Question about Oster Toaster Ovens
Display will not come on oster TSSTTVDFL1 toaster oven dead how to reset it?
1 1/2 months old toaster oven worked fine, this morning display does not light up, not of the buttons or knobs are functioning. Can this oven be reset, if so how?
5 Suggested Answers
  • 653 Answers
SOURCE: Toaster Oven Unresponsive (Farberware Model# FT032055
It sounds to me like you might have tripped the GFCI (Ground Fault Circuit Interrupter) or tripped the breaker. Go get a small lamp, radio, or other small appliance to plug into the same outlet. If they don't work, you have no power. The outlet you are plugged into may not be GFCI, but an outlet upstream may be. Older GFCI's were very prone to false trips. Newer models have indicator lights that either glow green when the power is on or glow red when they are tripped. If this doesn't pan out, go check your breaker box. A tripped breaker will have some room to move the toggle toward the on position. If you find one like this, assuming the kitchen circuit isn't marked, flip to off, then back to on. If none of this works, go buy a new toaster oven (assuming it doesn't work in an outlet in another room).
Posted on Feb 25, 2009
SOURCE: Oster Toaster Oven Model # 6192-33
I had the same problem where the time knob broke. I filled in a claim form on the Oster Website and they answered within 3 days saying the timer knob was discontinued and no longer available. They proposed to replace the whole toaster-oven with another model 6073-33 which I received last week. I've to say that their customer service was amazing.
Posted on May 12, 2009
SOURCE: broken timer knob
Posted on May 13, 2009
SOURCE: The knob on the bottom
You *can* order parts from the manufacturer directly, but good luck with that. The first time I called, and mind you their 1-800 # is a quagmire of numeric menu selections before you ever get to talk to someone, they said they would be happy to send me one but they were out/backordered and that I should call back in 2 weeks. Instead of putting me on some kind of list and sending me one when they got more...Grrr! Then I tried calling back and made it, again, through the menu maze only to find out they are in Eastern time. Super frustrating!
But I also discovered that the flat head screwdriver is the best temporary solution until I can get my hands on a replacement knob!
Posted on Jul 30, 2009
I found one of these on the curb. Took it home, and it was completely dead as you described. Took it apart, and there's a thermal fuse mounted above the convection fan that had blown. According to the data sheet, the fuse blows at 240C, but even if it never sees that temperature it will still fail eventually if exposed to high enough temperatures. The fuse is mounted against the chamber where it will get hot, so basically these ovens are designed to have a finite lifetime.
Anyway, long story short, you can buy replacement fuses online for a few bucks. It's a SEFUSE SF240E. Or just bypass the fuse. Keep in mind that the fuse is a safety feature that will kill the oven if it overheats, so keep that in mind if you decide to bypass it.
Jan 01, 2013 | Oster Toaster Ovens
I need to purchase a replacement for my toaster over #6233 - I need a new Baking Pan & Broiling Tray. Mine is very soiled and will not clean
FYI Oster Toaster Oven: about 18 months ago after careful consideration we purchased a counter top toaster oven for the RV from WalMart. I have a 20+ year old Oster Kitchen Center and found easy access to repair parts a couple of years ago, very pleased.
Last trip out in the RV the timer knob stripped out after what I would describe as a couple of months of light use. Google'd the model in search of a replacement knob only to find many others had "been there, done that". The model is obsolete and no service parts are available.
The Oster customer service rep seemed finished at this point and asked if there was anything else she could do for me. I asked what I, a long time Oster customer, should do with the useless oven. After repeating the question rephrased several different ways she put me on hold.
She returned several minutes later to inform me that as a "one time" courtesy Oster would replace our out of warranty oven with a current model. The replacement unit would have no warranty or support from Oster.
She supplied the model number and gave us an Order #. Looking up the model number and checking reviews I have very low expectations for the replacement. Most comment as to the poor quality and reliability of this current model.
A perfect example of a manufacturer who once produced a quality produce but now sells cheap imported disposable products.
YMMV
Nov 07, 2010 | Oster 6232 / 6233 1500 Watts Toaster Oven...
I have an oster toaster that worked for about 8 months, then just recently it shows this error (err) aftr toasting for a min. do you know what i can do?
It sounds like you have the same problem as the Oster 6248 typically develops. The fix is to avoid ever buying anything made by Oster again, because it's all the same ****, made in China, just more overpriced.
Jul 14, 2009 | Oster 6239 Toaster Oven with Convection...
Oster toaster oven 6293 won't turn on
Ask here, it seems they can get you every Oster manual as a PDF file.
Jun 04, 2009 | Oster 6290 Toaster Oven with Convection...
Oster Toaster Oven 6232 replacement parts?
Write to Oster and they might give you a new one depending on how old it is
Jan 30, 2008 | Oster 6232 / 6233 1500 Watts Toaster Oven...
"Err"or message with beeping
Same message here. Did anyone buy it a costco? I'm hoping they'll take it back. Andrew Victoria BC
Oct 14, 2007 | Oster 6239 Toaster Oven with Convection...
Toaster Ovens Logo
2,301 people viewed this question
Top Oster Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
ray gallant
Are you an Oster Toaster Oven Expert? Answer questions, earn points and help others
