Question about Kitchen Appliances - Others
The drive belt broke on my bread machine. where can i find a replacement. this seems to be a quite common problem with this particular brand
  • Jyackle5
    Jyackle5 May 11, 2010
    Make and model # please
    President:
  • 267 Answers
If the belt broke there had to be a reason . most of the time you have a bad bushing on the mixer paddle or the main drive wheel . thats why you cant fine one . there sllways some other thing thats bad , and the second one breaks too
Posted on Jan 23, 2009
I need a replacement drive belt for my Betty Crocker Bread Machine 1690
Some bread machine belts have number codes on them. If you still have your old belt email me the code off of it. The code will look something like this: STS S3M 523 My email is daryl441@msn.com I sell replacement belts.
Mar 08, 2013 | Betty Crocker BCF1690 Bread Maker
Need a replacement drive belt for Red Man brand bread maker
I need the parts code off the belt to see if I have it in stock. You can reach me through my website breadmachineshelp.com The part # on the belt will look something like this: 60 S3M471 I will need that number to get the right belt for you.
Dec 30, 2012 | Kitchen Appliances - Others
Bread wont rise and now machine did not mix properly or cook right.
It sounds as though your timing belt has broke. The timing belt, located at the bottom of your machine, drives the kneading paddle to mix the ingredients. You'll need to remove the bottom cover to verify my guess.
Did this answer help? Please rate it as soon as you can. Thank you.
Jun 09, 2011 | Toastmaster Breadmaker's Hearth 1193 Bread...
BELT BROKE NEED REPLACEMENT IS THERE A DISTRIBUTER THAT I CAN GET THE PART FROM
Hi, I have the same machine and the belt was in tiny rotten pieces...I wound a piece of yarn around the wheel and drive shaft (lie the machine on a kitchen counter, lid open and hanging down off of the counter, bottoms up, and remove the screws from the teardrop shaped brass colored safety cover, remove the cover and expose the wheel and drive shaft) pull the yarn tight and knot it. Then cut the yarn about an inch from the knot. Measure the yarn when pulled on a little. Mine measured 23.5"....I then googled bread machine belt 23.5" and up came one for an Oster Bread Machine (The one I was repairing was a Regal Kitchen Pro 6725) from totalvac.com located at 2 De Bush Ave Unit A8 Middleton, MA 01949
It was $7.95 for the belt, $6.95 S & H to a VA address, total cost $14.90 so I decided to give it a shot. When it got here, I removed the safety cover, held the machine up and shook as much of the old rotten rubber belt pieces out as I could, and replaced the belt by placing it over the sticky string on the drive shaft and teasing it over the wheel. It is an exact fit. Be sure the ribbed side of the belt is down against the wheel. Screw the cover back on and run it through a dough cycle so that the belt will get coated with the sticky stuff from the sticky string on the drive shaft. Until the belt is coated, it will turn the mixing blade, but it will slip. Hope this helps. Patti
image_icon_name.gifPatti Wilson
image_icon_date.gifSeptember 2009
May 05, 2009 | Regal Ware K6745S Kitchen Pro Bread Maker
Regal-Oster belt conversion possible?
Patti Wilson
Feb 16, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Breadman TR2200C Doesn't knead
I have this bread machine. A few months ago after several years of use, this exact problem happened with my machine. I opened up the bottom (easy to do, just keep track of the screws) and found that the belt had slipped off the pulleys. If you read the reviews on Amazon, you'll see that this is a common problem with this machine.
It's pretty easy to put the belt back on, but that may only be a temporary fix. Mine kept hopping off, until it got to the point where I just left the bottom off my machine to make the belt easier to access.
A few things might help. First, put a thin coating of vegetable oil on the belt before putting it back on the pulleys. This was recommended to me, and since I did it, the belt hasn't come off again (about 6 loaves; before that, the belt jumped off nearly every loaf). Even if you're skeptical, try it.
Second, the pulley tension is adjustable. If you loosen the 4 screws around the little pulley, you can move it slightly to increase or decrease the tension. Be careful - if you tighten it too much, you'll stress the motor and it will labor and stall out. Also, too much tension seems to flex the big pulley, making it more likely that the belt will slip off. You may find that the solution is to reduce, not increase, the tension.
Third, someone on Amazon solved the problem by making a cardboard disk that's slightly larger than the big pulley, and arranging this somehow to keep the belt from coming off. You could try this or some other method of blocking the cut-out areas in the edge of the pulley that allow the belt to come off.
On the down side, if the belt is actually broken, you're going to have a tough time replacing it. Parts aren't available from the manufacturer or anywhere else for that matter, except used parts on eBay.
If you can solve the belt problem, I think you'll love the machine. It makes terrific bread, much better than the one other brand I've used.
Nov 16, 2008 | Breadman TR2200C Ultimate Bread Maker
Bread maker belts
Go on e bay. They have a couple of stores that sell nothing but bread machine parts
Jun 29, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
63 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
