Question about kawasaki Full Suspension Mountain Bike Men
Brute force 750 carb problems
I have a 2005 brute force 750...i have installed a set of hot cams, as well as a big gun exhaust system, i have re-jetted...but i think i need help in the pilot jet..at 0 - 1/4 throttle it is running very rough, and it will backfire..i was told that if it backfires out of the exhaust it is to rich, so i have been trying to adjust the pilot screws but nothing is happening..should i get a rejet kit..would that give me more options
3 Suggested Answers
SOURCE: kawasaki brute force 750 2005,
Your jetting on the carbs are wrong.
if you want more info on the jetting and how to do it along with some GREAT info, check out highlifter.com/forum
Posted on Dec 18, 2008
  • 4 Answers
try to drain carb
water probably got in through air box and carb vent hose
drain and flush carb
replace spark plug
spray contact cleaner in carb throat through air box
Posted on Dec 19, 2008
I have a 2005 brute force 750 won't start with electric start it will start when I pull start it will run.when it's running the lites and display are flickering .
Sounds like your battery is about dead... replace the battery and clean the connectors/wires/terminals.. and a little waterproof grease will stop the corrosion. Make sure the new connections are tight!
Jan 25, 2017 | kawasaki 2005 Brute Force 750 4x4i
I have a 05' brute force. It starts and idles great but when i drive it misses out and when i let off the gas it backfires. Any ideas why? I have cleaned the carbs and changed spark plugs
Do you have a multi-meter and can check your cdi? The cdi is known as an igniter. It's what actually sends the signal to the ignition coil to fire down to the plug. If you can test your cdi and let me know, I'll see if I can find the specs - also, are you able to check your timing?
Dec 25, 2015 | kawasaki 2005 Brute Force 750 4x4i
My 06 Kawasaki 4 wheeler. Backfires when light switch is on going down highway. Is it battery related ?
Problem with Brute Force, please save my 4-wheeler from shop ...
www.kawieriders.com > ... > Kawasaki Brute Force/Prairie/Bayou
Nov 16, 2011 - Problem with Brute Force, please save my 4-wheeler from shop! ....2007 kawasaki 750 4 wheeler backfire problem ... should I save for my brute force 750? moe, Kawasaki Brute Force/Prairie/Bayou, 3, 10-18-2010 06:55 PM. Backfire thru exhaust
Feb 24, 2011
Low RPM Backfire Through Carb
May 24, 2010
four wheeler keeps backfiring
May 9, 2010
06 brute force 750 poping and backfire
Feb 18, 2010
More results from www.kawieriders.com
Oct 08, 2015 | kawasaki Motorcycles
05 kawasaki bf 750...battery was low......put a new one in..........now backfires out the exhaust.......tried the belt reset.....didnt help......suggestions.?.....
Brute force backfire problem - YouTube
? 1:06
www.youtube.com/watch?v=VFxGBYoVFqk
May 5, 2013 - Uploaded by gubba1957
I bought this 2006 750 it had a backfire problem when I bought it so I cleaned ... 2005 Kawasaki Brute Force 750 - Stock Exhaust Modification ...
Oct 03, 2015 | kawasaki 2005 Brute Force 750 4x4i
Why does my brute force four wheeler barg down when I give it gas then it backfires
The float in the carburetor is possibly sticking. have the carb cleaned or run some carb cleaner through it.
Aug 27, 2013 | HMF Kawasaki Brute Force 750 08-11 Swamp...
Kawasaki 750 brute force brake
Remove and check the settings, check the bearings and the tolerance that is needed or if there was dirt or foreign particles that had caused this to happen. Also it can be due to worn out brakes.
Jul 04, 2012 | HMF Exhaust Kawasaki Bruteforce 750 05-10
"06" Brute Force 750 back firing thru the carburators
Sounds like you may have to do a complete carburetor cleaning. Also, after this is done, be sure to put the breather box back and that includes the box cover. That bike is not worth a fiddlers, ..... without that cover put back on it. If the carburetor cleaning is not done properly then you'll still have the problem. Also, be careful when taking the carbs apart, they have different size jets in them and don't move anything in regards to linkages. Those carbs are also syncronized.
If that don't do it, then maybe, you'll need your valve clearances adjusted.
Good luck
Nov 01, 2009 | kawasaki Full Suspension Mountain Bike Men
Kawasaki brute force 750 2005, idles fine, but when you press the throttle it backfires, is this due to a carb problem?
Dec 11, 2008 | kawasaki Full Suspension Mountain Bike Men
good chance u have a bent rod, bent valve. Need to take to shop to get checked out.
Oct 30, 2008 | kawasaki Full Suspension Mountain Bike Men
kawasaki Full Suspension Mountain Bike Men Logo
1,301 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
