Question about Coleman Home Electric Furnace Eb15b/Eb15d
My coleman central electric furnace only blows cool air
My furnace never blows hot air. It only blows cool air. Its a little warmer than outside but not much
  • Hannah Schroeder
    Hannah Schroeder Dec 02, 2017
    Your furnace never blows hot air? That must be hard in the winter. Mine used to work fine, but when I came home from vacation two days ago, it was blowing cold air. I think I'm going to hire a professional who specializes in heating systems to see if they can fix the problem. Maybe you should too. http://www.hightechheatingandac.com/heat...
  • 1,929 Answers
Are you trying to heat or cool?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Dec 02, 2017
  • 499 Answers
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Posted on Jan 13, 2015
5 Suggested Answers
  • 230 Answers
SOURCE: we have had a coleman
Ice is an indication that the refrigerant is not flashing off correctly in the evaporator coil. In most cases you can simply turn the unit off (until it completely thaws inside and out) and replace the filter. Make sure that all the vents in the house are open as well. If this does not work then you will need a technician to come out and check the refrigerant levels in the system. Ice can indicate that the refrigerant is low. I hope this helps.
Posted on Jul 08, 2008
  • 143 Answers
SOURCE: Coleman outdoor air cond. unit
If the compressor is running, you have a freon problem. If the compressor is not running, you have an electrical problem, unless the compressor itself is bad.
Posted on Jul 26, 2008
  • 17 Answers
SOURCE: Recycling to soon?
sounds like the unit is low on freon. it will need to be serviced so the leak can be fixed then recharged.
Posted on Jun 06, 2009
  • 146 Answers
SOURCE: My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
Posted on May 28, 2010
Electric furnace coleman model # 3120A751. It won't shut off on its own. Just keeps blowing hot air any ideas?
something is wrong in the 24v. make sure no wires touching each other both behind the tstat and on the circuit board in the furnace.
and obviously r to red w to white y to yellow.....
Jan 27, 2015 | Coleman Heating & Cooling
Coleman/ Evcon central electric furnace Eb15b thermostat on auto will not blow air out i hear a click u see and feel it heating up then i hear Another click dont see nor feel heat then but put thermostat...
check the thermostat setting on back for electric heat. sounds like it is on gas heat. the fan should turn on right away if it is electric or heat pump.
Nov 15, 2014 | Heating & Cooling
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
Why would cool air be blowing out of my central ac unit condensor that sits outside? The other unit I have next to it blows out warm air and responds well to thermostat changes. The unit blowing cool air...
It probably has a low refrigerant charge. The air coming out of the outside unit should be warmer than the outdoor temperature when in the cooling mode and if it's a heat pump it should be colder than the outdoor temperature in the the heating mode. Check the big line going to the unit, it should be somewhere around the 40 F range and the small line should be hot.
May 23, 2010 | Goodman CKL24AR24 Air Conditioner
Coleman gas furnace. Burner will re-fire for a few seconds during the cooldown. Model G8C07512MUB12A
This is a little complicated because it can be several things and you need to provide more specific info....It could be your furnace is shutting off on the High Limit...which means your furnace is running too hot...check the filter , return air vents etc would be an airflow problem...dirty blower....Furnace can be too big for your house....when the furnace shuts off on High LImit , the fan will continue to blow air , cooling it down as usual and once the furnace cools enough to reset the high limit trhe furnace will Ignite again as long as the thermostat is still calling for heat . The furnace could also be running too long and getting too hot....your Ductwork can be too small...many factors come into play
Oct 25, 2009 | Heating & Cooling
I also need a wiring schematic for a Coleman 3500A816 furnace
What are you wiring? Possibly we can help.
Sep 24, 2017 | Coleman Heating & Cooling
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
When we turn on the central air there is a strong burning smell...like burnt toast but way stronger. IS it safe to remian in the house?
Is your central air furnace or electric heat. Electric furnace sometimes have electric strip sequencer stick in the closed positions leaving on one strip of the electric heat. Get a service tech as soon as possible to check this out. Any smells from a central unit need to be teken care of promptly. TURN OFF unit you have it checked for your safety. Rus
Jun 28, 2009 | Coleman Heating & Cooling
Coleman Home Electric Furnace Eb15b/Eb15d Logo
379 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
