Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printerhead problems, error codes and only black prints
I just set it up. at first it said printerhead not installed or loose. put it back in over and over. then error code 3809 keeps coming on. then it printed a photo only in black and white even though color ink near full. now the error code is back on and it's just there. useless.
  • 45 Answers
Need a new printhead. Call Kodak, they know this problem exists.
Posted on Jan 21, 2009
How to make printer print
Take the print head on and gently tap the nozzles on a paper towel.If you see all the colors and black then unplug the printer after the printhead is out and the carriage travels to the end (capped0
Wait 30 minutes and re-install the head.
This hopefully will make the printer believe it is a fresh unit
Aug 21, 2014 | Canon PIXMA MP610 InkJet Printer
I have an Epson color 440 printer that will not print black and white. I have put in a new black and color cartridge but it still won't print black. It will only print the things that are color and leave...
How about if you just print a plain text did you printer print it out a black text ? if yes so there's just some settings on the printer utility that should be check ...
Hope that helps..........
Sep 06, 2008 | Office Equipment & Supplies
My esp 3 kodak printer now has a printerhead problem after a year of use. When the printer does it's power up check I get a error with the ink cartridges indicator light lit up. When I remove the ink...
Your printer needs a service, in other words the waste ink sponges need to be cleaned and dried. They then need to be replaced and the printer reassembled. Then the Epson counter resetting software needs to be installed.
With this software the printer can be set to zero, it will work perfectly after this bit of attention.
It is a good printer, it's nothing that can't be repaired.
A computer technician will be more than happy to service your printer for you.
All the best!
damnor01
Feb 01, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printhead error
Just check your printedhead that could be not inserted properly of just clean the printerhead with a piece of cotton with alcohol then insert it back to the printer after you clean it. Then try to print if the problem are not solve just replace the printerhead.
May 29, 2010 | Canon imagePROGRAF W6200 InkJet Printer
Black ink does not print
If your printer have a separate printerhead with the cartridge just try to replace the printerhead of that printer it is because the printerhead have a problem on that.
May 28, 2010 | Brother MFC 240C All-In-One InkJet Printer
Printhead system error code 3807 Can't get printer up and running. How do i fix it?
For that problem kindly try doing the ff:
* Re-seat the inks both color and black then try printing
* Re-seat the Printhead of the printer then print again
* Try cleaning the printhead then print a demo page
* if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Oct 28, 2009 | Kodak ESP 5 Printer
Print Qued--No Print--Cartridge Error Problem--?Prinerheads?
It sounds like you need a new printhead, with that error the printhead is defective. The printhead is BC21E around $40.00
Jun 25, 2009 | Canon BJC 2100 InkJet Printer
Datacard SP35 + giving broken ribbon error
You have to clean the roller under the printerhead.
The big black one..
I suggest you install Diagnostics.
Go to motor test, and take the transport fast reverse. 300 sec.
Now you can clean the roller easy.
Nov 25, 2008 | Datacard SP35 Printer
Service printhead error 108
Error Code(s) Printhead Color
106, 111, 115, 171, 172 Cyan
107, 112, 116, 173, 174 Magenta
108, 113, 117, 175, 176 Yellow
109, 110, 114, 169, 170 Black
Power off the printer, take the Magenta cartridge out, take a lint and dust-free cloth or tissue and clean the hysinc mirror and the printerhead lens. I just did it and it took me three minutes to clean with toilet paper rolled up like a cigarette.
My printer is back on line. The hysinc mirror and printerhead lens is in the printer not on the magenta cartridge. Reinstall the print cartridge and power on. This has happened to me before with a different color.
here is the Lexmark c750 support link:
http://support.lexmark.com
I hope this helps. - This is from Joey V on fixyourownprinter dot com
Oct 13, 2008 | Lexmark C752 Printer
PrinterHead
A printer head is the ink cartridge. maybe you put the black where the color goes and color where the black goes. remember that black is to the right and color is to the left.
Apr 23, 2007 | Compaq A3000 All-In-One InkJet Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
139 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
