Question about Schwinn Cycling
Do the handlebars on the schwinn sidewinder raise?
Does the handlebars on the schwinn sidewinder raise ? Can you raise them?
  • 6 Answers
SOURCE: raising the handlebars
If your bike is older it might have a quill stem.To raise this you have to undo the allen key headed bolt situated where the bar & stem attach to the bike.It is often obscured by a plastic plug to prevent water rusting the bolt head.If this doesn't go high enough an adjustable quill stem must be fitted.
If you have the modern design of stem(A-head)you will have to replace the stem with an adjustable type which can be set upto 60 degrees.
Posted on Sep 29, 2009
dunnbiker
  • 8546 Answers
SOURCE: How do you raise the handlebar of a Schwinn Ridge
The handlebars stem is an Aheadset-style and as such has spacers below it to set its height. Once the steerer tube is cut to fit the combination of stem and spacers there's no going UP, only down. Stems can be replaced with different rises and lengths. Maybe that would help. A Bicycle Shop would have everything you need and the know-how to decide if you can mount the child carrer.
Posted on May 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: How do i raise the
Probably. Getting Riser Bars or a riser stem or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Detailed advice...
http://www.sheldonbrown.com/handsup.html
Posted on Apr 10, 2011
dunnbiker
  • 8546 Answers
SOURCE: Can I raise the handlebars? I
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Posted on Apr 11, 2011
dunnbiker
  • 8546 Answers
SOURCE: How do you raise the handlebars on a Schwinn
Your options are limited. Once cut, the steerer tube can be no higher than it is.
I would recommend you get used to the position that yields a careful compromise between
aerodynamics and uprightness when needed.
Posted on May 07, 2011
How do I raise the handle bars on a Schwinn Cruiser Alloy Seven?
There should be an allen wrench fitting on the top of the handlebar stem. Loosen (counterclockwise) so that the bolt head is up at least 1/4". Then tap the allen wrench with a hammer. The stem should come loose so that you can raise it. Be careful not to go above the "Max height" mark that will be engraved on the stem.
Oct 04, 2016 | Schwinn Cycling
Raising handlebars on schwinn ditch 2.0 dn
The above answer is incorrect. The Ditch has what is called a "threadless" fork/stem setup. One cannot raise the stem at all unless there are spacers above it. Raising the stem is also not the only option. A stem with a shorter "reach" may be sufficient. Google "threadless stem riser" to see options for raising the stem. Following is a video with the procedure.
Jun 09, 2016 | Schwinn Cycling
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
Jun 25, 2012 | Schwinn Cycling
How to raise the handlebars on a 1969 schwinn fair lady
loosen the center bolt at the handlebars,, do not remove it, just make sure its real loose, then place the front wheel between your legs, and work the bars back and forth lifting as you do ,, once you get the desired height, tighten the bars once they are aligned again with the front wheel
Aug 12, 2011 | Schwinn Cycling
I have a 4 year ols schwinn omni 191 C5 bike, i would like to raise the handle bars? can figure how to do it, used me hex thingy to remove bolt from sterring column and its would not raise, any help?
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Jul 26, 2011 | Schwinn Cycling
Need to raise the handlebars on Point Beach Schwinn bike
It's called a quill stem.
Google "how to adjust the quill stem on a bike" for video tips or just read this...
Jun 06, 2011 | Schwinn Cycling
How do you raise the handlebar of a Schwinn Ridge AL 26" bike? I want to add a child carrier and I need to raise the handlebar to make it fit.
May 27, 2010 | Schwinn Ridge Al 26" Men'sboy's Mountain...
Raising the handlebars
Sep 29, 2009 | Cycling
I need to raise the height of my handle bars.
I am not sure which question to answer, so I will try both.
raising the handlebars, loosen the stem bolt 4or 5 turns, (this is the bolt on on the top of the handlebar stem). Tap the stem bolt with a hammer, the bold should drop down and the handle bars should fall loose, adjust as needed, then tighten the stem bolt to set.
Please note, there is usually a limit line on the stem, do not raise bars above this level as iy will make the handle bars unsafe and could pull out or break off.
second question, Child seats ar very adaptable, an will fit most bikes. Be sure to use all the necessary hard ware and safety guards. for you and your passenger.
Try to get the seat set up as low as possible as the higher the seat the higher the center of gravity. It will have less effect on handling characteristics if you keep the seat low.
I hope this is of some help.
Ed
Feb 01, 2009 | Schwinn Mesa Gs Mountain Bike
Cycling Logo
668 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
