Question about HP Compaq nx6310 Notebook
Dvd RW driver (E:)
I have a problem with Dvd RW driver (E:)
when i put the cd in my computer any cd
i't doesn't work , and told me insert a disk
please help me how can i fix it
  • 2 more comments
  • alkaladi2009 Feb 11, 2009
    i did all that you telling me , and i restart the computer and then it's tell me instaliton disk
    who can i fix it it's don't log in
  • alkaladi2009 Feb 15, 2009
    vista indows
  • Dan rogers
    Dan rogers May 11, 2010
    Did you install the drivers for the drive
  • djembe85 May 11, 2010
    you should fill us in on the make and model of this writer
  • 20 Answers
Thereis a standard cd/dvd registry fix you can try , go to start menu and type regedit to enter the system registry. go to registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} an delete the upper and lower filters enties on the right side of the screen. close registry edit and reboot you system and you should have your drive back . given its not the drive itself( hopfuly it power up, and spins a cd)
Posted on Jan 19, 2009
  • 2 more comments
  • Dennis H Jan 19, 2009
    I you don't understand/or trust the fix , please send me more info
    I am a MCSE w/ Microsoft, and have been doing so for 20+ years.
    Another thing is what operating system are you using , unless you are installing linux, Win 98 an above do not require any CD drivers.
  • Dennis H Feb 12, 2009
    Please list your make & model of the drive, and the Operating system your using ( windows 98, xp etc.)
  • Dennis H Feb 15, 2009
    At this point I can tell that you do not understand enough to repair the situation with your older laptop.
    Any computer shop in you area could fix your problem for around 30.00 if it just a software issue, if the drive is bad it an be replaced for around 50.00 plus install . Good luck
    By the way I don't deserve the rating you gave me, Ijust was trying to help with the limited/ or lack of info you provided
My DVD/CD-RW drive isn't recognized/ doesn't play disks.
It may be bad. Has the laptop been damaged? Dropped? Open Device Manager, DVD/CD Rom drives, is it listed? In Start Menu, Computer, Is it listed? Try re installing the DVD rom driver, the MS Vista 32bit drivers can be found here:
Feb 02, 2013 | Dell Vostro A860 Notebook
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
Pioneer dvd rw dvr-k16a driver of toshiba laptop not functioning
this shows that your DVD RW is out of order and the only solution is to replace it with the new one.
dont forget to vote
Oct 10, 2009 | Pioneer DVR-K16 Burner
When in ''MY COMPUTER'' - CD Drive (E:) was droped into DVD-RW (D:
Try uninstalling the drivers in device manager, shut down, reboot and Windows should find both devices, it might ask for your windows disk to install drivers or search online to install them
Jul 27, 2009 | Computers & Internet
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
ACER 9410CD/DVD-ROM driver not found.
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Aug 14, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Why display "disk full" or "Wrong disk" and the disk is new
Try to used Nero, application that will help your driver execute the appropriate task to execute.
Please rate me SOLVED
Nov 19, 2007 | Teac (CDW552GA02) (CDW552GA02/10PK)...
HP Compaq nx6310 Notebook Logo
97 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
