Question about Kenwood KDC348U
My kenwood 348 u has been doing fine till now, when i use my auxilary chord it wont play but the speakers on the drivers side and it wont play the amps running my mids and highs. just all of a sudden happened and its a brand new monster cable, what is up?
  • 14 Answers
SOURCE: Kenwood kdc-mp528 amp/speaker problem???
This is a common mistake. This problem indicates that you are using the solid blue wire from the head unit to the remote turn-on on the amp. This is a power antenna wire that only receives power when on FM radio. You need to replace this with the Blue & White wire from the head unit (power control wire) to your remote turn-on on your amp. This should solve your issue.
Posted on May 12, 2007
doin12volt
  • 233 Answers
SOURCE: kenwood deck reads protect and won't function
you have one of your speaker wires shorted out to the body of the car somewhere, or the speakers that you installed are bad. That is the only two reasons it will go into protect. Correct the problem, then reset the deck - it should work fine.
Kenwood builds this feature in to protect the outputs - so they dont burn up in the case of shorted speakers or wiring.
Posted on Jan 17, 2009
SOURCE: Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Posted on Jan 28, 2009
SOURCE: New speakers are fuzzy
If it is an older vehicle you could have interference from the ignition system. You can wire the radio to be powered up from a toggle switch that get its power straight from the battery, with a fuse between the battery and switch of course. This will eliminate powering up the radio with the ignition switch and take the ignition system out of it. Also need to make sure the ground wire is grounded good and the ground wire is the same wire guage if not larger than the power wire.
Posted on Sep 28, 2009
  • 239 Answers
SOURCE: receiver keeps chiping in and
yes it is a power problem check all of your earths and try put the cap in pls vote thumbs up
Posted on Aug 12, 2010
Kenwood how to connect
You need a stereo mini to RCA cable to connect the laptop's headphone audio jack to the Kenwood. Here is an example of one below. They are very common and available at just about any electronics store for a few bucks.
http://www.amazon.com/Gemini-PH62089-Stereo-Mini-Male-RCA-Male/dp/B0001GAOE0
The Kenwood receiver should have a number of red and white "RCA" audio connectors on the back.
Just connect the RCA portion of the cable to a spare input. They should be clearly marked on the back of the unit and color coded (red for right channel and white for left channel). But it really doesn't matter if you mix the right and left up, it will still make sound.
EX:
Most receivers will have inputs that are labeled "CD" or "Aux" that you can connect any audio source to.
If you connect your laptop or an MP3 player to the audio input connections labeled "CD" behind the Kenwood receiver, you can listen to the device by selecting the CD as the source.
It is really easy!
May 04, 2014 | Kenwood VR-305
I dont get any sound radio,sirris,or cd
Is there something new that was installed or modified in your car recently, even if it's not related to electronics? (even trailer hitches, running board, etc)
Have you checked if there was a ground leak at each speakers?
Are you using an amplifier other than the one in your kenwood reciever?
May 29, 2013 | Kenwood KDC-MPV622 CD Player
I need a manual for a kenwood dpx-6100md. I want to work out if I can plug in an auxilary cable.
There is an adapter for some kenwood models, CA-C1AUX adaptorat the back of HU you will find a female port to plug the adaptor,you can also make your own adaptor, visit:
http://www.pakwheels.com/forums/d-i-y-projects/22718-diy-kenwood-headunit-aux-adaptor
Jul 10, 2011 | Car Audio & Video
Is a kenwood kdc 135 have a aux. for ipod capability
Look on the back to see if there is an auxilary socket plus on the front of the unit, is there an aux button to allow an input from an auxilary device. If you dont have a manual I would go to Kenwoods web site and enter in the model and see if you can download a user manual.
Jul 25, 2010 | Kenwood KDC-135 CD Player
How do you get it in auxilary mode
if you have a device (iPod etc) plugged into the front aux hole, and playing, you hit the SRC button until you get to the auxilary function.
Apr 10, 2010 | Kenwood KDC-135 CD Player
Cant get radio into aux mode so i can play mp3 player directions in manual arent clear on how to get radio in auxilary mode
Hello luvbetty4eve,
Without knowing exactly what make and model of receiver you have, it's not possible to provide specific instructions. But for most receivers, both stock and aftermarket, there is a "source" button sometimes shown as "SRC". To change from one source to the next, you simply press the button repeatedly until the display shows the one you want, in this case usually "AUX".
Jun 25, 2009 | Kenwood Car Audio & Video
Unit on standby
Hello Tim-----your radio has menu options that can be changed- one of these turns on your aux port. to access this GO TO www.kenwoodusa.com on the top of the page click on support then on the left side of the page click on user manuals now on the right side of the page type in k and then scroll down until you get to your model (kdc135) -----on pages 12-13 you will see the instructions to turn on the auxilary mode. If you have any problem drop me an E-Mail at merle840@aol.com
Good luck
Merle
Sep 30, 2008 | Kenwood KDC-135 CD Player
KENWOOD KDC-MP335
Yes, you can. It took me almost a month and about 70 dollars wasted to lfigure it out though. All you need is the the audio jack. Its a simple chord that runs to your aux jack in the back of your head unit. MAKE SURE YOU HAVE ACTIVATED THE AUXILLARY CONTROLS ON THE CD PLAYER. YOU DO THIS FROM THE MENU SCREEN. The chord cost like five dollars at wal-mart.
Aug 10, 2008 | Kenwood KDC-MP335 CD Player
Garbled sound
Your Codec is damaged. Reload your drivers for your sound card. First uninstall the old ones. Moving your non working speakers and they play fine says they are good. I have a problem that you have new speakers and the problem went away. Drivers do not care what speakers are on the other end. It only produces output. Now that your second pair is working correctly, put back the Harmons and see if the problem comes back
Mike
Apr 23, 2008 | Harman Kardon SoundSticks II Computer...
Help
hmm... can you scan tracks up and down?are you running it via extrenal amps or useing the speaker outputs from the radio?
Mark
Mar 07, 2008 | Kenwood KDC-X659 CD Player
Kenwood KDC348U Logo
24 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
