Question about Sanyo DP46848 LCD TV
Wanting to replace my sanyo dp46848 lamp, it burnt out.
Lamp burnt out just trying to see what it would cost to replace and how easy it would be...
  • 4 Answers
SOURCE: MULTIMEDIA PROJECTOR
I have a Sanyo XU35. Mine was starting up and showed a picture for about 15 - 30 seconds then shutting down. My lamp warning light was not coming on. When I put it in for repairs it turned out to be the lamp that needed replacing. The technician said it is not uncomman for the lamp to be going and the lamp warning light not to come on. I got my lamp on e-bay from ping_ngo for a great price.
Posted on Oct 02, 2007
SOURCE: lamp replacement
I had this issue.  Turned out the thermal switch was tripped and just needed to be reset. (The usual disclaimer: This procedure will void your warranty and is entirely at your own risk) Remove the six screws marked with arrows to open the top (be careful as there are still wires connecting the top to the bottom.  The thermal switch is directly over the bulb assembly and connects to the main board with two thin wires (grey and white on my Z4).  You can check the switch with a multi-meter.  Normally the two wires should be shorted, if there's no continuity it's tripped.  When it trips a small plastic pin painted white on top pops up, just press it back down and you should be good to go.  (It's a good idea to clean your filters, and check the projector ventilation after to ensure it doesn't get tripped again)
Posted on Jan 18, 2008
SOURCE: sanyo plc se15 no light output
i all,hoping you can help with my problem.Ihave been given a sanyo plc se15 projectoe but with no lamp originally,the "lamp"indicator and "lamp replace indicator"were originally lit but when i have installed a new(23hrs use previously) lamp i have no light output and these 2 indicators are still lit! what voltage should i have on the lamp terminals(i a fully qualified electrician btw) is there some sort of reset procedure as i dont have any instructions etc
thanks in advance for any help
Posted on Mar 22, 2008
  • 3 Answers
SOURCE: Sanyo PLC - Z5 Lamp Replacement Light
Just had the same problem. Based on other suggestions on here I tried resetting the overheat switch, and IT WORKED!
So, you have to pull the 6 screws (one of them is shorter than the rest, remember where it goes) that hold the top on the projector. 3 are on the back, 3 on the bottom - look for the arrows next to the screws.
Put the projector on it's feet, and pull off the top. The button wires will still be connected, so just hold onto the top and find the black circle/shaft above where the lamp is. The shaft has white paint on the top/tip of it. Push it down with a light amount of force. You should hear/feel it click.
Put top back on, put screws in, and you should be good to go.
Don't forget to reset the lamp replacement counter in the menus.
Posted on Aug 01, 2008
nick_helpap
  • 334 Answers
SOURCE: reset lamp counter on Sanyo Projector PLC XU100
in main menu lamp reset in settings
Posted on Oct 07, 2008
Why does my sanyo dp46848 screen go dark but whites are too bright?
First try to gently push the cable between the main board and the LCD controller (T-CON) board and if that doesn't affect the image then replace the T-con board.
Jun 30, 2014 | Sanyo DP46848 LCD TV
Why is my screen too white?
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 25, 2014 | Sanyo DP46848 LCD TV
Loss of Picture
It sounds that the CCFL lamp has the fault. Contact any service technician to make it confirm.
Jul 24, 2013 | Sanyo DP46848 LCD TV
47in sanyo flat screen gets a black shadow across it got to tap it to make it stop but happens alot . model DP46848
You have a defective LCD panel tab connection. The only permanent fix is to replace the panel. A replacement panel will cost more than a new set. I had the same problem with the exact same set.
Feb 08, 2013 | Sanyo DP46848 LCD TV
I have an amana convection/microwave model acm1580as that needs a lamp replaces. I bought replacement lamp and after practically tearing appliance apart I located burnt out lamp. Now I don,t know how to...
Hi, since you have located the burnt lamp, all you need to do is to unscrew the burnt lamp and replace the new one by screwing it in.....
You only need to unscrew to remove the lamp and if you cannot remove by unscrewing because it is stuck in, then you need the assistance of an electrical tech to help remove with his pliers....
Mar 26, 2011 | Amana ACM1580 Convection Microwave Oven
Samsung 50 inch DLP has power will not turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.Note lamp sometimes doesnt look bad when it's bad.The lamp you need is BP9601472A you can find it here http://www.discount-merchant.com/Samsung-HLM437W1X-OEM-Replacement-LAMP-BULB-p/samsung-hls5087w-lamp-sm.htm?Click=48173.Have a blessed one!
Apr 29, 2010 | Samsung Televison & Video
How do I change the light bulb in the Sanyo pro traX multiverse projector
unscrew the lamp door on the bottom of the projector, unscrew the lamp, remove the lamp, replace with new lamp, screw in, replace door, turn on, and reset lamp counter (menu-settings-lamp counter reset-yes)..
Nov 03, 2009 | Sanyo PLC XU30 Multimedia Projector
My Sanyo DP46848 LCD TV display goes black when turned on.
My mother's was doing the same thing (purchased 2008). Put up with it about 6 months and took it to a repair shop. Bottom line - the display panel has a flaw in and will cost more to replace than the tv cost. See about it now it yours is still under warranty.
Oct 21, 2009 | Sanyo Televison & Video
TV won't stay on
Hello Fonzell!
Regarding the tv turning, my question is, do you hear a clicking sound? if so, it's most probable tio be your ballast, that might not have enough voltage to keep on with your lamp, and that's why it shuts off.
You could try replacing it and seeing if it resolves your issue, I believe they're running around 70 dlls..
have a great one ! :)
Apr 21, 2009 | Samsung DLP HL-P5663W 56" TV
Sanyo DP46848 LCD TV Logo
20 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
