Question about Panasonic Lumix DMC-FZ28 Digital Camera
Camera does not turn on; on switch engaged, battery charged, memory card in place.  Camera worked a few minutes ago; I have been turning it off and on while learning to use the controls.
  • gcbrown246 Jan 19, 2009
    Thanks, Fowler, for your response -- it didn't work, though.  ~ cb
  • gcbrown246 Jan 20, 2009
    Regarding my Lumix FZ28 that wouldn't turn on:  the problem was that I thought a green light on the charger meant that the charging was completed.  Reading the manual, a green light means that the camera is being charged.  So I wasn't charging the battery adequately.  Live & Learn!
  • 119 Answers
Take the battery out and leave it out for twenty seconds..then try again
Posted on Jan 19, 2009
  • Shane Fowler
    Shane Fowler Jan 19, 2009
    put it in the freezer in a plastic bag for 20 minutes..it can correct overheating problems
My Nikon D3100 will not turn on. Is there something wrong with the batteries/memory card? Or rather the camera body itself?
It could be either the battery or the camera.
If you have a second battery, try it. If it works with the second battery then the first battery is bad.
If you don't have a second battery, take your camera and battery to a good photo store. They should have a second battery to try. You might be able to test your battery with one of theirs. This will tell you whether the battery or the camera is bad.
Oct 04, 2016 | Nikon D3100 Digital Camera
Samsung le19a656a has sound but no picture ? has picture sometimes for a minute or so when turned on and off
Just switching off and on is not enough. You could try one step further. After switching off, remove the battery and memory card for a little while just a few seconds should be enough.
To make sure the memory card is still working, put it in an external memory card reader and look on the computer you still have pictures on it. If the card gives an error in the computer, try recover software, to retrieve your pictures. If the card looks ok, replace the memory card and the battery and switch on again.
But also make sure the battery is charged.
If after this still the same error occurs you should visit a repair centre, or start saving for a new camera.
Jun 10, 2014 | Samsung S860 Digital Camera
Unable turn on canon 60D i was reviewing the photo
Remove the battery and memory card, switch the power switch on for a few seconds and then switch it off. Make sure the battery is fully charged, re-insert the battery and try to switch on again without the memory card in.
Oct 24, 2013 | Canon EOS 60D Digital Camera
Took a few photos, switch off, 5 minutes later switched back on, blank screen but can view playback and menus
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Jun 10, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Never used it. Turn on the camera and it says
1. Ensure batteries are fully charged.
After all this if its not work then the lens guide pin is damaged & replacing the lens is the solution of your problem.
May 19, 2010 | Nikon Coolpix 4600 Digital Camera
My Kodak Z650 camera just won't switch ON. I used the camera a few weeks ago and it was working fine and after using it, I removed the battery and packed it away for next use. The next time i tried using...
Hi there Make sure the new batteries are fully charged before used. After that remove the memory card & try to power on. If its not ON then i suggest you remove the battery & check the that place for any sulfur layer( green colored ) are there or not. Just clean that place & put the camera in sun light for 10 minutes. Because some time moisture make short the circuit board & that's why camera would not turn on. If its a moisture problem then after those operation it will start working. But if your camera power supply converter are damaged then its not possible to repair at home. So go for all these basic treatment & after that if you not success then i suggest you please visit Kodak service center for replacement or repair. Thanks.
Apr 02, 2010 | Kodak EasyShare Z650 Digital Camera
My m863 kodak camera charging light won't turn on.
Is the camera charging? Remember when charging thought the computer NOT to switch the camera on since this will deactivate the model to charge. Try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak EasyShare M863 Digital Camera
My kodak easyshare V1003 camera will not turn on. It worked a few days ago and now it will not charge or turn on. I just bought new batteries and it still will not turn on. Any suggestions on how to fix...
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 09, 2009 | Kodak EasyShare V1003 Digital Camera
My camera turns off right after i turn it on. it
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Here are the steps:
3. Without the memory card,turn on your camera.
Unfortunantly KODAK do no longer repair this model. They offer a Trade up option where you for 25-30% cheaper than the listed price can exchange the camera to any newer model provided KODAK has the model in stock.
Contact KODAK:
Nov 24, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
Camera won't turn on
Battery Condition! Battery Contacts! Memory card in place. Check all and come back
Sep 05, 2007 | Nikon Coolpix 4600 Digital Camera
Panasonic Lumix DMC-FZ28 Digital Camera Logo
71 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
