Question about Samsung FPT5084 50 in. Plasma HDTV
I have a Samsung PN50B650S1FXZA and the HDMI inputs do not work.The component video and RF coax inputs work. Tried different HDMI cables and different devices Blu Ray player and Cable Box.
  • Russell Klebs Jan 15, 2013
    The Main PCB BN94-02855F controls the HDMI switching. Replacing the  Main PCB BN94-02855F fixed the problem.
2 Suggested Answers
SOURCE: new device not found usb1
download the firmware and problem solve T-MSX5IBRC-1004.4
Posted on Sep 02, 2011
Samsung tv indicates no input devices are connected
did you try different hdmi port,also you can try component or composite,if those inputs work you have a defective main board
Nov 28, 2014 | Samsung Televison & Video
How to hook up a cable remote to a Samsung cable box?
    • 1 Examine the back of the your cable box and the back of your Samsung HDTV. Note which cable jacks are of an identical size and color. Those are the ones that can be used to connect the two devices. Samsung HDTVs cluster all the jacks in a single panel near the power cord.
    • 2 Look at the square rectangular boxes labeled "HDMI In." These are for high-definition multimedia interface cables--combination A/V cables that provide the highest possible image and sound clarity. Look at the back of your cable box for an identical jack labeled "HDMI Out." If you see one, connect the two jacks using an HDMI cable. If you don't, you need to use another set of cables to hook up your cable box.
    • Sponsored Links
    • 3 Check for a series of three round jacks labeled "Component In" and color coded in red, green and blue. These are component video jacks, which provide a good HD picture, but not as good as HDMI. If your cable box has an identical set of "Out" jacks, use them to connect the two components.
    • 4 Look for a pair of red and white jacks (possibly connected to a yellow one). These are audio RCA jacks. If you're using component video cables to hook up your cable box, you will need to hook these two up as well: Component video cables don't provide sound. Any cable box that uses component video cables should also have "Out" jacks for RCA audio cables.
    • 5 Find the raised circular jack with a pinhole in the center of a milky white plastic interior. This is the coaxial jack. Samsung HDTVs label them "Ant In." Every cable box should have a corresponding jack labeled "Out" or "Ant Out." If none of the other cable jacks on the cable box match, use a length of coaxial cable to connect the TV to the cable box through these two jacks. You can also use this connection to hook the TV directly to the wall cable.
    • 6 Turn on your TV and cable box, and set the TV to the input jack connected to the cable box. You can do this by pushing the Menu button on the remote, scrolling down to the "Input" option and pushing "Enter." That will let you cycle through the various input options, labeled by cable type (HDMI, component video). Press "Enter" again when you reach the right component, then exit the menu. You should now be able to watch TV as normal.
Read more: How to Hook Up a Cable Box to a Samsung HDTV ' eHow.com http://www.ehow.com/how_4867255_hook-cable-box-samsung-hdtv.html#ixzz2DwgQRtRE
Dec 03, 2012 | Televison & Video
The coax input on my tv is broken off how can I connect the cable to it other than the red white and yellow cords which don't have a good connection either I have my dvd player hooked up to hdmi is there a...
the simple answer is no.
but if you have basic cable (coax) you could connect it to a vcr, tune the channels with the vcr-
connect the vcr to the TV with composite video (yellow, red/white)
Apr 13, 2011 | Samsung Televison & Video
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
I am trying to connect my Samsung DVD Recorder to my Samsung PS-42D7HD tv via the HDMI cable but it just comes up "no signal" on the tv - nothing at all. Also have an Olin HD Set top box with...
Hello
by befault your dvd recorder is transmiting signals via component video, so what you need to do is this connect both cable HDMI and Component or just a video cable then go into setup and then select video out via HDMI your video will go off on the screen and then with TV remote slect input source HDMI on TV and it should work fine.
Thankyou
May 09, 2008 | Televison & Video
Cabling -- Panasonic LCD TV into LG DVD player (model no. DV6812P)
Take the basic Red, White, Yellow component cable -- plug it into the backside of the DVD player and plug the other side into the back of the t.v. Make sure to plug the right colors into the right sockets. If there are no available AV inputs on the back of the t.v, plug the other end into your cable box (if you have one).
Mar 03, 2008 | Televison & Video
No HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Feb 16, 2008 | Denon AVR588 Receiver
Connection problem
The best hook up for this unit is to use the hdmi if your samsung box offers hdmi output. The panasonic vcr should be hooked to any one of the composit video inputs with the yellow video cable and the red and white audio cables. If the vcr does not have composite output then use a rf (coax cable) to antenna a input and put the tv on channel 3 or 4 as vcr is set for.
Jan 13, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sony STR-DA5300ES Audio Problem
I am posting this to try and get everyones audio problem for this receiver fixed. If you only connected the HDMI cable to the 510, you will not get sound. This receiver passes through HDMI only, no processing of audio. You must either connect a fiber optic or digital coax to the 510 for that respective HDMI input from the BD player, the DVD HDMI only accepts digital coax, and the Video2 HDMI only accepts fiber optic. If you BD player does not have digital coax out for audio, you must move the connection to Video2 HDMI and connect fiber optic to the Video2 fiber input. Sony butchered the whole purpose of HDMI with this receiver. Hope this heps you. By the way, it is hardware, no firmware update will correct this.
Jan 02, 2008 | Sony STR-DG510 Receiver
Samsung FPT5084 50 in. Plasma HDTV Logo
Henry  Thomas
Henry Thomas
