WHERE IS THE FUSE FOR A SAMSUNG WASHER WF328AAW/XAA
3 Suggested Answers
SOURCE: I purchased a WF328AAW/XAA washer
I am having this same issue. Did you ever find a solution?
Posted on Mar 22, 2011
  • 6277 Answers
SOURCE: My washer has no access
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
(On some machines it is necessary to unscrew or pull the lower front panel off to gain access to the filter cover)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 04, 2011
I have a Samsung front load washing machine wf328aaw/xaa. the washer stops when it gets to the drain function. The drain pump motor is not getting the 120 to run the motor. I removed and tested the
There is a water level sensor that could inhibit the operation of the pump if it is indicating that the water level is low. There is also a small relay in the control panel (on the control circuit card), which may have dirty contacts. That is the contacts are not closing properly. Unfortunately, this relay is not readily accessible to consumers and even quite difficult to service for the professionals. I posted a description of the repair or cleaning of the contacts on the question placed by another user "My Drain Pump Doesn't Work"
Oct 19, 2014 | Samsung WF328AAW Front Load Washer
I have a Samsung front load washing machine wf328aaw/xaa. the drain pump motor is not getting the 120 to run the motor. I tested the resistance on the motor and it tested ok as 13.8. when I put the w
Have you resistance tested the cable from the pub to the pump connections ? The sensor problem I had which was linked to failure to drain was connected to a piece of tube some sort of pressure sensor .. The tube had a split so it was not detecting the pressure (of I assume height of water left in the machine) split was at the top .. Bit of trimming of the pipe fixed the problem
Samsung washer WF328AAW/XAA metal pieces in hose?
Could be a number of things. Either something foreign was left in a pocket (Coins are the most common object) and has come out in the wash. The coin rattles around and falls in between the tubs through the gap in the front gasket. When this happens, the coin can hit the bracket which holds the heater element in place and tears it off. This causes a lot of damage. Most Samsung have plastic outer bowls and often, the tub will be split and a leak will start from underneath. Lastly, it could be the drum main shaft and spider assembly. This is what holds the spin tub into the machine. If this fails, bits of metal will come off. Usually seen as bits of corroded aluminium that get stuck in the pump and hoses. When this happens, the tub usually goes loose and the machine makes a horrible grinding and banging noise when spinning. I would say that if this has happened , its time for a new machine.
Sep 10, 2014 | Samsung WF328AAW Front Load Washer
Where is the debris filter in a samsung washer WF328AAW/XAA
you take the plug out
take the back off
it should be between the tub and the pump ((take the hose of and clean it))
Feb 02, 2014 | Samsung WF328AAW Front Load Washer
Wf328aaw hums but won't work
Could you please describe the problem you are having a little better?
Nov 17, 2012 | Samsung WF328AAW Front Load Washer
WF328aaw Samsung Washer, Will not power up. No lights no sounds, complete no power. Check the door if it was closed, check the breaker outside home, did the tech support in the accompanying manual. I did...
I have same problem. The way I get around it is I change the cord to another wall socket. Apparently this is a thing with Samsung washers of this model type. There is a way to dyi fix it, but it would involve buying the part and taking the top off and risking something else to fail
Jan 27, 2018 | Samsung WF328AAW Front Load Washer
How do you install a pump motor on a samsung washer model # WF306LAW/XAA
remove back panel and you should see the pump .remove the clamps on the hoses and there should be 3 bolts securing pump to base, remove with socket, 1/2
Aug 26, 2010 | Samsung WF328AAW Front Load Washer
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
