HP Deskjet 3845 InkJet Printer Logo
Shirley Hemphill Posted on Jun 25, 2007
Deskjet 3845 not printing properly
I just loaded a new black and color ink cartridge into my hp dedkjet 3845 printer. The print test comes out good. However, when I print the printing goes lopsided on the page and looks blurred. After a couple of pages the message comes up that the cartridge will not move shut off the printer and check for any paper jam or particles. I have check and found no paper jam. Have dusted off the inside of the printer. Cannot find anything. However, the problem keeps occurring. Any suggestions on what the problem could be and how to fix it?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 25, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
517
Points
It needs a proper service as the moving parts are not moving freely .. or maybe when installing the cartridge you have damagaed one of the sensors .. it can be one of both
How do i print a self test for black ink through Linux Ubuntu for a hp deskjet 3845.
Open the Printer widget. Select your printer option for a a self test. But I believe that a self test option should be available from the printer's own command panel.
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: [email protected]
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
    For additional support please visit http://www.inkjet411.com
    -Thank you
Large ink spill. Printer no longer recognized new black cartridge.
You can perform the Tap 41 Cartridge Health Diagnostics Test: [applies to HP Deskjet 6800/6900/9800]
http://inkjet411.com/?page_id=1741 (refer to 2nd video to understand how to read the printed pattern)
1. With printer power on, press and hold the POWER button.
2. Press the Cancel (X) button four (4) times.
3. Press the RESUME button (Down Arrow) once.
4. Release the POWER button.
5. The Diagnostic Test Report should print.
--- A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout: http://inkjet411.com/?page_id=1741
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink (special "ink back-up mode").
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
HP Deskjet 3845 printing in blue yellow and green but no red. Print cartridges are new.
Check your cartridges. HP cannot guarantee the quality of remanufactured or refilled cartridges. Also make sure that the expiry date of the color ink is not reached. You should find it written on the cartridge itself.
Hi there, I have recently changed the black ink cartridge in my HP Deskjet 3845 printer, but it now prints with purple ink. Can you help?
have you cleaned the print head? done a test page? i had a simlilar problem with a lexmark but it turned out to be a refilled cartridge. if you are using genuine hp cartridges i would recommend printing a test page and checking the solid colours .
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00224&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=372330
hope this helps!
New color cartride not printing in color - printing in black and white
If you are not using factory new HP ink and cartridges then that is most probably your problems.
If you are using HP factory new cartridges, then contact HP technical support and inform them that you have a defective cartridge.
By the way, you did take the tape off of the nozzles and contacts, didn't you?
Don
Printer only prints out in blue
change the color cartridge and instead of Black,,use Photo Cartridge..
HP 3845 Inkjet won't print color under OSX
Try this test:
Let's say you want to print this present page (of fixya.com from Firefox or another web-browser), try File/Print and see if you have the tab Advanced to change to the color cartridge.
2answers
Replaced black ink cartridge, now printer won't print
3120 printer won't print black after new cartridge installed
k24674
Grand Canyon Tech
Grand Canyon Tech
