Question about Canon GL1 Mini DV Digital Camcorder
Editing Canon GL1 Mini DV Digital video in Final Cut Pro x
SOURCE: Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Posted on Dec 04, 2007
MrsJGreen
  • 130 Answers
SOURCE: software for the canon zr300 mini dv digital camcorder
You will likely have to order this through Canon.
Posted on May 30, 2008
  • 39 Answers
SOURCE: I can't upload video from my Canon GL1
first off make sure you are positively connected to computer via usb. then make sure your drivers are updated. then see if it connects. also note that your camera screen may say "would you like to connect to usb port?" make sure if that does appear that you hit yes. best of luck!
Posted on Feb 17, 2010
SOURCE: My Mac does not recognize my Canon HV 30 DV when i connect the FireWire.
I've been around the block with this for days, including a fresh installation of the software on my MacBook Pro. Sigh.
Here's what seemed to work:
1) Reset Vixia HV30 (tiny reset button behind the battery). Did not change any settings on the camera after that.
2) Installed Canon's software that dropped some canon-related files in Library/Quicktime folder.
3) Opened new iMovie 6.0.3 and Final Cut Express HD 3.5.1 projects (a) FCE (using Easy Setup in FCE) to Apple Intermediate Codec 1080i60 (b) iMovie 'HDV 1080i'.
4) Connected 4-pin --> 6-pin firewire cable out of the camera to a bus-powered external drive and from the drive, firewire 800 --> firewire 800 --> MacBook Pro 10.5.8.
This was a last-ditch, Hail Mary effort. It worked, and the camera showed up in the System Profiler firewire window, too, whereas it had not before all of the above. Still does not show up when hooked directly from the camera to the FW 800 input, but at least I can capture now.
Posted on Feb 20, 2010
  • 12 Answers
SOURCE: Canon ZR300 Mini DV Digital Camcorder THE MINI DV
I know this is going to sound strange. I had the same issue with my ZR300. When you insert a tape and close the mechinism you hear the tape whirl then it pops open and chimes. I found a solution online and thought it was to good to be true. It said to hold the camcorder in your left hand with the right side up (the opposite side of the fold out viewer). You then hit the camcorder , not real hard like slapping something. Open the door and insert the tape and WHAM! It loaded fine. Eight people had tried it according to the review and all eight people had success. I was skeptical but it works! Don't hit it so hard you break it. I did mine twice before it worked but it works everytime now. Trust me just try it and it will work.
Posted on Nov 16, 2010
Testimonial: "AMAZING IT WORKS!!! TAPE IS IN AND I'M RECORDING GREAT!!! THANK YOU."
I get digital video breakup and no sound on playback on my Canon Gl1.
Buy a cleaning cassette. Read it's instructions before using it.
Jul 05, 2011 | Canon GL1 Mini DV Digital Camcorder
Tip
How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut...
How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Final Cut Pro is a professional and all in one video editing, compositing and special effects package for the Macintosh. The software logs and captures video onto a hard drive (internal or external), where it can be edited and processed.
If you are a Kodak video fan and you want to give professional editing to your Kodak videos, Final Cut Pro is the best choice for you. However, Final Cut Pro can edit any QuickTime compatible file format including DV, HDV, MOV, MPEG-4. That is to say, in order to edit your Kodak video with Final Cut Pro, you have to convert Kodak videos to the supported formats by Final Cut Pro with Kodak video to Final Cut Pro Converter for Mac.
Tips:
Kodak records the video files with mov files (i.e. Quicktime files) does not mean they are perfect for editing in FCP. The fact is, all of the small video cams, including the Kodak Zi8 Cams, records highly compressed codecs that are known as delivery codecs, not editing codecs. You need one third-party software to convert HD mov files to some formats like DV, HDV , MPEG-4 that FCP is happy to edit.
Kodak video to Final Cut Pro Converter for Mac is one simple-to-use solution with the minimum amount of buttons and a small menu for converting Kodak video (Kodak Zx1, Kodak zi6, Kodak Zi8 and Kodak PLAYSPORT) to DV, HDV, MPEG-4, etc., for importing Kodak videos to Final Cut Pro. Besides, it is also an easy-to-use editing tool that assist you for making personalized video. You can trim the video to a certain length to convert, adjust video aspect ration by using crop function, add special effect like Gray, Emboss, Old film into video to make it more artistic, join several files or set the video output parameters. All this can be done with a few mouse clicks.
