Question about Kenwood Audio Players & Recorders
KR-V5570 amplituner KENWOOD - Kenwood Audio Players & Recorders
3 Suggested Answers
  • 4 Answers
SOURCE: My Kenwood KR-V5570 receiver powers
i had exact problem.
the bare wire speaker cables that connect via a clip connecor in back of the receiver are pushed too far in. something inside is shorting out with the speaker cables. solve this issue by either tightly twistng or soldering the wire ends ( then clip the ends about 1/4 inch long). watch out for the same issue of electrical shorts at the speaker end of the cables.
Posted on Sep 05, 2009
HomePlicity
  • 41 Answers
SOURCE: do not hear the second click on speaker relay on
I will assume no audio is coming out of your speakers.
When the reeciver starts up It looks at the load (resistance) of the speakers attached to see if it is reasonable. If It appears there are no shorts in the speakers then the speaker relay will close (second click) and send signal to your speakers. If there is no second click then either the the reciver is detecting a problem with speakers or cables or the detecting circuit has failed. I would start by disconecting all speakers then start the receiver up. If your not getting a second click after about 4 or 5 seconds then the receiver will need service. If it does click then shut receiver off, and hook up one speaker at a time, then re-start receiver. If one speaker suddenly makes the system fail then you have found your problem. If you have a Volt/Ohm meter, set it to resistance(Ohms) and measure each speaker. Anything Under 4 ohms will be a problem.
Good Luck
Posted on Apr 01, 2010
Knob broken on Kenwood KR V5570
If you are in the U.S. you can try pacparts.com. You didn't say which knob was broken, so I couldn't research it for you. You should be able to find it there for yourself though.
Nov 19, 2012 | Car Audio & Video
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Hi, My friend (who has a visual impairment) moved house recently, they own a Kenwood KR - V5570, I assisted with re setting up PC etc. I am now baffled with connecting her left and right speakers to this...
If you keep guessing you may succeed in blowing something up.
The cables have RCA connectors or bare wires for a reason.
Get the manual out and read it.
Register and download it for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KR-V5570-Receivers-manual/id/479bh938/t/2/
Don't pay too much attention to the actual colors of speaker wire. Use the colors as reference. Each speaker has a plus and a minus. Connect them to corresponding plus and minus for their respective amplifier outputs.
Jul 04, 2011 | Kenwood KR-V5580
Do not hear the second click on speaker relay on kenwood KR-V5570 why?
Good Luck
Apr 01, 2010 | Kenwood Audio Players & Recorders
My Kenwood KR-V5570 receiver powers off when I try to run a medium to high volume and the standby light blinks
Apr 27, 2008 | Audio Players & Recorders
Have a kenwood KR-V990D and can't seem to bring the volume up
kenwood has always showed negative numbers 00 is as high as it will go
Jan 06, 2008 | Kenwood KR-V990D Receiver
Hook-up
You should first check the ratings and specification. Then only you can hook up. But from my side plz always use compitable systems
Dec 08, 2007 | Sony SA-WM20 Subwoofer
Problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Nov 19, 2007 | Kenwood KR-X1000
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
