Question about Apple iPod nano
My ipod is frozen
It just says synchronizing ipod
  • ollie 92 Feb 22, 2009
    i plugged in my ipod to the comp to charge it now its just frozen . even when i plug it in now i tunes dosent recognise it . its as if its not plugged in ???
    PLEASE HELP !!! i only got it 2 months ago:)
  • 728 Answers
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Posted on Apr 16, 2009
Resetting instructions
Hi Kirk
If you have forgotten the code or put the wrong code in your ipod, you can unlock the Ipod by doing the following:
Connect your IPod to the primary computer you use it with (the first one Ipod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock Ipod using either (the code or connecting it to the computer you use to manage its songs). . . you can restore your ipod to factory settings using ipod Updater.
Please note that this will erase all data on your ipod.
Afterwards, you can add your music and data back to your ipod.
If you want to change the primary computer that your Ipod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted.
Always make a backup of your important data.
2. Connect your ipod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your ipod and you don't have access to the primary computer, your only option is to restore the Ipod, which will erase all music and data.
Please take time to rate me
Bud
Apr 26, 2013 | Apple iPod Audio Players & Recorders
Tip
How do I synchronize Outlook calendar with my iPod Touch
<p>The iPod Touch is programmed to keep you entertained with videos, music, games and other applications. The device also keeps you organized by synchronization with Outlook and keeps track of your appointments and events. iTunes acts as the conduit of information between Outlook and iPod Touch to move. Any comments or additional agreements in the calendar data while the device reverts to Outlook and the two are synchronized. <br /> <p><br /> <p>1. Double-click the iTunes icon to start the program. <br /> <p><br /> <p>2. Click on "Help" in the top menu bar. From the drop-down menu, click "Check for Updates". If an update is available, click "Yes" to install it. If an update is not available, click "OK" to close the dialog box. <br /> <p><br /> <p>3. Connect the iPod to your computer via the USB cable. Click the graphic iPod under "Devices." <br /> <p><br /> <p>4. Click on "About" in the menu bar to the right of the iTunes window. <br /> <p><br /> <p>5. Check the box next to "Synchronize calendars from Microsoft Outlook." Click on the calendar you want to synchronize. Click "Apply" to copy the data to the iPod. <br />
on Aug 05, 2011 | Apple iPod touch
My ipod is frozen and the buttons dont work the unlock button is frozen and the ipoda1236 EMC no. 2174 screen wont turn off
Hi lastonsarah
Bud
Apr 22, 2013 | Apple IPOD 8GB MODEL NO. A1236
I forgot my passwor on my 8gb ipod touch and my screen is frozen
there are two options by which you can unblock the code on your ipod. Follow any of the procedures tomorrow.
Unlock with the Primary Computer
  1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
  2. Open itunes and sync the iPod as normal.
  3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by Restoring
  1. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  2. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  3. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Good luck.
Jun 07, 2010 | Apple iPod touch
I pod is frozen in Synchronizing plugged in and out and back into
Have you already attempted to reset the iPod?
If not you will want to attempt that as your first step towards resolving this issue.
To do so you will need to simply press and hold both the center and menu buttons for at least ten seconds or until the apple icon appears on the screen.
If this does not resolve your issue please do let me know.
Also in the future if the iPod seems to be frozen on the do not disconnect screen, shut down the computer and reset the iPod before disconnecting it. Improper disconnection can cause hardware corruption.
Jan 10, 2010 | Apple iPod nano 4th Generation
My ipod is stuck on the synchronizing screen
Try reseting it, It worked for me. Hold down the "Menu" button and the middle button for about 7-10 seconds.
Hope this helps!
Oct 04, 2009 | Apple iPod nano
Its frozen and the buttoms are not working
Please wait for your ipod to discharge all the power it has.it might even take 2-3 days to discharge the power Then after the ipod is completely empty (which means its off and needs to be charged) you can connect it to your computer. Please make sure your computer is scanned from viruses. You can also scan your ipod from viruses. Never unplug your ipod before it completes synchronizing. You dont need to worry! its normal for ipods to behave that ways :)
Jun 02, 2009 | Apple iPod nano MP3 Player
My ipod froze
Press and Hold the Menu Button and the Center/Action Button
This will reboot youriPod and it will be alive again.
If this helps you please leave a vote at fixya
May 17, 2009 | Apple iPod nano MP3 Player
My ipod nano is frozen
Try pushing down and holding for at least 5 seconds the Menu button and the center Select button, at the same time. This should force your iPod to restart and it should eventually again be discovered in iTunes. Using the Restore option aftwerwards in iTunes is adviceable, at least make sure your iPod has the last version of its software. Good luck!
Jan 03, 2009 | Apple iPod nano
My ipod nano 3rd keeps saying synchronizing 'Do not disconnect'. It's been saying that for an hour now and it's not even plugged into my computer. It's just frozen on that and I can't do anything. I just...
i want to change the list of songs i have in my ipod nano but how come the old once doesn't appear anymore but can't store new ones.. Keep on saying "not enough memory... need your help... thanks..
Oct 20, 2008 | Apple iPod nano
Apple iPod nano Logo
61 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
