Question about Toshiba e-Studio 350 Copier
Installation of e-studio 350
Here is my problem. I have e-studio 350 copier. I tried to install the proper driver from Toshiba website on my computer and I was not successful. My laptop is Dell Inspiration 1545 and I am using Vista 64. The copier worked well with my previous laptop (HP, Vista 32). It looks that that the installation of the dirver was correct but in fact the printer was not installed. There is no printer installed in the Control Panel>Printers. However, I can use the copier as a scanner and it works, but not as a printer.
  • Toshiba Master
  • 653 Answers
U need to confirm the driver support Vista 64bit.
U can obtain the driver at:
http://www.copiers.toshiba.com/support/controllers/ebridge350-450.shtml
Posted on Feb 13, 2009
How to install operating system in toshiba copier e studio 520
Firmware is prepiortority so you must have access to the Toshiba website which normally only tech have, Now drivers are different if drivers you need go to Toshiba web site down load required drivers Toshiba STUDIO 520 523 600 623 720 723 850 853 Service Manual free...
Oct 27, 2015 | Toshiba Office Equipment & Supplies
Copier wants me to install new black toner cartridge after I installed new one.
for e-studio 350 check if the developer tank unit auger broken or harden with moistered toner hope will lead u to the solution
Mar 03, 2014 | Toshiba e-Studio 350 Copier
I am getting white page when ever i try to print from my Toshiba e-studio 350. Installed drivers 3 times.
There are more solution
1. Primary or main chargers cable must be disconnect.
2. Tranfer charger ......
3. H.B.T. (High Voltage problem)
4. Transfer charger Connector is out of work, that means lickage, broken ...
Cheak this I think Thats the real problem, You can solve that by fixing the TR by any kind of glue, I think u can understand what u have to do so .....
100% confidental and this case You can see the error code C970.
Thanks
Jul 03, 2010 | Toshiba e-Studio 350 Copier
Toshiba e-Studio 350 - How to Print?
Did u install printer kit? It looks like a mini thumb drive, hooked to usb port?
Mar 07, 2010 | Toshiba e-Studio 350 Copier
Problem with Toshiba e-studio 280- need vista 64 bit driver
You update your copier driver for 64 bit windows suppoted.www.toshiba studio 161.com
Mar 11, 2009 | Toshiba e-Studio 161 Copier Copier
Compatability issues with Toshiba e-studio 350 copier and Windows Vista
This copier must have the latest firmware installed, a print enabler and you must have the latest print driver in order for Vista to be supported. All of this is available from a certified Toshiba dealer. Also, you can check to see if the copier is working by inserting the Cat5 cable to the copier from your network and typing in the IP address (found under the Administrator tab on the touch panel of the copier) into the URL bar of your browser. A web page will pop up showing the machine is active.
Oct 21, 2008 | Toshiba e-Studio 350 Copier
Hard Drive error No. F105
F105 is "other HDD error" . Start the copier holding 0 and 8, it goes in a test mode, then punch 690 and presss start key. Restart the copier. If does not work you might have to replace the HDD and reinstall the firmware. Let me know.
Dec 30, 2007 | Toshiba e-Studio 350 Copier
Unsolved fault
check all your paper cassettes and make sure the paper isnt jammed in there or that it is installed properly
Jun 19, 2007 | Toshiba e-Studio 350 Copier
Toshiba e-Studio 350 Copier Logo
551 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
