Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Freezer not freezing very well
I have a side by side made by GE in my garage. Most things seem to barely freeze in the middle but thaw in the top and the door. My garage is very cold on average about twenty degrees.
Thanks,
Randy
    Sergeant:
    Champion:
  • 318 Answers
Possible door seal problem, door may not be sealing all the way.
If not the door,,then it may be a lack of refrigerant, it may have leak out, have it recharged.
Posted on Jan 19, 2009
  • 410 Answers
I have another possibility for you. home refrigs for the most part are not designed to work in low ambient conditions ie: below 40f what will happen is they will cycle off on the temp control and then not start back up. only way to test for sure is move it to warmer area. door seals may be a part of th eproblem as well.
btw some newer refrigs actually have low abient kits available to help them operate in colder areas. you may check with GE to see if this is available to you. Peyton
Posted on Jan 20, 2009
Why is my GE side by side freezer not freezing on top?
It sounds like the freezer fan has failed. You are correct on the ice machine.
Jul 21, 2014 | General Electric GE Profile PSDS3YGXSS...
GE profile side by side fridge freezing and thawing randomly
Defrost entire unit, put food in coolers with ice and unplug. Wait 24 hours with doors open. Any clogs in freon lines should be gone, plug unit back in and see how it works.
Jan 24, 2014 | GE GSS22SGM Side by Side Refrigerator
My Ge side by side freezer was thawing now it
Might just be a freezer thermostat gone bad by sticking in an open position. If that's the case you will be out of control in temp settings. Hope this has helped!!BB
Dec 15, 2009 | GE Profile PSS26NGS Side by Side...
Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Aug 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer side not freezing
Turn off the refrigerator.Remove the freezer shelves/bins and rear panel.
Take a hair dyer and thaw the ice completely. The defrost heater will be across the bottom of the freezer coil. The defrost thermostat will be attached to a refrigerant coil at the top of the freezer coil.It is about the size of a quarter and 1/2 inch thick.There will be wires from top to bottom on the sides of the coil.
May 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile refrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
67 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
