Question about Mitsubishi WD73738 73 in 3D HDTVReady LCD TV
Mitsubishi wd 73738 is flickering
Light was just replaced after being dim. All was fine for about an hour. The screen is flickering in purples & greens and there is a "tick tick" sound coming from inside the set.
SOURCE: Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Posted on Nov 24, 2007
kazzandra
  • 16 Answers
SOURCE: light purple spots on my screen
Unfortunately, this sounds like a problem with your TV's lamp. They are not cheap to fix. Search Ebay for a new lamp and get someone to install it for you. These Mitsubishis have a design flaw that make the lamps burn out quickly.
One thing that will PREVENT this problem is making sure that the TV's vents are clean.
Posted on Apr 04, 2009
  • 8457 Answers
SOURCE: My mitsubishi Model # WD-60737.
Tv under a year old call Misubishi for a warrenty repair.Flashes staus light mean could be any these parts have problems power supply board,Ballast board or the pojection lamp itself.
Posted on Jan 11, 2011
i had the same problem and i called mitsubishi they said it is a software malfunction and they are sending me an update to install via flash drive. i am now awaiting the email
lovejoy91
  • 691 Answers
SOURCE: My mitsubishi wd-65c8 has a
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Posted on Jan 23, 2011
Replaced bulb in mitsubishi WD-73738 tv now it works for about 20 minutes and then flickers and smells hot
Cooling fan gone and cutting out on overheat? These projections televisions are so old tech :>)
Oct 14, 2015 | Mitsubishi WD Televison & Video
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
May 17, 2014 | Mitsubishi Televison & Video
Mitsubishi wd-60738 overheating
Look in the back for the fan area and see if you can feel/see it running. May be blocked or need to be replaced
Sep 16, 2012 | Mitsubishi WD-60738 TV
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
My 73'' mitsubishi model #wd-73738. Is flickering.
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Or try replace light engine..if the above solution won't work..
Feb 23, 2012 | Mitsubishi Televison & Video
I have a Mitsubishi WD-65731, After watching for an hour or two, the screen is taken over by a pink or purple color. We just got it back after replacing the optical engine.
You need to have the servicer check and re-seat all the connections to the light engine. It is also possible that the new engine may be at fault.
Feb 18, 2008 | Mitsubishi WD-65731 65" HDTV
Mitsubishi wd-52525 no picture or sound
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Jan 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD73738 73 in 3D HDTVReady LCD TV Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
