I have a concord it has 2 flashes saying the presure switch is closed how to open?
  • 144 Answers
Rap it with a screw driver handle, not too hard
Posted on Jan 19, 2009
Why won't my hazard lights turn off on my chrysler concorde?
Might have a bad switch behind steering wleel on column.
Sep 13, 2014 | 1997 Chrysler Concorde
Computer board is flashing two red flashes. Code says that Pressure switch is open. What needs to be done now?
Hello, a pressure switch remains open for a few differant reasons, 1) there is a obstruction in the flue pipe or chimney, 2) the small hose that goes from switch to inducer is either loose, obstructed, or sometimes condensation can build up in that small hose 3) the switch itself is bad and must be replaced. Theses are a few reasons why it wont close. Let me know what you find.
Feb 08, 2011 | Heating & Cooling
Craftsman 53918 - 3/4 hp, belt drive garage door opener. Wall unit says safety sensors misaligned. Replaced them as suggested by manual, no fix. Does not appear to be any power from where you plug...
The main light flashing 10 times is the sign of a door sensor problem. Check to see if the small light on each sensors is lit and not flickering. If you cannot get both lights to come on your sensors or the wiring to them is bad.
Sep 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Alarm flashing and saying cover open. Have opened your close door switch has something stuck in it or it is broken
May 27, 2010 | Canon SmartBase MP360 All-In-One InkJet...
My 2 group astoria over steams from top of warms up then in about half hr steam shoots out at the preasure valve doicky do i need a new one of those thanks greg
The pressure releive valve is pre-factory set to open if the pressure in boiler reach between 1.6 to 1.8 bars.
So either you have the presure switch (presostat) not working normal which supose to switch off the electrical element at 1.2 to 1.3 bars.
So look at the presure gauge at which presure the presure releive valve open and releive the steam out from boiler if it shown more than 1.5 bar the you need to check the presure switch since it does not switch off the heating element.
If the presure releive valve open below 1.5 bar then you need to replace the releive valve.
Good Luck
Mar 23, 2010 | Astoria Argenta SAE-2 Espresso Machine
Car starts and cuts out after 2 to 3 seconds. fuel
When the ignition switch is turned on the pcm turns on the fuel pump by energizing the fuel pump relay. The PCM keeps the fuel pump on as long as the engine is cranking over or running.It does this by recieving pulses from the ignition module. If there are no referance pulses the PCM will turn the fuel pump relay off in 2 seconds with the ingnition on.
Most models also include a secondary control path through the oil presure switch witch will turn the fuel pump on after it detects oil presure.cranking time will be longer if the fuel pump doesn't recieve current until oil presure switch contact is closed.
Jan 28, 2010 | 1998 Chevrolet K2500
Meaning of rudd furnace trouble codes
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
Dec 12, 2009 | Heating & Cooling
Bad control board?
This is a good one! I would check for a blocked vent or intake pipe first. Also check to make sure the condensate lines are free of moisture or debris. What is the code for three blinks?
Oct 11, 2009 | Goodman GMS807034ANA Heater
Chrysler concorde sun roof stuck open!!
Check the fuses to start with. If they are fine it could be a broken switch or a burnt electrical motor. If the closing mechanism has broken and bound up it could keep the window from closing. With the car in accessory mode or ON -whichever allows the windows to open - hit the close switch and listen closely. if a click of the motor can be heard it is a mechanical issue - if not it is electrical.
Feb 26, 2009 | 1998 Chrysler Concorde
1993 chrysler instrument cluster lights out, headlights flash
sounds like you have a problem with your alarm system. likely the ignition switch is the problem.
May 15, 2017 | 1993 Chrysler Concorde
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
