Question about Sanyo DS35510 35" TV
Tv too dark to see
The tv was working fine and it just went dark, I can barely see a picture. It wasn't hit with lightning or power outages. All the colors appear to be working but the screen is very dark. I first unplugged it from the surge protector an plugged into the wall, I tried to change the settings with the on screen menu, I tried the reset button on the remote to restore the factory settings, then I cleaned all the dust off the circuit board and made sure all the wires were connected securely. None of this worked so thinking it was a hopeless cause I did something stupid I tried to adjust the little knobs in the back. Yeah, I know that I'm an idiot. So now I have white lines and all the on screen letters and numbers aren't readable. I've had the tv for six years and it worked great. It is a Sanyo DS35510 35" tv. So I guess what I need to know is it a lost cause? Will it cost more to fix than it is worth? Thank you in advance.
    President:
  • 3,130 Answers
To get rid of the white lines look at the place where you turned the control. It should be called the screen control, turn down the screen control counterclockwise till the white lines just go away. If the picture is still dark, you will need to have this set serviced as there is a problem in the crt driver board, or the power supply board. good Luck
Posted on Jun 25, 2007
SOURCE:
VCR will not show picture or menu on TV after power outage.
Hate to say this, but when power outages occur, things like vcr's are the first thing to fry. But if you feel that the vcr is fine as far as powering up, then unplug it from the wall socket for 30 minutes or so, plug back in and see results.
Apr 13, 2010 | Televison & Video
During a storm, my tv was plugged into an outlet and it was working fine and in a minute, it turned off by itself. Now the tv does not work. There is no sound, no picture. The only thing thats still on is...
It got hit by lightning I believe. I hope you have insurance. It will most likely be in the power supply board. My recommendation is if you have cost replacement insurance is to get a new one. Once a tv get hits by lightning it is hard telling what other damage may be lurking.
Oct 20, 2009 | Hitachi 60DX10B 60" Rear Projection...
Had power outage and after hitting reset button green light blink
Hard to say without looking and sniffing!
But if you suspect that it is and it is likely, you may be able to get it repaired on your insurance policy. It should be covered under FUSION
Dont mention the lightning but check your policy. Then get the repair guy to write fusion problem on the receipt and submit for claim.
Sep 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I had a power outage!
Hi there!
Power outages and lightning are the main causes of Electronic failure. It has obviously affected your TV and will need to be seen to by a repair technician if you are not skilled to do so. Regards and good luck, JUS004
Apr 01, 2008 | Apex Digital AT2002S 20" TV
Tv hit by lighting don't come on at all
ok you have defective parts! power section in unregulated and regulated power supply! next the secondary power section!
Sep 21, 2007 | Durabrand DWT1905 TV
Prima plasma
sell it and buy real tv
Aug 29, 2007 | Prima CV1311 TV
Lightning hit last night tv won't work cable company says it's in the television
Sorry to here about your problem! This is the time of year I used to get tons and tons of sets, stereos ,games, and vcrs in for repair. On your panasonic it seems that maybe the surge took out the tuner portion or the power supply. It sould cost aprox. 200 bucks or so for a new tuner. Im sure your aware that homeowners will cover almost all repair after the deductable. Good Luck
Jun 04, 2006 | Panasonic CT-36G24 36" TV
Sanyo DS35510 35" TV Logo
109 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
