Question about Kitchen Ranges
Mentis extractor fan ME100 4T will not work after installation
Power reaching the machine
2 Suggested Answers
SOURCE: Kitchen extractor fan
hi! most of the time this will be sticky switch normally located on the inside edge of the extactor unit behind the filter mesh!.hope his helps
Posted on Dec 20, 2008
Discharge Outlet Size W4400H Washer Extractor
Installation manual Washer extractors W4400H, W4600H, W4850H ...
www.opl-ltd.co.uk/extradocs/Gen4000%20Installation%20W4400H.pdf
Jan 31, 2011 - W4400H. W4600H. W4850H. W41100H. 400. 600. 850. 1100. 920. 980. 1220 ...Dimensions. 1 Control ... The washer extractor is supplied bolted in place .... The connector for the machine discharge (A) has ... outlet. Make sure that the hose's function is un- affected by the tilting function if the machine has
Mar 22, 2017 | Washing Machines
HJA2440 extractor (60cm model) light goes but the fan does not. I do not know where to find the fuse? Or other suggestions for getting the fans to restart?
Check for the proper power at the fan motor and fan switch. If the correct power is there the fan motor is bad.
Aug 30, 2014 | Kitchen Ranges
I have a Husqvarna extractor fans, the type with the motor on the roof. In seems to work fine on full power but not no the lower power settings. It also trips out when the light and extractor are on at...
The 'trip out' is where the unit draws more power than the breaker is rated for. Because it runs ok on full power (check they are running at full speed on this setting), the breaker is allowing enough power to reach the unit in this setting, so the breaker is fine. However when you switch on the light with the extractor it trips, at that point it is drawing too much power through the breaker at it trips to stop the device burning out. Check the connections to the unit are clean and dry and firmly made, if not power could leak away drawing more from the breaker. The next step is to measure how much power is being drawn by the unit in each mode, using an Ammeter in line with it. If you do not know how to do this (its dangerous if you get it wrong) ask an electrician to check the current draw in all modes.
Dec 19, 2013 | Garden
Icon extractor fan covers do not close completely
I have no idea of what you are talking about, but it sounds COOL!
("Alright Mr.Sulu, retract the Extractor Fan covers, on my mark......."
I need more POWER, Scotty!"
"I'm giving all she's got Captain!")
Post back in a Comment, David
Regards,
joecoolvette
Apr 13, 2013 | Computers & Internet
Bosch washer dryer WVT2850GB error code E06
Remove the rectangular fascia at the bottom front of the machine - on my model you only need a coin to turn the two plastic screws. Unclip the black rubber drain pipe, remove the plug from the end and drain the water into a bowl (or several bowls).
Then undo the round plug at the bottom left of the machine (more water will come out) which will give you access to the extractor pump. Check that there are no obstructions in there and that the small propeller in there can turn freely.
If there is no obstruction there then we move onto the next steps.
If you can figure out how to remove the front of the machine then you will find this part easier
First, TURN OFF THE POWER. Then, on the front of the machine, on the bottom left, undo the screws that fasten the extractor pump onto the front of the machine. Then pull the machine out from the wall so that you can get to the back of it. Remove the back of the machine by taking out the ten or so screws.
Looking in from the back: At the bottom-front-right of the machine you will see the extractor pump. It will have two hoses attached to it - a fat one and a slightly thinner one. Reach into the bottom of the machine and remove the power plug from the back of the extractor pump. Then, using a pair of pliers (or something similar) to open the spring clip, remove the thinner of the two hoses (the drain hose) from the pump unit. This can be fiddly - especially if you're doing it from the back of the machine.
Pull the hose out of the machine and check it for obstructions. If there are no obstructions in there then move onto the next step.
Reach back into the machine and, again using the pliers, remove the fatter tube from the pump. Remove the pump from the machine and check it for obstructions in the entry and exit holes, and also make sure that the propeller isn't obstructed. Then shake and squeeze the fatter tube to see if there is an obstruction in there
Best of luck.
Mar 29, 2010 | Bosch Washing Machines
Dec 20, 2008 | Imperial C2036PS1-TW Kitchen Hood
My extractor fan is leaking a lot of water, it is nothing to do with the weather as it happens when it is not raining. The extractor fan was working but now has stopped
sounds like
the extractor is mounted in a cold space, and the moist air is condensing on the cold fan as it exits,
the fan housing may need better insulation, and the flap valve in the exhaust pipe needs to be checked to ensure it is closing, and keeping cold air out
it is possible that condensate in the fan has fried the motor
something to check
Nov 05, 2008 | Heating & Cooling
Neff extractor fan not working
Hi rags116,
I'm Harvey the Master Plumber.
Your problem is: You have a neff extractor fan which hasstopped working. The light and fan have both stopped working. Do I know where you can find the fuse as you suspect that this may be the problem. If I don't think it is the fuse would I be able to suggest anything else.
The type is D-AY25-8 If there is another number that is more helpful please let you know. thanks Again your Neff Series 2 extractor has stopped working and you want to save yourself buying a new one!! Any suggestions greatly appreciated!
Since both light and fan require low voltage it sounds like a bad transformer. It will be mounted next to the motor. Make sure you turn off the power first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 24, 2008 | Kitchen Ranges
Wireing a bathroom extractor fan to a three switch (fan=landing light=offswitch0
yes, if the three switches are all made together, then there is only one feed. sounds like a bad switch, or possibly bad exhaust fan. check voltage at fan with switch on, if not qualified, be careful, or call an electrician
Aug 10, 2008 | Dryers
Bosch Extractor Fan model DKE945DGB
One way to check is to track down a schematic of the parts. That will often give you a good idea of there the part attaches and how.
Feb 01, 2008 | Kitchen Ranges
Kitchen Ranges Logo
264 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
