Question about Vacuums
My vax rapide xl v027 leaks water from the clean tank through the rubber seal at the bottom of the tank. Seal seems ok but seems to rely on gravity. Leak is there weather or not its turned on
reddevil6
  • 1673 Answers
SOURCE: Vax problem
Could be a bad pump.
Posted on Feb 22, 2008
SOURCE: Hoover Steam Vac clean water tank valve leaks
Honey! It's broke. You can manuever the little black valves out, but you will only find the hole in the clean water tank. I have the EXACT same problem. My advise to you is to take the valves, caps and handle off, sell them on EBAY and then buy you a whole new clean water tank.
Posted on Nov 18, 2008
SOURCE: Oreck XL Leaks Dirt At Bag Entrance
do you use a docking station to put your bag on or is it just a push on bag? also when you turn on the vac with an empty bag in it, does the outter bag blow up?
Posted on Dec 22, 2008
  • 3 Answers
SOURCE: bissell spotbot: leaking the dirty
I had the same issue. After some research, I determined I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
This caused reduced suction, and for the water to pool at the botom of the spotbot, thus leaking.
I purchased the gasket at Bissell for 1.39. The part number is 203-6646.
I purchased my SpotBot new from Target, and never remember seeing this black gasket, but the difference is night and day.
Posted on Aug 14, 2009
  • 190 Answers
SOURCE: hoover steam vac leak from the bottom when tank
The tank is not sealing to the black rubber ring seal on the lower handle. make sure this seal is not displaced.
Posted on Nov 20, 2009
Vax carpet shampooer water tank leeking
If tank itself is leaking nothing you can do but replace it. Check it for cracks or leaks at sink. Make sure the round rubber seal it sets on is ok an not bent over or broken, also check the leaver to make sure it is not hing up an is working properly.
Jan 29, 2015 | Vax Vacuums
How do I replace the hoses on a Hoover Spin Scrub?
I'm guessing you have an F7000 series machine. You have a bad solenoid. When they go bad they don't close so all the water poors out. Take it to your local vac repair shop for the repair.
Sep 11, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
My Bissell proheat2x leaks water from bottom of machine, if you have the water tank full and cleaner and leave it sit it drains out onto the floor, it leaks when you are using it to, is this a seal or...
Nope, not a seal problem, just natural good old fashioned natural gravity. I know it doesn\'t take long for it to start leaking after use but Bissell covers this in the manual. Thoroughly clean the unit, run clean rinse water through every cycle and empty all tanks and cavities after use. Do not leave water in any of the tanks when not in use. What doesn\'t leak on your floor (which doesn\'t take long) could cause permanent blockages in the lines. It\'s a pain, I know, but I use the garage or back deck to park and prep mine after use.
Aug 15, 2013 | Vacuums
Hoover steam vac leak from the bottom when tank has water in it when not running but tank is not leaking
Nov 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Leaking tank
(1) Does water or chemical leak from the tank when filled, but before it is installed? If not, then the tank is OK.
(2) If the tank is not properly aligned to the lower handle when assembled and latched, the black rubber seals on the handle will not seal to the tank. You may wish to look at this. Also, make sure both round black rubber seals are present on the flat mount where the tank valves will sit.
Oct 05, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac spin scrub leaking cleaning solution
The hose leading from the tank to the sprayer head on the bottom of the unit, or the tank is not seated properly or the tank has a hole or crack
Feb 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Leaking Solution Tank/Seal Install - Hoover Steam Vac
Not sure this will help, but we have a Hoover Steamvac F5843 and our valve seal seemed to have shrunk so the tank was leaking. Bought a new seal and had the same problem. How to install? There weren't any instructions or pictures of the part(s) involved in the manual. Online there were a few pics but nothing helpful. After careful examination of the existing part and where it was supposed to be, I removed the original off the valve stem, placed the new one on it and carefully pressed the valve stem with the seal into place. It didn't look quite right and we were thinking "now what?". My wife and I got the idea at the same time...install the clean water tank (with the stem & seal in the bottom) back onto the steam cleaner. I took it back off to see what the stem & seal looked like afterwords and voila...the seal was perfectly inserted where it should be and the tank no longer leaks! The 'peg' that presses up on the valve stem pushed the seal perfectly in place.
Nov 16, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Leaking
If the seal and plungers are ok(bottom of tank), then most likely have a crack on the bottom of the tank, lot of times it will be under the seals, breaks away and will like out.
Dec 24, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Water leaks
I removed the clean water tank to refill it and all the cleaning solution poured out onto the floor. Turns out a plastic pin with a spring and a rubber washer also fell out onto the floor leaving a hole in the bottom of the tank. Calls to Hoover and local repair center all ended the same with the need to order a new clean water tank for about $45 and two weeks for delivery. Went to my local True Value Hardware store and within a few minutes we found a workaround using two 7/16"x 1/4"x3/32" #780 Ring from Danco Inc. Pulled off the proprietary Hoover O Ring that had obviously failed and put two of these O Rings on in its place and so far it is working perfectly. Total cost $1.35. Would be nice if Hoover cared to take better care of their customers by offering this almost free and quick solution to the problem.
Oct 13, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Vacuums Logo
142 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
