Question about Compaq EVO T30 Network Terminal
Upgrade 238622-001, Compaq Evo T30 Thin Client 300Mhz 32MB Flash/64MB/Win CE NET/IE 5.5 w/o
Hello: I would like to upgrade a: 238622-001, Compaq Evo T30 Thin Client 300Mhz 32MB Flash/64MB/Win CE NET/IE 5.5 w/o to support PXE. This means it needs to have Windows NT embedded to support PXE. How can I achieve this? We have about 15 Evo T30 that we need to upgrade. Any one out there with suggestions? Thank you in advance.
  • 3 Answers
You need to replace the 2mbit bios chip used by the WinCE Evo with the 4mbit one used by the NTe and XPe Evo, then you need an add on flash module, since the onboard flash is too small. After that, just find the OS file and flash away. You can find the OS files and a utility to flash from the HP support site. You'll need a crossover ethernet cable, not a patch cable, to do the flash.
Posted on Oct 07, 2009
SOURCE:
200E freezes up
A 200e that locks up usually need a memory and a firmware upgrade. The original 200's only have 32mb of internal memory. The upgraded mini print board that is used in the 730 has 64mb of memory. This 64mb board was used in the 200 as a upgrade and this stopped the lock up problem. Also over the years Bernina has improved the firmware and this also cures the lock up problem. The latest and probably last firmware version for the 200e is version 5, also called the cutwork version. The easiest thing for you to do would be to take your 200 to a dealer and have them install a 64mb mini print board and also upgrade your machines firmware to the latest version 5. Also if you have loaded embroidery designs in your machine, remove them as they use up the machines memory. When you get too many designs loaded even if you have a 64 MB board in your machine you can still have lockup problems.
May 28, 2014 | Bernina Artista 180
I have a wyse winterm v30 thin client. what steps will it take in order to reload the firmware?
you can download this pdf guide from
https://support.wyse.com/OA_HTML/cskmbasicsrch.jsp?jttst0=6_23871%2C23871%2C-1%2C0%2C&jtfm0=&etfm1=&jfn=ZG455B66622DEA31A7AE70467E3EBEC537FE9176B1484EFD6E483B952B0ED1CF6F10611204C7B33B20AA233809D7249C41FE&oas=etuN3Cl3pQgYaOxTZDlD7w..&categoryId=10820
this will show you the steps to do a USB firmware upgrade.
Mar 20, 2011 | WYSE Winterm V30 Thin Client - Thin Client...
Hi im looking for info on how to flash or load windows ce on a neoware ca5 thin client, i have downloaded the Os but have no clue how to load it on the thin. can you please assist me
  1. Make a bootable USB drive using HP Drive Key Boot Utility (via bootdisk.com Method 2)
  2. Format the flash disk in the device.
  3. Make the flash disk in the device bootable using MBRTool (This is necessary if you installed GRUB on the disk. The MBR needs to be overwritten)
  4. From the Win CE installation folder, from drive:\<path to wince installation>\PLATFORM\CEPC\SRC\BOOTLOADER\DOS\BOOTDISKcopy all files and paste it to the flash disk in the device (These files always comes with Win CE installation)
  5. Put your build of Win CE - EBOOT.BIN in the flash disk on the device (This will be your custom Win CE image)
  6. Remove the USB drive, and boot the device. Your new build of Win CE should boot up.
Aug 26, 2010 | Computers & Internet
Can I upgrade 32 mb Video display of my compaq evo n1000c?
As the Video Card is integrated into the Motherboard for your Model, the only way to upgrade is to change the entire board with a larger integrated Video Card. I believe there is a board with a 64MB ATI Card available. Cost of this board replacement may be more than ugrading to a newer system with higher performance specifications. Check link for HP Parts available: http://h20141.www2.hp.com/hpparts/part_search.aspx?mscssid=296B216B673D46AEAB69E6F5488E26A6&NoMatch=true
Jan 10, 2010 | Compaq Evo N1000C Notebook
How do you connect ethernet so you have both your desktop and thin client connected?
Purchase a ethernet hub. I have 1 by Linksys. They are relatively inexpensive. Plug your cable modem into the uplink jack and your desktop and anything else to the other ethernet ports.
Char S.
May 20, 2009 | Compaq Evo Thin Client T30 (311335-001) PC...
Upgrading my compaq evo d51s
A ram upgrade could help, however you may need to think about upgrading your CPU also. First check if you can upgrade your CPU. Your best option may be to upgrade to a new computer altogether.
May 07, 2009 | Compaq Evo D500 PC Desktop
How can i reset S30 wyse box
Try a G-key reset.
Failing that use WSI and an S30 image from the wyse Website.
WDM also has the option to to re-image the client.
You may also be able to get into the control panel of the terminal, and download an FTP image and set the terminal to upgrade from the image when uploaded to your ftp site. From the control panel, you can initate the upgrade manually
Mar 24, 2009 | WYSE Winterm S30 Thin Client - Thin Client...
Reflashing wyse s30 unit
It probably has to do with the version of CE client that is installed on the Thin Client. I have run into this problem before. The same Wyse clients can have different versions of CE installed. If the versions are the same then contact WYSE tech support to find what the error code relate to. BPCS
Dec 08, 2007 | WYSE Winterm S30 Network Terminal
Compaq EVO T30 Network Terminal Logo
717 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
