Question about Konica Minolta bizhub 250 Scanner
What is code m4 on konica minolta 250?
Preventative maintenance is required please call your technician representitave and provide the code listed below Code: M4
5 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: konica minolta Di3510...C0500 troubleshooting
C0500 refers to a low fuser temperature. You can attempt to clear the code by using the tech rep service mode.
Go to "Counter"
Go to "Trouble"
Trouble reset
If "warm Restart Swich" is asked for- This can be actuated through a small access hole on the right side of the control panel, using a straightened paper clip or something similar.
You may need to clear the counter by pressing "clear" and then "end".
After clearing the code, power cycle the copier. If it comes to "ready" you are all set. If not, you may have a blown heat lamp or thermal fuse which would need to be replaced by a technician. Good Luck!!"
Posted on Oct 31, 2007
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
xeerie
  • 347 Answers
SOURCE: Konica Minolta bizhub 250 code 0204
The code is an error code, it means your copier bizhub 250 is having some problem in the LCT.large capacity tray the last tray.its not opening or may be malfunctioned.
Posted on Oct 20, 2010
taminol
  • 62 Answers
SOURCE: konica minolta Bizhub C350. Following message
Hi katienash,
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.
Good luck
Regards
m-press.biz
Posted on Feb 25, 2011
Konica minolta bizhub C253 is showing me trouble code C- 2556. What should I do to pix this problem
Konica-Minolta bizhub C253 Trouble Error Codes List page 4
Code C2556
Abnormally high toner density detected yellow TCR sensor
• TC ratio in the developing machine, which is determined by toner replenishing amount control mechanism, is 11 % or more for a given number of times consecutively. • When the connector of the TCR sensor is disconnected.
Solution:
1 Reinstall imaging unit. 2 Reinstall toner cartridge. 3 M3, M4 operation check (At this time, IU must be non-installation.). 4 Change imaging unit. 5 Change PRCB
Extract from:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C253&page=4
Nov 14, 2015 | Konica Minolta Office Equipment & Supplies
Minolta Di 5520 solution code C-13f5
Sir/Mam either the code is wrong or the model is wrong. The code is for a Minolta or some konicaminolta machines the model you list do you mean Di5510 which is a Konica machine that use Konica codes like SC35-03. Also the machine problem is listed under Bizhub 250 which I could not fine the code for either.
Apr 09, 2014 | Minolta bizhub 250 Black and White Copier
How to fix a error code 1327 on a minolta minolta bizzhub250
Try shutting dow the unit totally, even try unplugging it from the wall for 15 minutes.
If the error code does not go away, then a technician is needed
Apr 08, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
M4
I have a machine konica Minolta always appears incorrect code C-2703 I wanted to know what the cause of the problem and how to solve
Dec 15, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
I cant find the driver for my konica minolta Di1611 for windows xp. can you help me download it's driver?
Konica Minolta Photo Imaging, Inc. ceased its Camera Business Operation as of 31 March, 2006, and since 1 April, 2006
Sony Corporation has been providing customer service for Konica's, Minolta's, and Konica Minolta's cameras (excluding Film-in cameras) and camera-related products except for the binoculars.
Please be informed upon the termination of the Agreement between Sony Corporation and Konica Minolta Photo Imaging, Inc..
Konica Minolta ceased the entire customer services for Konica Minolta cameras and related products, as of 31 December, 2010.
After 1 January, 2011, the Repair Service Providers will continue support for the repair service independently.
To view the list of Repair Service Providers for each region, please click HERE.
Aug 15, 2011 | Computers & Internet
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5320 Black and White Copier
Dec 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
Konica Minolta bizhub 250 malfunction error 3452
Jun 12, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Minolta Di151 Error Code C-13
The trouble is that Minolta did not provide a chart of error codes in the user manual; mostly error code issues would require a technician to repair anyway -- or at least somebody trained to do preventive maintenance. If you have a routine repairman, or if you have My Konica-Minolta access, you should be able to get more information that way. Other things to check:
  • Is a preventive maintenance due?
  • What was the unit doing before it threw the code? Was it making copies? Of what quality? Did it stop in the middle or finish a run?
  • Are you using good quality, dry paper? This was posted in December -- might you be having static problems due to dry air?
If you're in the United States, you can check Konica-Minolta's Sales/Service Locator for a local repair outlet. Otherwise, you may need to contact Konica-Minolta directly.
Dec 26, 2007 | Minolta Di151 All-In-One Laser Printer
Konica Minolta bizhub 250 Scanner Logo
132 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
