I need the part for the Kenmore gas dryer-- heating element --burner assembly 8321272 --cannot find where to by to fix the dryer
SOURCE: replacing the heating element Kenmore dryer 110 64892
nestor, on the posted model, you want to drop the lower front panel. Take a puddy knife and push in on the clips on each side and it will pull off. Kill the power to the dryer. On the right you will see the heater housing. The housing will have a front deflector. You can remove that deflector by removing the screw on the bottom or simply just bend it down out of the way. Remove the 2 wires on the left that attach to the element itself. On the left side of the housing there will be a quarter inch screw that holds the element in place. Use a small socket set to get it off. Now the element will pull right out of the housing. Sometimes they are difficult to pull out but it will come out. Did you ohm out that element to make sure that was the culprit? Catriver.
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
SOURCE: removing front panel
The first thing to do is to remove the plastic plug on the lower left front corner of the dryer. it is just a small square plastic piece. This way you can see if the ignitor is glowing red. But to answer your question, You remove the 2 screws underneth the lint filter. Then the top will just pop up with a screwdriver. Then there is 2 5/16 screws holding the front on. (this is for the most common kenmore. If this sounds all wrong i will tell how the other model comes upart.
SOURCE: cant find heating element for kenmore 80 series dryer
it should be in a housing mounted just inside the back panel. unlatch the housing from its mounts and the element slides out from the bottom
SOURCE: where is heaing element located on kenmore dryer
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
