Question about Canon Office Equipment & Supplies
Ir 3530 error E 000110-0001
E110 scanner motor error
3 Suggested Answers
  • 56 Answers
SOURCE: ERROR c-6000
Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
BR
Posted on Jan 27, 2008
muleskinner2
  • 270 Answers
SOURCE: I am using Canon IR
I had the same problem on a IR-2230 and I had to replace the Developer Assembly. Check the connection first - have you recently had this worked on?
Posted on Jun 22, 2011
What is soulotion canon photocopior error 000110
E110 : Failure of the Scanner Motor (M21)
1.Check the cable.
2.Replace the Laser Scanner Unit.
3.Replace the DC Controller PCB (PCB4).
Nov 11, 2016 | Canon Office Equipment & Supplies
Canon ir c3220 error code e000110 0110 how to clear this code
Here is a link to the error in the online service manual. This error may require replacement of parts prior to clearing
Canon iR C3200 Series Service Manual E110 0x10 Error Code
Aug 27, 2016 | Canon Office Equipment & Supplies
JAM ERROR 0207 ON CANON IR 3530
Open the printer and remove the paper jam.
Dec 04, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
E000110-0210 CANON C3220-C1
Code E110-0210 Description The operation of the laser scanner motor is faulty. The rotation of the M laser scanner motor is faulty.
The motor lock signal remains in an unlock state for 1 sec or more while the laser scanner motor is in operation. Error Codes Canon iRC3220 Code E110 0210
Oct 29, 2013 | Office Equipment & Supplies
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Error E110
laser scanner motor has a fault.
laser scanner driver pcb might be faulty.
or the dc board has a problem.
Aug 15, 2011 | Canon imageRUNNER 400S Copier
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Canon ir 3530
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
ERROR c-6000
BR
Jan 26, 2008 | Kyocera RI-3530 Black and White Copier
82 people viewed this question
old marine
old marine
