Question about Jandy Air Energy Heat Pump - 100,000 Btus
Heat Sentry controller for Air Energy Heat Pump is not functioning
Where can I find a replacement?
2 Suggested Answers
UglyPoolGuy
  • 46 Answers
SOURCE: I receive Lo H20 message at an air energy heat
This is pretty common for LOW FLOW through the heater. Most of the time, homeowners turn the bypass the water away from the heater and this reduces the amount of water flowing through the heater. Check the bypass to ensure that you have enough water flowing through the heater.
There is nothing else that will throw this code unless the flow sensor is bad altogether.
Once you have inspected your bypass, and the code reappears, you will need to have the heater inspected and possibly change out the flow sensor.
Posted on Dec 08, 2010
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Tip
Solar Air Heating - You Can Cut Utility Costs and Save Money
Solar energy is becoming very quickly recognized as one of the best alternatives to fossil fuels It is an abundant and renewable natural resource. It can be used to save energy in residential, commercial, and industrial settings. Solar technologies will use the sun's energy to provide heat, hot water, light, electricity, and cooling, for homes, businesses, and industry.
Many major advancements have been made in the solar technology fields over the recent years. Solar air heating is becoming more attractive than ever before now that it is becoming lower in cost and more efficient. Solar energy is easily the cleanest and most inexhaustible of any of the known energy sources. The many variations in energy prices have fueled interest in alternative fuels such as solar energy. Demand for solar energy has been increasing exponentially as heating, cooling and many other energy costs continue to skyrocket.
Solar air heating and solar water heating are two examples of solar thermal technologies which produce heat, but not electricity. Solar air heat is best suited for installation in new construction and existing houses. Solar panels for any type of heating should be placed on a south-facing pitched roof, free of shade. The angle should be between 20 and 50 degrees. They may also be mounted on an angled frame on the ground or on a flat roof. Solar air collectors (the devices that heat up the air using solar energy) can directly heat individual rooms. They also can potentially pre-heat the air passing into a heat recovery ventilator or the air of an air-source heat pump. Solar heating panels can be one of the most cost effective ways to reduce your utility bills. This will make a positive contribution towards a better environment. Solar air heating systems often use large bins filled with rocks that store heat (although this method is becoming rare due to problems associated with controlling moisture and mold growth in the rock).
Energy Policy Act has implemented a 30% tax credit for consumers who chose to install solar water heating systems. State and local government programs are now being put in place to encourage the use of solar energy. Cash incentives are available for those that integrate solar energy technology as an alternative energy source. The Department of Energy (DOE) is working to design even more cost-effective solar heating systems and to improve the longevity of the materials used in those systems. Other incentive programs now include offering homeowners tax credits for solar panel installations and for solar heating systems. With solar power you will save money, increase your property value, help protect the environment and help to create a more secure America by reducing our dependence on foreign energy fuel sources.
A great solar heating system will save energy, reduce utility costs, and produce clean energy.
on Dec 12, 2009 | Heating & Cooling
Replacement 10 cup glass coffee pot
  • Items found similar to "GEMCO 10 Cup Glass Replacement ... www.ebay.ca/sch/sis.html?_nkw=GEMCO 10 Cup Glass Replacement Coffee... Items found similar to "GEMCO 10 Cup Glass Replacement Coffee Maker Carafe Decanter"
  • Items found similar to "BUNN Black Coffee Pot Carafe 10 ... www.ebay.ca/sch/sis.html?_nkw=BUNN Black Coffee Pot Carafe 10 Cup... Please enter a minimum and/or maximum price before continuing. C $ Enter minimum price to C $ Enter maximum price ...
  • One All 10 Cup Glass Eurostyle Universal Replacement ... www.amazon.ca/Glass-Eurostyle-Universal-Replacement-Carafe/dp/...
    • 4.7/5
    • 7 REVIEWS
    • ONE-ALL
    One All 10 Cup Glass Eurostyle Universal Replacement Carafe, Black: Amazon.ca: Home & Kitchen ... This replacement pot fits perfectly with my Braun coffee maker, ...
