working since. Now if I can get the wireless click pad to work I'll be back to the norm. Look online for a schematic if you don't know what the speed sensor looks like. These companies also sell just the parts if you want to repair your old opener. I hope this cures your problem.
Dec 29, 2012 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but door won't open. checked chain, seems to be ok
The problem is not the chain, it is the plastic gear in the unit of the liftmaster Garage Door 1/2 Hp.The plastic gear is not engaging, although it sounds like it is working.
You will have to replace it with a new one, then the liftmaster Garage Door 1/2 Hp will be able to open up once again.
Once you open and remove the old gear, Be sure to thread the screws in all the parts before you install them. Pre-threading them once would really help. Secondly, label the wires on the back of the opener before lowering it to the ladder, so you can put them back in their proper place.
Hope this was helpful.
Goodluck
Elect_Comp
Jun 27, 2011 | liftmaster Garage Door 1/2 Hp
White ghost screen only 1/1/2 years old started going to white screen occasionally at 6 months old just for a few seconds now gives only white ghost picture.
It can be the ribbon cable on the T-CON board is looseor it is not getting 5vdc from the logic board to feed the T-CON board.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
You will need to open it up and take a look inside. It may be still under warranty.
Service manual:
http://elektrotanya.com/?q=showresult&megnev=SAMSUNG megnev2% 20 & = & Category = & LN32A450 kat2 = all
Jun 06, 2010 | Samsung LN32A450 LCD Monitor
I have an old craftsman 1/2 hp door opener. It
You may have a bad wall control. Try disconnecting it from the opener and try. Otherwise it is time for a new model.
Apr 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door openly opens 5-6 in, then stops.
If the door isn't unusually heavy when you open it manually then maybe an adjustment will help. On the back of the motor unit you will find the 'up force' control. Increase it 1/4 turn and try.
Jun 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Electrical problem with logic board or terminal block
do you see burn mark on board? Is so and unit is older than 15 years, buy new one.
Feb 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
177 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
