Question about Hotpoint RB757 Electric Kitchen Range
Locking door wont open
We have Hotpoint selfcleaning oven with locking door. It got lock when in broil mode. Have turned off oven but locking mechanism wont reopen??
  • Anonymous Apr 25, 2009
    door is locked
The self cleaning lock is stuck and I can't open the oven, how do I fix this
Posted on Mar 30, 2009
After selfcleaning tried to bake put when you push the bake button it says to unlock door, however door is already unlocked and open
During self clean the oven controller locks the door to ensure one does not accidentally open the door and get insured due to high temperature. The door lock mechanism is unlocked once the temperature comes to normal when self clean is complete. In your case the controller is still sensing high temperature but the door lock mechanism has been released. This could mean the controller is detecting incorrect signal. Try to turn the mains power to oven off and back on. If this does not make a difference then you need to check the temperature sensor or worst the controller needs to be checked.
As I do not have the model number of the oven it is hard to give further diagnostic information.
Aug 13, 2014 | Hotpoint Ovens
Oven is locked and I can't open it
Try setting back into the selfclean mode. The door should finalize the locking action after which you can cancel selfclean and it should then unlock. If this doesn't do it, the locking mechanism could be disengaged (broken), which will require an experienced tech to open the door for you for temporary use until a repair part is installed.
If you want to try unlatching it manually, try a THICK coat hanger. Bend one end at a 90 degree angle.With it at a horizontal position, insert it over the top edge of the door 2 inches to the right of center, rotate it 90 degrees (so the bent end is pointing straight down) and slowly pull it to the left in an attempt to pull the latch hook to the open position. You will have to "wiggle" the door slightly as you pull the latch. Use caution not to jam the hanger in place and PLEASE TURN OFF THE POWER BEFORE ATTEMPTING ANY DO-IT-YOURSELF REPAIRS.
Good luck.
Nov 19, 2012 | Kitchen Ranges
Maytag Frigidaire Electric selfcleaning oven slide in type 30 inch wide purchase in 2003 --cleaning lady cleaned oven,unable to pull open oven door -door is jamed shut ???
Hello
Let oven completely cool then try.Locks out for safety because of extremely high temperatures involved in self clean mode.
Feedback appreciated
Aug 05, 2011 | Frigidaire FEB24S2AS Single Oven
Oven will not come on to cook, it will come on in cleaning mode
I've seen this problem on my own oven. If yours, like mine, has a door that has a locking mechanism, the catch is most likely stuck in the locked position. The door still closes and the lever still moves (though it may be very stiff).
Take off the screws around the locking plate, manually push the catch to the open position, spray the catch VERY, VERY lightly with WD-40 and dry it thoroughly. Close the oven door and try the lever again.
At this point, it should move freely and your oven should be able to switch between LOCKED/Self-Clean Mode and UNLOCKED/Cook Mode. If it does still get stuck, you'll just has to a) try lubricating the catch a bit more or b) keep a screwdriver handy! ;)
Aug 05, 2009 | Hotpoint RB757 Electric Kitchen Range
Kitchenaid superba oven stovetop oven door will not open after se
When the oven goes into clean mode the door is automatically locked as a safety feature. I would put it back into clean mode again, let it clean for a while and then hopefully when it cools down the door will open. good luck .
Mar 20, 2009 | Ovens
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
How do use self clean service?
CAUTION: SHOULD AN OVEN FIRE OCCUR,
CLOSE THE OVEN DOOR AND TURN OFF THE
OVEN. IF THE FIRE CONTINUES, USE A FIRE
EXTINGUISHER. DO NOT PUT WATER OR FLOUR
ON THE FIRE. FLOUR MAY BE EXPLOSIVE.
To set the controls for a self-clean cycle:
For satisfactory results use a 2 hour self-clean cycle for
light soils and a 3 hour cycle for average to heavy
soils.
1. Be sure the clock shows the correct time of day.
2. Press Clean. "— — —" appears in the display.
3. Press the Up Arrow until "3:00" appears in the
display for a 3 hour cycle, or press the Down Arrow
until "2:00" appears in the display for a 2 hour cycle.
4. As soon as the Up Arrow or Down Arrow is
released, "CLN" appears in the display.
5. As soon as the controls are set, the motor driven
lock will begin to close automatically and the "LOCK"
indicator light will flash. DO NOT open the door while
the light is flashing (it takes about 15 seconds for the
oven door to lock).
6. The "LOCK" light will glow until the cleaning cycle is
completed or cancelled, and the oven
temperature has cooled.
When the self-clean cycle is completed:
1. The time of day or “END” will appear in the display
window and the “Clean” and "LOCK" light will continue
to glow.
2. Once the oven has cooled down for about 1 HOUR
and the "LOCK" light has gone out, the oven door can
be opened.
3. If “END” is in the display and the “Clean” indicator
remains on, press Clear/Off. The time of day will
appear in the display.
NOTE: When the oven is cool, wipe away any residue
or powdered ash with a damp cloth or paper towel.
Stopping or interrupting a self-cleaning cycle:
If it becomes necessary to stop or interrupt a selfcleaning
cycle.
1. Press Clear/Off.
be opened.
3. Restart the self-clean cycle once all conditions have
been corrected.
How the ES 200 operates:
CAUTION: NEVER ATTEMPT TO REMOVE EITHER
THE BAKE OR BROIL ELEMENT WITHOUT DISCONNECTING
ELECTRICAL POWER FROM THE
RANGE. ELECTRICAL POWER IS CONNECTED
TO THE ELEMENTS WHENEVER ELECTRICAL
POWER IS CONNECTED TO THE RANGE.
The ES 200 electronic oven control system is made up
of three parts that control the bake and broil elements,
and the locking of the door in the self-clean cycle.
1. Electronic oven control.
2. Oven temperature sensor.
3. Oven door lock mechanism.
Dec 06, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
GE OVEN SINGLE ELECTRIC JKS05BW
I have the same problem. Mine is a self-cleaning oven. But I'm just preheating it 450 and it did it. Then this AM it did it while broiling.
Apr 09, 2008 | GE JKS05 Electric Single Oven
Whirlpool 465 ceramic stovetop - Locks up in self-clean mode
Try this to get the oven door open. Turn off the power, take a coat hanger and bent at 90 degree angle about 2 inches long. Turn the wire side ways along the top of the door, 2 inches to the right of center, turn your wire so the bent piece is down. Now pull out on the door and move the wire to the left. This should unlock your door so you can get to dinner. What may have happened is that the broil got above 500 degrees at the oven sensor and locked the door for safety. That does happen
Feb 03, 2008 | Kitchen Ranges
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Hotpoint RB757 Electric Kitchen Range Logo
407 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
