Question about Zephyr Savona ZSA-M90S Kitchen Hood
Need new filter panels. Our Savona is only 3 years old and filters keep falling onto .
Where can we get new filter panels? Three year old Savona filters keep falling onto our range during cooking. Walking the Great Wall of China would take less time than trying to replace light bulbs. Had we only known where this was made!!!
5 Suggested Answers
SOURCE: Push Button Switched
zepher sent replacement sritch.
had to wait a while -parts from italy (heh)
so far ok
design is poor
Posted on Jul 18, 2008
SOURCE: light blub burnt out
The easiest way to remove the light bulb is to wear a rubber glove, use your palm to press against the bulb, and turn counter-clockwise.
The suction created by the rubber glove should allow you to remove the light bulb easily.
Posted on Jan 15, 2009
  • 68 Answers
SOURCE: range hood is making noies
use a good 3 in 1 oil. Don't use WD-40 it will only clean it then dry out the bearing. the problem will be worse than when you started.
Posted on Feb 06, 2009
SOURCE: Zephyr Savona
Original bulb is actually a JDR--I purchased 2 bulbs and received JDRC bulbs that are shorter and do not fit and there is no adjustment at the bulb housing/socket--LOL
Posted on Apr 07, 2009
Car is cutting in an out as though it is out of fuel how ever the fuel tank is full. I guessing there is a fuel blockage. Would it be the fuel filter?
Hello leah... yes begin by changing the fuel filter. Here is how to do it:
1 Raise the left rear of the vehicle with a floor jack and place a jack stand under the rear sub-frame to support the weight of the vehicle should it fall. Every year people are injured or killed by not following this simple safety step.
2 Turn the ignition off and remove the fuel filler cap to relieve any pressure that has built up in the fuel tank from evaporating fuel. This will prevent fuel from spraying and running down your arm when you release the fuel lines.
3 Use the fuel line quick disconnect tool to remove the lines from the fuel filter by slipping the tool into the quick disconnect until it spreads the retainer and allows the line to be removed. Push the line onto the filter while pushing the tool into the fitting, then pull the line off the filter. When both lines are free, unsnap the filter from the bracket.
4 Snap the new filter into the bracket, noting the markings that indicate flow. Flow should always be toward the engine. Push the line fittings onto the filter nipples until a click is felt, and the line can no longer be pulled off the filter.
5 Prime the fuel system by turning the ignition key to the "Run" position for two seconds and then to the "Off" position. Do this three times and then start the engine. Check the filter quick disconnects for leaks then test-drive.
Feb 20, 2011 | 2001 Mazda Tribute
Need firing order with diagram
Firing order 1-5-6-3-4-2-7-8
Distributor rotor turn's clockwise
cylinder's 1-2-5-7 left side of motor
cylinder's 2-4-6-8 right side of motor back side by fire wall.
Maintance
Keep up with your oil changes every three months or 3,000 miles which ever comes first, also at same time have all fluid level check, fuel filter and air filter replace once a year, tune-ups every two years, have your brakes check once a year, unless then feel funny have them check right away, transmission if fluid and filter has not been change every 30,000 miles, I leave it alone or new fluid will damage transmission clutches and transmission will have to be overhaul within 30 to 60 days.
Jun 29, 2010 | 1988 Cadillac Sedan DeVille
I have a napa fuel filter I took off and wanted to
call napa and give them old part # they can cross reference it to a new number for the right filter or any other auto shop give them ur veh info -even online price 5.95 to 12.95
Sep 27, 2009 | 2003 Ford E150
Need to change the frig water filter
filter part number is fsp-4396710 @$39.95 it is located in the front grille on the left side. It unscrews and pulls out. You transfer the twist top onto the new filter and push and screw it back in.
Apr 08, 2009 | KitchenAid Superba Architect KSCS25INSS...
Hello, I have the same model. And though it is three years old, starting from the last month, it does not clean anything anymore. Cannot even pick up one single thing from the floor. Every dirt gets stuck...
i know bissell vacuums are very cheap but they should last more than 3 years. there should be two parts to the dirt cup. remove the dirt cup and above it there should be a round plastic part. unscrew it and check that filter.
Apr 06, 2009 | Bissell 6594 PowerForce Bagless Upright...
Range hood is making noies
Feb 06, 2009 | Zephyr Savona ZSV-E30AS Stainless Steel...
Need a new hood for my hauck 3 wheeler about 3 years old
we are manufacturers of auto hood..jus send us your specifications, we'll provide u with the same.
Thnx
Jan 24, 2009 | Hauck Baby Gear
Model EL7020 will not stay running!
Try turning the knob on top of the machine all the way to the right and try it again
Dec 04, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
so far ok
design is poor
Feb 29, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr Savona ZSA-M90S Kitchen Hood Logo
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Tom Chichester
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
