Question about Kenmore 22612 Bagged Canister Vacuum
Kenmore vacuum 27612690 power cord stuck
The power cord won't retract
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: vacuum base removal-kenmore whispertone 300
Most of these you have to take off the cover on the back end where the cover retrack button is. Usually it has a catch, 2 on each side, use a screw driver, pry up near each corner to release it, then you can get to the cover over the moter and cord reel. Remove the 2 screw and put up and out.
Posted on Jan 14, 2008
  • 744 Answers
SOURCE: power cord reel problem with a kenmore canister vacuum whisperti
Pull the cord all the way out and see if it's contaminated with anything sticky. Also check the guide rollers that the cord rides in and see if they are rolling smoothly and without resistance - they may also need cleaning. If so, clean it off and try again.
If not, it may be the spring reel itself in which case you may need to replace it.
Posted on Apr 30, 2009
Power cord wont fully pull out or retract?
There is probably dust causing the roller to get stuck. Try spraying some WD-40 just a small spray inside the hole the cord retracts into and see if that helps.
Feb 20, 2015 | Vacuums
How do I fix the retractable cord on a Dyson DC19 vaccum cleaner
Great Youtube video
https://www.youtube.com/watch?v=4p0N2XwiKaw
Aug 22, 2014 | Dyson Vacuums
Husky power cord reel won't retract
spring in cordreel is sprung. cord is probably on last leg. Go to vac replacement parts online store and order a new one.
Feb 04, 2013 | Vacuums
The power cord does not retract or rewind when the button is pushed. How can I repair this?
Sometimes you can help get the springs working again, by gently pulling the cord out a little further and then let it slowly in while pushing the cord retract button.
Nov 08, 2012 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore canister vacuum retractable cord jammed
go and buy it from www. repairclinic.com
God bless you
Jul 06, 2012 | Vacuums
I have a Kenmore Vacuum cleaner 116.24212. The retractable electric cord won't retract. How can I fix it?
The retraction mechanizm is likely jammed. Mostly likely the cord has jumped it's groove in the retraction wheel/hub. If you are good with tools there is a 70% chance you can get it to work again with a basic DCR operation. Most mechanical problems can be solved using this simple rule: Dissassemble Clean and Reassemble.
CAUTION: The retract mech has a powerful spring inside, avoid exposing. Most retract mech units are rivoted closed so consumers won't poke thier eye out.
CAUTION: UNPLUG THE UNIT
Open the unit from the bottom and the top lid of the canister should come off.
The retract mech should be obvious as it is where the cord comes into the unit.
Look for the cord being bound by iteslf either on top or underneath (lie two cordes in one groove)
Remove any binding.
If you see no debris or obsticals for the cord to retract (where it is getting stuck)
Your spring could have sprung!
Do you feel and retract at all?
Can you locate the releae mechagnism?
Does the Release button seem to function? When Pressed it should take pressure off of the cord hub.
The retract mech may need replaced. Overall the cost will be about $60 for parts.
Feb 12, 2011 | Vacuums
Retractable cord
I'm assuming that you have bought the new retractable cord assembly. If you have so, I believe the cord should retract going counter-clock wise (pulling it makes it spin clockwise).
Feb 22, 2007 | Kenmore 23613 Progressive PowerMate Bagged...
Kenmore 22612 Bagged Canister Vacuum Logo
61 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