  • Bunn 10 Cup Replacement Glass Coffee Maker ... - ebay.com www.ebay.com > ... > Coffee & Tea Makers > Replacement Parts & Accs
    • SELLER 100.0% POSITIVE
    • KNIGHTDALE, NORTH CAROLINA
    BUNN 10 Cup REPLACEMENT GLASS COFFEE MAKER CARAFE DECANTER POT Black in Home & Garden, Kitchen, Dining & Bar, Small Kitchen Appliances ' eBay
  • images of Replacement 10 cup glass coffee pot bing.com/images 7f4o0&w=143&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">c03o0&w=148&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">0e6o0&w=113&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">3c4o0&w=113&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2"> See more images of Replacement 10 cup glass coffee pot
  • MELITTA REPLACEMENT GLASS COFFEE POT CARAFE 10 CUP ... www.ebay.com/sch/sis.html?_nkw=MELITTA+REPLACEMENT+GLASS+COFFEE... Find best value and selection for your MELITTA REPLACEMENT GLASS COFFEE POT CARAFE 10 CUP MINT search on eBay. World's leading marketplace.
  • Replacement 10 cup glass coffee pot - Fixya www.fixya.com > Forum > Coffee Makers & Espresso... Replacement 10 cup glass coffee pot - Coffee Makers & Espresso question
  • REPLACEMENT-Coffee-Maker-GLASS-POT-Mr-Coffee-10-12-cup ... www.ebay.com/sch/sis.html?_nkw=REPLACEMENT-Coffee-Maker-GLASS-POT... Items found similar to "REPLACEMENT-Coffee-Maker-GLASS-POT-Mr-Coffee-10-12-cup-"
  • Amazon.com: Medelco 10 Cup Glass Eurostyle Universal ... www.amazon.com > ... > Coffee Machine Accessories > Coffeemaker Pots > Fits my Braun 10-cup coffee maker perfectly. ... Medelco Glass Eurostyle Universal Replacement Carafe - Black, 12 Cup 3.5 out of 5 stars 109. ...
  • Cuisinart® 12-Cup Replacement Carafe in Black ... www.bedbathandbeyond.ca/store/product/cuisinart-reg-12-cup...
    • $34.99
    ... > Cuisinart® 12-Cup Replacement Carafe in Black ... 12-Cup Programmable Coffee Maker in ... original glass coffee pot and the replacement pot fits ...
  • One All Universal 10-Cup Eurostyle Glass Replacement ... www.walmart.com > ... > Kitchen Appliances > Coffee & Espresso Makers
    • 4/5
    • 15 RATINGS
    • $7.84
    • IN STOCK
    Buy One All Universal 10-Cup Eurostyle Glass Replacement Carafe, Black at Walmart ... 10-Cup Eurostyle Glass Replacement Carafe, ... Cup Glass Coffee Replacement ...
  • Mar 10, 2016 | Coffee Makers & Espresso Machines
    Can heat strip/pump control wiring be left unconnected?
    If you don't use the heat pump don't install a heat pump t-stat. But if you do use a ht. pump tstat you should be able to leave that wire off (the O wire) and it will function properly.
    Jun 22, 2015 | Dometic 3106995.032 Analog Thermostat Heat...
    Remote control not working for Haier Air Con. HSU 09LE08
    My problem is indicator blinking on off and after 30minute air cond good function and after 4hours air cond breakdown.
    Feb 15, 2013 | Heating & Cooling
    What are some examples of home automation?
    HVAC, centralized control of lighting, automatic security systems, applicances, etc
    Jan 30, 2013 | Home Automation
    Radiator
    For radiator replacement procedure. I suggest you to click the link below and follow the detailed procedure :-----
    How to replace Radiator?
    http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-audi-and-vw.html
    HOW TO REPLACE AN UPPER RADIATOR HOSE
    http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-upper-radiator-hose.html
    HOW TO REPLACE A LOWER RADIATOR HOSE
    http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-lower-radiator-hose.html
    How to replace Radiator on Car models?
    http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-acura-car.html
    How to flush cars radiator?
    http://repairhelpcenter.blogspot.com/2011/11/how-to-flush-cars-radiator.html
    HOW TO PRESSURE TEST A RADIATOR AND CAP
    http://schematicsdiagram.blogspot.com/2011/07/how-to-pressure-test-radiator-and-cap.html
    HOW TO REPLACE A RADIATOR
    http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-radiator.html
    HOW TO REPLACE A RADIATOR SUPPORT
    http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-radiator-support.html
    This details will help.
    Thanks.
    Feb 11, 2012 | 2001 Toyota Sequoia
    Jandy Air Energy Heat Pump - 100,000 Btus Logo
    264 people viewed this question
    Top Jandy Pool & Spa Experts
    David Spradling
    David Spradling
    Craig Butler
    Craig Butler
    Jay Finke
    Jay Finke
    Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