Part one: How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Step 1:Free download and install Mac Kodak video to Final Cut Pro Converter
Download Kodak Video to Final Cut Pro Converter For Mac and double click the downloaded . dmg files to install. A user-friendly interface will pop up.
Step 2:Load Kodak video files
First: Connect Kodak camcorder to computer and transfer mov files to iMac, Mac book.
Second: Hit the File button on the top left panel or click "Add Video" button to select Kodak MOV files to this converter.
Step 3:Select the output format and destination
Click the downward arrow beside Settings to choose the proper Final Cut Pro format from the drop-down list. And then click Browse button to specify the output location.
Tips: Select DV, HDV or MOV format for FCP in the pull-up list next to Profile field. And then click Browse button to specify the output location.
Step 4:Start the conversion
After all the necessary setting has been done, hit the "Start" button to start converting. Click the Open button to select the converted DV, HDV files to Final Cut Pro for further editing upon completion.
Part Two: Import Kodak videos to Final Cut Pro and edit Kodak video in Final Cut Pro.
Step 1:Import Kodak videos to Final Cut Pro
Launch Final Cut Pro and click "Import"-"Files" and then select the converted Kodak files. Find the file in the resources list for the project and drag the file into the Timeline, and then save the project.
Step 2:Edit Kodak video in Final Cut Pro
Apple's Final Cut Pro Software is an all in one video editing, compositing, and special effects package for the Macintosh. The following steps will show you how to use the Timeline:
One: Edit video and audio timing
There are three tracks on the Timeline, one for video and the other two for audio. And you can cut the video and audio tracks all at once in the same place.
Choose the razor blade tool in your menu, and click the times that you want to split it. You can also set input and output times on the Viewer window. Final Cut Pro also allows you to layer video tracks on top of each other.
Two: Add transitions
For Kodak videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions.
Three: Export video
Once you are finished with editing your video, click on File and point to Export, then you will see a list of options of how you can export the edited file. For example, if you want to publish your video to the web, you can click on "Export using QuickTime Conversion". When you see the naming dialog box, input the name you prefer and at the bottom, select "MPEG-4" at the bottom, and then select "Broadband-High" under the format setting. And now click on Save.
on Sep 17, 2010 | Computers & Internet
Canon GL1 message to eject tape... I want to transfer it to puter. any suggestions?
Canon GL1 was working fine last night,now it want do ANYTHING today,want power up or anything,want even eject tape when I push eject button. Any suggestions?
Jun 25, 2010 | Canon GL1 Mini DV Digital Camcorder
GREY BANNED OUTPUT
It is symptom of dirty / clogged video head.
Please use good quality mini-dv video head cleaning tape to clean head. Problem will be resolved.
Mar 16, 2009 | Canon ZR850 Mini DV Digital Camcorder
Clean lens
A can of air might get it!
Dec 09, 2008 | Canon GL1 Mini DV Digital Camcorder
How do i connect my canon GL1 to My desktop computer?
Do you have a firewire cable? You should be able to use Windows Movie Maker to import footage as long as you have it connected via firewire.
Hope this helps!
May 25, 2008 | Canon GL1 Mini DV Digital Camcorder
Importing video from Xl1 canon into my Mac
you must use the third party software convert your video files format to final cut express support formats.such as dv,mp4,mov
if your video files is .tod format,you can use tod to final cut express converter.
http://www.fceconverter.com/tod-to-final-cut-express/
if it's .mod files format, you can use mod to final cut express converter
http://www.fceconverter.com/mod-to-final-cut-express/
Mar 27, 2008 | Sony Handycam DCR-TRV18 Mini DV Digital...
Canon
You don't actaully need the camera. If the DVD is not copyrighted simply put the DVD disc into your mac and copy the biggrest file (usually marked video.ts) You can then drag and drop this onto your Final Cut timeline.
Dec 24, 2007 | Canon XH A1 Mini DV Digital Camcorder
Rec video
Is the tape locked? Make sure the tape is not switched into protective mode.
Hope this helps!
Dec 21, 2007 | Canon GL1 Mini DV Digital Camcorder
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Canon GL1 Mini DV Digital Camcorder Logo
100 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
